Thank you for visiting the NEW ZEALAND HP Store
Mon-Fri 9.00am - 6.00pm
When monitors are positioned incorrectly, users often experience neck and shoulder strain. Studies show that even the smallest changes in monitor positioning can increase neck muscle pressure by up to 400%. However, not all monitors are easily adjustable, making the monitor stand a crucial component of an ergonomic setup. With the rise of remote and flexible working arrangements across New Zealand, HP monitor stands offer adjustable tilt capabilities, making user experience highly personalised.
HP offers a wide range of monitor accessories that address these ergonomic challenges while maintaining workplace aesthetics. Our stands are designed to promote optimal viewing angles, with research indicating that the ideal monitor position should be 15-30 degrees below horizontal eye level. These stands are available in various colours, including classic Black, ensuring aesthetic appeal.
That said, posture and desk preferences are highly personal, so monitor stands must be adaptable rather than enforcing a one-size-fits-all approach. Whether you opt for an adjustable tilt or a monitor mount, each solution is tailored to fit your unique needs.
At HP, we offer a varied range of monitor stands to accommodate diverse user needs, including customised home-office setups. Each stand type has its own specific benefits and features—while some are sold separately, others come integrated with a new monitor. The available models provide enhanced compatibility with a variety of setups.
These cost-effective solutions offer simple angle adjustments to reduce glare and improve viewing comfort. However, they may not suit users who are especially short or tall or have non-standard desk heights. Since they lack moving parts, these stands tend to be highly durable and long-lasting. Be sure to check that the fixed height is comfortable before purchasing!
Height-adjustable stands are a great entry-point ergonomic solution. They feature smooth vertical adjustments, allowing users to position the top of the screen at eye level, which supports proper posture throughout the workday. The adjustable tilt feature offers customisable viewing angles. If you have a taller desk, these stands can often accommodate a sit-stand workstation setup.
HP’s premium monitor stands offer the most versatility. Not only do they provide support for heavy displays, but they also integrate seamlessly with the workspace. Depending on the model, you can expect features similar to those found in premium HP monitors available in New Zealand, which include:
Height adjustment up to 150mm
Tilt range of -5° to +23°
178° pivot for portrait mode
-45° to +45° swivel capability
With adjustability in all directions, these stands are ideal for collaborative work. Studies show that multi-screen setups can increase productivity by up to 42%. Articulating stands facilitate these setups by enabling monitors to be positioned vertically or horizontally, reducing excessive head movement and optimising viewing angles for different tasks. Various monitor mount options allow for flexible setups.
HP monitor stands follow industry-standard VESA mounting patterns (100x100mm and 75x75mm), ensuring compatibility with third-party mounting solutions.
Monitors can also be wall-mounted—a great option for security purposes, as it makes them harder to steal (look for models with security locks). The HP Quick Release Bracket, which is VESA-compatible, allows easy mounting to various stands, arms, and wall mounts, making it the perfect bridge to a customisable setup.
Their high-quality construction provides lasting durability. The long-term impact of poor office ergonomics is still being studied, as humans have only spent a few decades working on computers daily. While research is ongoing, we already know that improper workstation setups contribute to chronic pain and other health issues.
HP Display Center, a free tool for HP users, includes an ergonomic setup guide to help users optimise their workstation.
An ergonomically positioned monitor significantly reduces neck and shoulder tension. HP systems are designed to minimise strain. Research indicates that keeping the top third of your screen at eye level can prevent excessive downward tilting, which leads to muscle strain and potential long-term discomfort.
Proper monitor height is crucial for spinal alignment. Height-adjustable models allow for adjustments to accommodate personal comfort. When users can adjust their screen height freely, they naturally maintain better posture, reducing the risk of chronic back pain. This feature provides an effective means to enhance ergonomic setups.
Monitor positioning directly affects both visual comfort and productivity. The ideal viewing distance should be 50-70 cm (about arm’s length), with a downward gaze angle of 15-20 degrees. HP monitors with adjustable arms make this positioning seamless. Additionally, features like HP Eye Ease, flicker-free displays, and low blue-light technology help reduce digital eye strain.
