Liquid vs. Air Cooling Technologies for CPUs - Discover OMEN’s Cryo Chamber
April 21, 2025
Modern PC gaming systems are truly remarkable. Today’s gaming computers deliver more realistic graphics, exceptional gameplay, and higher frames per second (FPS) than we could only dream about a decade ago. Even more impressively, they accomplish this with smaller hardware and PC chassis than previously imaginable.
For British gamers looking to take advantage of these technological advances, understanding cooling systems is essential, especially given our varying climate that can sometimes challenge PC performance.
But this ultra-high performance comes with a notable drawback—specifically, significant heat generation during marathon gaming sessions. This excessive heat can damage electronics, affect performance, and cause PCs to crash unexpectedly.
The most dedicated gamers are turning to cutting-edge cooling solutions, like liquid cooling and cryo chambers, to prevent performance issues and maintain their PCs’ health. Read our comprehensive guide to liquid cooling vs. air cooling systems to determine which is best suited for your requirements.
Air Cooling Systems
Air cooler systems are the most straightforward—and cost-effective—solution to cooling down your OMEN gaming PC. Most consumer PCs and laptops use some form of air cooling to prevent overheating and maintain a high level of performance.
This system typically comes with both intake and exhaust fans. These dual fans allow the system to expel hot air out of the chassis and bring cold air in from the other side to cool components, like the CPU and GPU. When you combine these fans with a heatsink (which absorbs heat from critical electronics and dissipates it into the air), you get an effective cooling system with efficient heat dissipation technology that’s perfect for most home use cases.
While there are numerous CPU cooling systems to choose from, the most common are tower and low-profile coolers. Tower coolers are usually found in PCs with a large tower chassis. They’re typically high-performance and very effective at removing heat. On the other hand, low-profile coolers are most often used in laptops and they’re not nearly as effective as their larger counterparts.
Cost-sensitive consumers can look to air cooling systems as a competitively-priced way to cool their gaming PC without exceeding their budget. They’re also easy to install, maintain, and troubleshoot when broken. Plus, you don’t have to worry about liquid coolant leaks.
However, when it comes to liquid cooling vs. air cooling, air cooling systems may struggle to remove enough heat from high-performance PCs, like those used for gaming, graphic design, and data analysis. Large tower cooling systems also take up quite a bit of room in the chassis and can get in the way of other components. Finally, they often run loud and the noise level can get quite high.
Liquid Cooling Systems
Liquid cooling systems are a premium alternative to air cooling systems. These high-end setups come with a pump, radiator, water block, and multiple insulated tools. They’re much more expensive compared to an air cooling setup, but they can remove quite a bit more heat. This makes a liquid CPU cooling system the best option for high-performance gaming PCs that can run dangerously hot.
An all-in-one liquid CPU cooling system is the best choice for gamers who want a plug-and-play option. That’s because they come pre-assembled and can be installed in minutes. With this type of turnkey unit, the pump, radiator, and water block come as a single unit.
On the other hand, custom loop solutions are used by PC hobbyists and gamers who prefer a more elegant solution. If you’re interested in building your liquid cooling system and wringing the best performance out of your setup, you can build a fully customizable loop system that lets you cool multiple components in a single loop.
This approach is also favoured by gamers who focus on aesthetics. A properly set up loop system can be beautiful and it’s often used by gamers who go for vivid colour splashes and a transparent PC case, while also improving the gaming case airflow.
Liquid cooling systems come with much greater performance compared to traditional air cooled systems, especially when it comes to high-performance gaming PCs that naturally run hot. This includes those running overclocked CPUs and GPUs, and systems that run 1440p or 4K resolutions.
They’re also much quieter than air cooling systems and allow you to easily customise the look of your PC with RGB lighting and other vivid designs.
Despite these many benefits, liquid cooling systems are much more expensive than their air cooled counterparts and they may not fit every gamer’s budget. They’re also more difficult to install and come with the risk of liquid leaks that could damage your expensive PC.
Advanced Cooling Innovations
In addition to liquid cooling vs. air cooling options, HP also provides gamers with advanced cooling innovations that can boost your OMEN gaming PC’s performance and extend the life of your components.
The OMEN by HP 45L Gaming Desktop PC features cutting-edge cooling technology that separates the cooling system from the main PC case. This frees up room in the PC tower and delivers even more efficient thermal performance optimization.
Here’s how it works. With advanced cooling chambers, the radiator is located in a separate compartment of the OMEN PC tower. This gives your system better airflow, lower temperatures, and unbeatable PC performance. It also results in lower fan speed and improved FPS stability. Finally, it will extend the life of all your PC’s components by improving temperature control that can damage electronics over time if left unchecked.
HP has run several benchmark tests—and consistently found that PCs with advanced cooling chambers have better CPU thermal management and lower noise levels than other gaming PCs.
Cooling Performance Comparisons
The results are in! When it comes to liquid cooling vs. air cooling systems, liquid cooling outperforms air cooling in nearly every category. HP’s options are among the best CPU coolers, and can keep CPUs and other critical components up to 10-20 degrees cooler than air cooling systems. This has been proven time and time again during rigorous stress tests.
Custom liquid cooling loops perform even better, which is why many gamers call them the best CPU cooler available. This is especially true when they’re separated into multiple compartments to boost performance.
Liquid cooling systems are also much quieter compared to air cooling systems. The lack of noisy fans is a huge benefit to gamers who don’t use headphones. Advanced cooling chambers operate even quieter than standard liquid cooling systems.
