Power draw is the amount of electrical power, measured in watts (W), that your desktop consumes during operation. When we talk about desktops "under load," we're referring to those demanding moments when your PC is running AAA games at maximum settings, streaming gameplay, or rendering video content. During these intensive tasks, your OMEN desktop can demand significantly more power than when it's sitting idle on your desktop.
Understanding power draw isn't just about technical specifications, it's about ensuring your gaming experience remains smooth and uninterrupted. The right balance of power affects three critical areas: performance stability (preventing crashes and lag), cooling requirements (managing the heat from high-performance components), and overall efficiency (optimizing your electricity usage). That's why we've engineered desktops like the HP OMEN 35L and HP OMEN 45L with robust power supplies and advanced cooling systems specifically designed for high-performance gaming.
Why Power Draw Matters in Gaming PCs
Power draw affects every aspect of your gaming experience, from the components you can run to the temperatures your system reaches during marathon sessions. High-end components like the NVIDIA RTX 5090 or processors such as the AMD Ryzen 9 9950X3D and Intel Core Ultra 9 are incredible performers, but they also demand significant energy to deliver their full potential. The more powerful your CPU and GPU, the higher your system's overall power consumption—which is why understanding these relationships helps you make smarter decisions about your OMEN desktop configuration.
Stable power delivery is the foundation of consistent performance. When your PSU delivers steady, reliable wattage, your system runs smoothly without stutters, unexpected slowdowns, or sudden reboots. OMEN desktops like the HP OMEN 45L and HP OMEN 35L come equipped with power supplies specifically designed to support high-performance GPUs and CPUs without compromise. You can monitor this consumption in real-time using tools such as OMEN Gaming Hub, HWMonitor, or HWiNFO, giving you valuable insights into your system's power usage patterns.
The relationship between power and heat is direct and unavoidable—the higher your power draw, the more heat your components generate. Without sufficient cooling, this heat buildup can trigger thermal throttling, where your system deliberately slows down to prevent damage. That's why we've equipped desktops like the OMEN 45L with advanced cooling technology, including the innovative Cryo Chamber, to maintain optimal temperatures even during extended gaming sessions.
How to Estimate Your OMEN Desktop's Power Draw
Step-by-Step Calculation Method
Calculating your desktop's power draw starts with understanding which components consume the most electricity. Your CPU and GPU are the primary power consumers, but every component adds to the total. The CPU, often referred to as your computer's brain, has its power consumption typically listed as TDP (Thermal Design Power). Understanding the balance between CPU and GPU requirements is crucial, as explained in our article on GPU vs CPU for Gaming. Meanwhile, your graphics card typically represents the single largest power draw in a gaming system.
Beyond these main components, other parts contribute to your total power consumption. Your motherboard typically uses 50-80W, while RAM consumes about 3-5W per stick. Storage drives vary, with SSDs using around 5W and HDDs consuming about 10W. Cooling systems add another 5-30W depending on whether you're using fans or liquid cooling, and USB devices plus other peripherals contribute additional power requirements.
Practical Example: OMEN 45L Configuration
Let's walk through a real-world example using the OMEN 45L to understand how these numbers add up. The Intel Core i9-13900K processor consumes 125W during normal operation but can spike up to 250W under heavy load. The NVIDIA GeForce RTX 4090 graphics card draws approximately 450W when gaming at full capacity. Additional components including RAM, SSD, fans, and the motherboard collectively consume about 80 to 100W. When you total these numbers, the OMEN 45L can draw around 650-800W when pushed to its limits during intensive gaming or content creation.
The Importance of PSU Headroom
Smart system builders never purchase a PSU that just barely meets their calculated needs. Power spikes during gaming and future upgrade potential require extra capacity—we recommend adding 20-30% headroom above your estimated requirements. For our OMEN 45L example drawing 800W at peak, this means selecting a 1000W PSU provides the optimal balance. This additional capacity ensures your system runs cooler and quieter while maintaining stability during those intense gaming moments. Check out our step-by-step guide on How to Build a Gaming PC for more detailed building advice.