Studies show that 80% of workers experience fatigue from prolonged PC use. Beyond positioning, factors like monitor brightness also play a crucial role in eye strain—excessive brightness in a dimly lit room is a significant risk factor. Proper monitor and stand pairing can ensure optimum performance through proper solutions.
This premium gaming monitor features a fully adjustable ergonomic stand, offering tilt, height, pivot, and swivel adjustments for optimal gaming comfort. It’s an excellent choice for serious gamers and professionals who need precision and flexibility.
27-inch screen size
QHD (2560 x 1440) resolution at 240 Hz
IPS display with 1ms GTG response time
Tilt, height, pivot and swivel adjustable stand
HDR, integrated speakers, AMD FreeSync™ Premium
NVIDIA® G-SYNC® Compatible
The comprehensive stand adjustments make this monitor perfect for long gaming sessions, helping New Zealand gamers maintain proper posture while enjoying responsive gameplay.
The OMEN 32q features a premium stand designed for comfortable gaming on a larger display. Its ergonomic adjustments help maintain proper viewing angles even with the larger 31.5-inch screen.
31.5-inch screen size
IPS display type with 165Hz refresh rate
1ms GTG response time with overdrive
Stand with ergonomic adjustment capabilities
AMD FreeSync™ Premium Technology
400 nits peak brightness with HDR support
99% sRGB and 95% DCI-P3 color gamut
The larger screen combined with the adjustable stand makes this monitor ideal for New Zealand gamers who need both immersion and comfort during extended play sessions.
HP’s monitor stands are designed for seamless multi-display setups, allowing for precise alignment between screens—even if they are different models.
Financial analysts may prefer multiple landscape monitors for better data visualisation. Programmers often benefit from a vertical second monitor, which allows them to view more lines of code. Designers use multi-monitor setups to streamline workflow, reducing the need to switch between programme views.
Available monitor mounts and stands offer this adaptability, ensuring efficiency for New Zealand professionals across various industries.
Flexible stands enhance various work scenarios:
Adjusting height for video calls to achieve an optimal camera angle
Using portrait mode for document review, which provides a more natural reading experience
Adapting to multiple users in shared workspaces, common in New Zealand’s growing co-working environment
When rotating your monitor, your operating system must be updated accordingly.
Windows Keyboard Shortcuts:
Ctrl + Alt + ↑ = Normal landscape view
Ctrl + Alt + → = Rotate 90° right
Ctrl + Alt + ← = Rotate 90° left
Ctrl + Alt + ↓ = Flip screen upside down
Efficient use of available space maximises workflow adaptability.
Windows Settings Method:
Press the Windows key, type “Display settings,” and press Enter
Select the display you want to change
Find the “Display orientation” dropdown
Choose your preferred orientation
Click “Keep changes” to confirm
For reading, switching to low-light or reading mode can further enhance comfort. HP offers systems tailored for adaptability, which improve workplace efficiency.
New Zealand’s bright natural light conditions can create unique challenges for monitor positioning. Many offices and home workspaces in New Zealand feature large windows to take advantage of the beautiful scenery, which can create significant glare issues. Adjustable monitor stands are particularly valuable in this context, allowing users to tilt and reposition screens throughout the day as lighting conditions change.
Additionally, with New Zealand’s strong focus on work-life balance and flexible working arrangements, many professionals are creating dual-purpose spaces at home. Adjustable monitor stands allow for quick reconfiguration of workspaces, helping Kiwis maintain clear boundaries between work and personal time.
Investing in an ergonomic monitor setup is one of the best ways to improve both productivity and long-term health, especially important for New Zealand professionals adapting to flexible working arrangements.
Your monitor and stand play a key role in creating a comfortable, efficient workspace. HP’s monitor stands prioritise VESA compatibility, adjustable tilt, advanced adjustability, and a sleek base design—all crucial factors in ergonomic workstations available through the HP New Zealand online store.
A well-chosen monitor stand can mean the difference between neck strain and comfort, disorganisation and efficiency. For New Zealand professionals looking to enhance their workspace ergonomics, HP’s range of monitors with quality stands offers solutions for every need and budget.