However, despite the clear performance benefits of liquid cooling systems, they are much more expensive than traditional air cooling. This makes it a premium option that may or may not be suitable for your particular budget.
Finally, air cooling systems are more reliable than their liquid counterparts. They can run for long periods without any maintenance, outside of cleaning dust out of the fans themselves. Liquid cooling systems, on the other hand, require regular maintenance and pump checkups to keep them in good working order. Failure to properly maintain a liquid cooling system can result in leaks that can damage components.
Gaming Performance Impact
One of the reasons why high-end cooling systems are so important in the gaming world is heat’s negative impact on PC performance. High temperatures can lower FPS, cause stutters, and lead to component damage over the long term.
Liquid cooling systems eliminate most of these risks. They help CPUs and GPUs boost clocks. Ultimately, this leads to more stable and higher FPS—and longer-lasting components that save money in the long term.
In addition, gamers who regularly engage in marathon sessions will want to look at liquid CPU cooler systems to maintain performance and prevent failures. That’s because hours-long gaming sessions can lead to sharp temperature rises over time and air cooled systems will struggle to bring temps down to a reasonable level.
Casual gamers can start with an air cooling system and still have a great time. That’s because these systems can maintain low temperatures for an hour or two without issue, especially when playing on lower resolutions like 1080p.
Setup and Optimization
Now that you’ve chosen the best CPU cooler, it’s time to prepare for setup. Most air cooling systems are simple to install and can be done in minutes. The only issue you’ll need to look out for is RAM and GPU clearance because of their size.
Those looking to install liquid coolers will need to set aside more time for installation. Consider watching several tutorial videos before installation to increase your comfort level with the process and components.
Finally, make sure you set up a regular maintenance schedule to prevent disruptions and optimize performance. Air cooling systems are easy to maintain. Just clean out the fans and heatsinks every quarter.
Liquid systems require more detailed maintenance. You’ll need to check the pump monthly to ensure it’s operating smoothly. You’ll also need to replace coolant regularly and inspect tubes for cracks every few months.
Conclusion
Gamers are always on the hunt to optimize their gaming desktop PC for the best performance. Casual gamers and those playing with lower resolutions can confidently use traditional air cooling systems and still have a great gaming experience.
However, gamers using advanced VR technology, high resolutions, and engaging in marathon gaming sessions need the best CPU cooler to maintain performance and protect their investment. Look for liquid cooling systems that can lower high temperatures and boost performance to get the most bang-for-your-buck and highest-quality gaming experience.
Also, keep an eye out for new developments in the world of PC cooling. Advanced cooling technology, like that found in the OMEN by HP 45L gaming desktop, is becoming more reliable and widespread. In the future, you’ll be able to run incredibly powerful setups without any concern about heat or performance by using a cutting-edge cooling system that can tame the hottest components and highest gaming resolutions.
HP’s MSRP is subject to discount. HP’s MSRP price is shown as either a stand-alone price or as a strike-through price with a discounted or promotional price also listed. Discounted or promotional pricing is indicated by the presence of an additional higher MSRP strike-through price
The following applies to HP systems with Intel 6th Gen and other future-generation processors on systems shipping with Windows 7, Windows 8, Windows 8.1 or Windows 10 Pro systems downgraded to Windows 7 Professional, Windows 8 Pro, or Windows 8.1: This version of Windows running with the processor or chipsets used in this system has limited support from Microsoft. For more information about Microsoft’s support, please see Microsoft’s Support Lifecycle FAQ at https://support.microsoft.com/lifecycle
Ultrabook, Celeron, Celeron Inside, Core Inside, Intel, Intel Logo, Intel Atom, Intel Atom Inside, Intel Core, Intel Inside, Intel Inside Logo, Intel vPro, Itanium, Itanium Inside, Pentium, Pentium Inside, vPro Inside, Xeon, Xeon Phi, Xeon Inside, and Intel Optane are trademarks of Intel Corporation or its subsidiaries in the U.S. and/or other countries.
Microsoft Windows 10: Not all features are available in all editions or versions of Windows 10. Systems may require upgraded and/or separately purchased hardware, drivers, software or BIOS update to take full advantage of Windows 10 functionality. Windows 10 is automatically updated, which is always enabled. ISP fees may apply and additional requirements may apply over time for updates. See http://www.microsoft.com.
Get Marvel’s Avengers when you purchase HP gaming PCs with qualifying 9th gen or 10th gen Intel® Core™ i5, i7 and i9 processors. Redemption code will be sent out by email within 60 days of purchase. Limited quantities and while supply lasts. Offer valid thru 12/31/2020 only while supplies last. We reserve the right to replace titles in the offer for ones of equal or greater value. Certain titles may not be available to all consumers because of age restrictions. The Offer may be changed, cancelled, or suspended at any time, for any reason, without notice, at Intel’s reasonable discretion if its fairness or integrity affected whether due to human or technical error. The Offer sponsor is Intel Corporation, 2200 Mission College Blvd., Santa Clara, CA 95054, USA. To participate you must create an Intel Digital Hub Account, purchase a qualifying product during the redemption period, enter a valid Master Key, and respond to a brief survey. Information you submit is collected, stored, processed, and used on servers in the USA. For more information on offer details, eligibility, restrictions, and our privacy policy, visit https://softwareoffer.intel.com/offer/20Q3-19/terms.
