Thank you for visiting the NEW ZEALAND HP Store
Mon-Fri 9.00am - 6.00pm
After the success of CS:GO, no one expected any other FPS game to be able to break the market, until VALORANT came on the scene. For Kiwi gamers looking to climb the competitive ladder, the tactical shooter has quickly become one of the most exciting esports titles in the region. Precision, reaction time, and split-second decision-making are crucial if you want to do well in the game. Whilst your own skills are imperative, you still need the hardware to support your goals. With high frame rates, optimised peripherals, and reduced input lag, you can give yourself the competitive advantage that will take your skills to the next level.
This is where OMEN Gaming PCs come in, as they are built with superior performance in mind. We utilise advanced technologies and hardware to deliver reduced latency and consistently high FPS, pairing them with our OMEN Gaming Hub to extract every ounce of performance from your hardware. In this guide, we’ll learn how to optimise your setup with the best settings for VALORANT, utilising in-game configurations, GPU driver optimisations, system tweaks, and peripheral adjustments. So without further ado, let’s jump right in!
In most competitive games, even the slightest advantage can make the difference between a clutch win and a frustrating loss. This edge can be gained by adjusting the in-game or hardware settings of your computer.
Here are a few desired effects that you should be looking for:
For tactical shooters like VALORANT, FPS (Frames Per Second) is significantly more important compared to many other genres. This is because higher FPS delivers smoother animations, more responsive aiming, and better visibility. Shooters are also the only games where you can actively tell the difference between higher FPS, making it easier to execute your skills properly.
Whether you’re competing in local New Zealand tournaments through the NZ Esports Federation or simply grinding ranked matches, maintaining consistent high frame rates gives you the responsiveness needed to outplay your opponents.
Input lag refers to the delay that occurs between you clicking your mouse and seeing the action being performed on the screen. This delay is often not noticeable during normal day-to-day work but becomes extremely apparent during gameplay. For competitive VALORANT, where milliseconds matter, reducing input lag is essential for quick peeks, accurate sprays, and clutch plays.
Unlike most single-player games, cranking graphic settings up to “Ultra” in tactical shooters might not be the smartest decision, as it often lowers FPS. For competitive gaming, speed and clarity are of utmost importance; finding the right balance between cinematic visuals and performance is crucial. Turn down unnecessary eye candy whilst preserving crisp visuals for spotting enemies.
Fortunately, VALORANT is extremely well-designed and performs exceptionally well on a wide range of hardware. This means that whether you have an entry-level OMEN Gaming Laptop or a high-end Gaming Desktop, you can get excellent performance without any significant issues.
Here’s a basic breakdown of the expected FPS you can get from OMEN hardware:
| Hardware Tier | GPU Example | Expected FPS |
Entry Level
GTX 1660 / RTX 3050
144–180 FPS
Mid Range
RTX 4060 / RTX 4060 Ti
200–300+ FPS
High-End
RTX 4080 / 4090 / 50 series
300+ FPS consistent
Now that we’ve determined the type of hardware you require, here are a few in-game settings that will complement your setup and ensure optimal FPS and clarity.
| Category | Settings | Reasons |
Display Mode
Fullscreen
Lesser input lag
Resolution
1920×1080 or 2560×1440
Ensured clarity
Limit FPS
Off / Uncapped
Artificial capping can cause a delay
NVIDIA Reflex
On + Boost (if GPU supports it)
Reduces system latency by coordinating CPU and GPU
Multithreaded Rendering
On
Makes use of your entire processor
Material Quality
Medium / Low
Unnecessary details don't impact gameplay
Texture Quality
Medium / Low
Helps with both clarity and performance
Detail Quality
Low
Reduces foliage and unnecessary visual elements
UI Quality
Low
Lower performance cost and a cleaner HUD
Vignette
Off
Reduces peripheral visibility
V-Sync
Off
Prevents input lag
Anti-Aliasing
MSAA 2x
Slight smoothing without performance costs
Anisotropic Filtering
4x
Helps textures
Improve Clarity
Off
Causes FPS spikes
Bloom
Off
Bloom adds glow effects that can mask contrast
Distortion
Off
Avoid warping or visual distortion
Cast Shadows
Off
Merely cosmetics that can affect performance
Here are a few additional audio settings that complement your visual settings for an optimal gaming experience:
These optimised settings strike the perfect balance between visual clarity and performance. By disabling resource-intensive effects like shadows, bloom, and distortion, you free up GPU resources for higher frame rates whilst maintaining the visual information needed to spot enemies quickly. This configuration is particularly effective on HP gaming systems, where the hardware can deliver consistent high FPS without bottlenecks.