Visual Power Comparison: OMEN 35L vs 45L
| Model | Typical Configuration | Estimated Power Consumption | Recommended PSU |
| OMEN 35L | Intel Core i7 + RTX 4070 Ti | 450-550W | 750W |
| OMEN 45L | Intel Core i9 + RTX 4090 | 650-800W | 1000W |
The OMEN 35L offers a more power-efficient option for mainstream gaming, while the OMEN 45L provides the headroom needed for enthusiast-level components.
OMEN PSU Options: Understanding Gaming PC Wattage
The OMEN 35L and OMEN 45L come equipped with power supplies ranging up to 1200 watts, all featuring 80 Plus Gold Certification. This certification means these PSUs deliver power efficiently, converting more of your wall outlet's electricity into usable power for your components while wasting less as heat. The result is better performance, lower operating temperatures, and savings on your electricity bill over time.
Running your PSU below its maximum capacity isn't just recommended—it's essential for longevity and efficiency. Power supplies operate most efficiently at 70-80% of their rated capacity, which reduces internal stress, lowers heat generation, and extends the unit's lifespan. This headroom also provides crucial flexibility for future upgrades. When you decide to add a more powerful graphics card or additional storage drives, you won't need to worry about exceeding your power budget.
OMEN desktops utilize modular PSU designs, meaning you only connect the cables your system actually needs. This approach keeps your build clean and organized while improving airflow through the chassis. Better airflow means more efficient cooling, and the modular design makes future upgrades significantly easier since you're not wrestling with unnecessary cables. A robust PSU serves as the foundation for gaming stability, preventing crashes or performance drops when your CPU and GPU demand maximum power during critical gaming moments. Learn more about how to optimize your PC for gaming to get the most from your power supply.
PSU Requirements by Component Configuration
| Model | Typical GPU Options | PSU Size | Estimated Gaming Load |
| OMEN 35L | RTX 4070/4070 Ti | 800W-1000W | 450-600W |
| OMEN 45L | RTX 4080/4090 | 1000W-1200W | 600-850W |
Using Power Draw Calculators Effectively
When planning upgrades, a power draw calculator becomes an invaluable tool. Simply input your components—CPU, GPU, RAM, storage drives, and cooling—and the calculator estimates your total system power consumption. For instance, if you're considering adding an RTX 4090 to your OMEN 45L, the calculator might show 750-800W under load, confirming that your 1000W or 1200W PSU has ample capacity to support this upgrade with room to spare.
Efficiency and Cooling: Managing High Power Draw
The relationship between power consumption and heat generation is fundamental physics—when your PC pulls more watts, it naturally produces more heat. Left unmanaged, this heat can degrade performance through thermal throttling or even shorten component lifespan. That's why proper cooling isn't just about comfort; it's about maintaining peak performance consistently. Check out our guide on How to Cool Down OMEN Gaming Laptops for additional cooling insights that apply to desktop systems as well.
We've engineered the OMEN 35L and OMEN 45L with sophisticated cooling solutions including liquid cooling options and airflow-optimized chassis designs. These systems work in harmony—hot air is expelled efficiently while cool air flows strategically across critical components. This thermal management ensures consistent performance under load, preventing the performance degradation that occurs when components overheat.
The 80 Plus Gold efficiency rating on OMEN PSUs plays a crucial role in thermal management. By converting electricity more efficiently, less energy is wasted as heat within the power supply itself. This improved efficiency translates to lower operating temperatures throughout your system, reduced electricity consumption, and quieter operation since cooling fans don't need to work as hard. Over time, this efficiency extends hardware longevity by reducing thermal stress on components, ensuring your investment delivers reliable performance for years to come.
What Gamers Should Know About Power Management
Not every gaming session demands maximum power from your system. Lighter titles like Valorant or Minecraft run efficiently without stressing your hardware, while graphically intensive AAA games can push your GPU and CPU to their limits. This variance in power consumption is particularly noticeable on high-end systems like the HP OMEN 45L, where the difference between casual and intensive gaming can be hundreds of watts.