Now that we have everything else ready, it is time to move towards some additional optimisations that will bring out the best in your GPU. Most OMEN computers come with either an NVIDIA or an AMD GPU, so let’s take a closer look at how you can optimise both:
NVIDIA SYSTEMS
For NVIDIA systems, you should:
NVIDIA Control Panel:
AMD SYSTEMS
On the other hand, for AMD computers, here’s what you should do:
AMD Adrenaline:
After setting up the hardware and optimising all the game settings, we must now consider the system settings, including the Windows and network settings. Let’s look at what you should be setting up for the best VALORANT experience.
For the network settings, make sure you have:
New Zealand players should aim for ping below 50ms for optimal competitive performance. If you’re experiencing higher latency, check with your ISP about gaming-optimised connections or consider upgrading your internet plan.
Finally, we reach the last step, which involves setting up the audio and peripherals that enhance the overall gaming experience and enjoyment. Ambiance is essential when you’re trying to zone into your gaming sessions, and here’s how you can get the best setup:
The OMEN Gaming Hub is your command centre for optimising system performance. Here’s how to leverage its features for VALORANT:
What are the best settings for VALORANT FPS optimisation?
The truth is, there isn’t a single “one-size-fits-all” answer, because the best settings depend on your hardware and monitor. That said, most competitive players follow the same principle: lower graphics for higher, more stable FPS. Turning off shadows, bloom, and distortion removes distractions whilst boosting performance. On OMEN gaming systems, you can comfortably run these optimised settings and still achieve 240+ FPS.
Should I use stretched resolution on OMEN systems?
Some players swear by stretched resolutions, claiming they make enemies appear wider. The trade-off is that your visuals get distorted, which can hurt clarity and consistency over time. Since OMEN hardware already delivers excellent frame rates at native resolutions, you don’t need to sacrifice visual accuracy for higher frame rates. For New Zealand players competing at the highest level, we recommend sticking with native resolution for the best competitive experience.
Can OMEN laptops achieve 240+ FPS in VALORANT?
Yes, that’s one of the great things about VALORANT being so well optimised. A mid-tier OMEN laptop with an RTX 4060 or better can comfortably achieve 240 FPS, especially when using the recommended settings. The OMEN 16 inch Gaming Laptop 16-u1003TX with its RTX 4060 GPU easily maintains these frame rates, making it perfect for competitive play both at home and on the go.
What’s the best OMEN desktop for serious VALORANT players?
For players who want absolute maximum performance, the OMEN by HP 45L Gaming Desktop PC offers top-tier specifications including an RTX 4080 GPU and Intel® Core™ i9-14900K processor. This system delivers consistent 400+ FPS, eliminating any hardware bottlenecks from your competitive gameplay.
How important is internet speed for VALORANT in New Zealand?
Whilst VALORANT doesn’t require massive bandwidth, stable, low-latency internet is crucial. Most New Zealand players connect to Sydney servers, so a fibre connection with consistent speeds will minimise ping spikes. We recommend at least a 50 Mbps connection, but more importantly, ensure low latency rather than just high speeds. Using a wired connection through your OMEN desktop will always outperform Wi-Fi for competitive play.
Should I disable Windows animations for better performance?
Yes, disabling Windows visual effects can free up system resources and reduce input lag. Navigate to System Properties > Advanced > Performance Settings, and select “Adjust for best performance.” This removes unnecessary animations and effects, allowing your OMEN system to dedicate more resources to VALORANT.
Creating the ultimate VALORANT setup goes beyond just your PC. Here’s a comprehensive checklist for competitive players:
Once you’ve optimised your system, maintaining that performance is crucial:
Use OMEN Gaming Hub to track system metrics over time. If you notice FPS drops or increased temperatures, investigate potential issues before they impact your competitive performance.
Winning in VALORANT comes down to awareness, speed, and precision, and with these settings, you’ll get access to all of them. By fine-tuning your OMEN Gaming PC with the proper settings based on your hardware, you will not only unlock higher FPS and lower latency but also have a more enjoyable time due to crisp timings. Whether you’re grinding ranked, competing in local New Zealand tournaments through the NZ Esports Federation, or preparing for international competition, these optimisations will give you the performance edge you need.
From gaming laptops perfect for portable performance to powerful gaming desktops that deliver maximum FPS, OMEN systems are engineered specifically for competitive gaming. Combined with optimised gaming monitors and gaming accessories, you’ll have everything needed to compete at the highest level.
Experience competitive gaming excellence with HP OMEN systems, engineered for esports precision and built for consistent high-FPS dominance. Take your VALORANT gameplay to the next level with hardware designed for New Zealand’s most dedicated gamers.