Smart settings can significantly reduce unnecessary power consumption without sacrificing gameplay quality. Enabling DLSS (Deep Learning Super Sampling) leverages AI to maintain visual quality while reducing GPU load. Setting an FPS cap prevents your system from rendering frames beyond what your monitor can display, eliminating wasted processing power. Using balanced graphics settings provides smooth gameplay without pushing every setting to maximum, finding the sweet spot between visual quality and efficiency.
Protecting your investment from power-related damage is crucial. A quality surge protector guards against voltage spikes that could damage sensitive components, while an Uninterruptible Power Supply (UPS) provides battery backup during outages, giving you time to save your progress and shut down properly. These protective measures become even more important as your system's value and power consumption increase.
Long gaming sessions naturally lead to higher electricity costs, making power awareness increasingly relevant. A power draw calculator helps you estimate these costs and plan accordingly, especially if you game for several hours daily. Understanding your system's power consumption helps you make informed decisions about when to use maximum settings versus more efficient configurations.
FAQs About Gaming PC Power Draw
How many watts does an OMEN desktop use under load?
The OMEN 45L with a high-end GPU typically consumes 500-700W under heavy gaming loads, while the OMEN 35L with a mid-range GPU uses approximately 450-550W under similar conditions. During idle or light usage, both systems draw considerably less—usually between 60-100W—demonstrating the dynamic nature of modern power management.
Is a 1200W PSU enough for RTX 5090?
Yes, a 1200W PSU provides ample capacity for an RTX 5090 build, even when paired with a high-end CPU and multiple storage drives. This wattage offers sufficient headroom for system stability, future upgrades, and even moderate overclocking if desired.
How do you check your OMEN PC's power draw?
Several methods allow you to monitor your desktop's power consumption effectively. An external watt meter like Kill-A-Watt plugged between your PC and wall outlet provides the most accurate real-time measurements. Software monitoring through OMEN Gaming Hub, HWInfo, or MSI Afterburner tracks individual component power usage—while not as precise as hardware meters, these tools offer convenient monitoring without additional equipment. PC power draw calculators help estimate consumption before making upgrades, letting you verify your PSU capacity before investing in new components.
What's the difference in power consumption between OMEN 35L and 45L?
The HP OMEN 35L, as a compact mid-tower system, typically features mid-range to upper mid-range GPUs, keeping average power draw between 350-550W under load. The larger HP OMEN 45L supports more powerful configurations including high-end GPUs, additional storage, and enhanced liquid cooling, resulting in power consumption ranging from 500-750W or more depending on the specific build. To explore these differences further, check out Best OMEN Gaming Desktops for Casual Gamers to see what each model offers.
Conclusion
Power draw might seem like a technical detail buried in specifications, but it's actually one of the most important factors determining your gaming PC's performance, stability, and longevity. The right balance of wattage, efficiency, and cooling ensures your desktop runs smoothly without overheating, crashing, or limiting your future upgrade potential.
By understanding and managing your system's power needs, you're not just protecting your hardware investment—you're optimizing your entire gaming and creative experience. Every component works in harmony when properly powered and cooled, delivering the consistent, reliable performance that serious gaming demands.
At HP, we've designed the OMEN 35L and OMEN 45L with these principles at their core. The HP OMEN 35L strikes an ideal balance for gamers seeking efficiency without sacrificing performance, while the OMEN 45L provides enthusiasts with maximum power and extensive upgrade potential. Both desktop models deliver the robust power supplies, advanced cooling systems, and long-term flexibility needed to handle today's most demanding games while remaining ready for tomorrow's innovations.
About the Author
Robert Maina is an experienced technology writer specializing in laptops, consumer tech, product reviews and buying guides. With over 10 years of experience, he creates clear, easy-to-understand content that helps readers choose the right technology for their needs.
