23 May 2025
HP OMEN PC Memory Guide: Optimised for Creative Work
As Australia’s creative industry continues to flourish across our major cities from Sydney to Melbourne and Perth, content creators are constantly pushing their machines to the absolute limit. Whether you’re rendering high-resolution videos for streaming platforms or designing complex 3D models for architectural visualisation, having robust memory architecture to support your creativity is essential. But what exactly is memory architecture?
Though it sounds technical, think of memory architecture as your workspace. If your workspace is too small, it quickly becomes cluttered, and finding what you need requires constant reorganisation. The same applies to your computer’s memory—well-designed memory architecture allows your PC to access, process, and store data quickly without lag or bottlenecks.
Why HP OMEN PC Memory Architecture Stands Out
HP OMEN PCs are built with efficiency and utility in mind, equipped with low-latency, high-speed RAM configurations that can handle virtually any creative challenge. By designing memory architecture that prioritises efficiency and stable functionality, OMEN machines have become some of the best PCs for video editing and graphic design available to Australian creators.
This focus on creative work efficiency means HP OMEN’s memory architecture can handle large datasets, multitasking, and running multiple virtual machines simultaneously. Your HP OMEN system can switch between intensive applications flawlessly, allowing your creative process to flow smoothly without performance compromises.
Why Memory Matters for Australian Creatives
Your computer’s memory performs various critical operations during creative workflows:
  • Smooth Performance: Enables heavy tasks like 4K video editing and multitasking without stutters or lags
  • Stability: Ensures your machine doesn’t crash, lag, or slow down during demanding workflows
  • Responsiveness: Enables quick loading of applications and faster data processing
  • Future-Proofing: Supports evolving creative software requirements across the Australian market
Understanding HP OMEN’s Memory Architecture
Many people believe more memory automatically means better performance. While partially true, optimal performance requires more sophisticated architecture. Understanding how HP OMEN’s memory is designed helps explain why these systems deliver exceptional performance without necessarily requiring hundreds of gigabytes of RAM.
Different Models, Different Setups
HP OMEN offers tailored configurations designed for specific user needs across Australia:
  • High-end Models: Feature faster RAM, larger capacity, and greater upgradability
  • Entry-level Systems: Prioritise efficiency and utility while remaining budget-friendly, making HP OMEN gaming and content creation accessible without breaking the bank
Whether you’re working from a home studio in Brisbane or a co-working space in Adelaide, there’s an HP OMEN configuration suited to your creative needs and budget.
Types of RAM in HP OMEN Gaming PCs
HP OMEN PCs are built with specialised components to ensure maximum performance for Australian creators:
  • DDR5 & DDR4 RAM: Most HP OMEN gaming PCs use DDR4 or DDR5 RAM, with newer models featuring DDR5 for higher bandwidth, lower power consumption, and faster speeds
  • SO-DIMM (Laptops): Smaller memory modules used in laptops, often equipped with dual-channel configurations for better performance
  • DIMM (Desktops): Standard memory modules used in desktop computers, with HP OMEN selecting top-tier components for faster speeds, better cooling, and upgradability
  • ECC vs. Non-ECC: While most HP OMEN gaming PCs use non-ECC RAM for faster speeds, some workstation builds feature ECC RAM modules for better data accuracy and processing
Professional creators across Australia need systems that can keep pace with demanding workflows without lags or bottlenecks. HP OMEN’s memory architecture optimises RAM usage to provide seamless creative experiences across various disciplines:
Video Editing Performance
Benefits:
  • Reduced buffering times with increased memory speeds
  • Seamless 4K and 8K editing regardless of layer count or effects complexity
  • Smoother timeline scrubbing and real-time effect previews
  • Faster export and rendering times
Recommended Configuration:
  • Entry-level (1080p editing): 16GB DDR4 3200MHz
  • Professional (4K editing): 32GB DDR5 4800MHz
  • High-end (8K editing): 64GB DDR5 5600MHz
Best HP OMEN Desktop for Video Editing
The HP OMEN 45L represents the pinnacle of creative performance for Australian content creators. With its powerful Intel® Core™ i9-14900K processor and NVIDIA® GeForce RTX™ 4090 graphics card, this desktop delivers exceptional video editing capabilities for professional workflows.
  • Intel® Core™ i9-14900K (up to 6.0 GHz with Intel® Turbo Boost Technology)
  • 64 GB DDR5 memory for seamless 8K video editing
  • NVIDIA® GeForce RTX™ 4090 (24 GB GDDR6X dedicated)
  • Multiple connectivity options including DisplayPort™ and HDMI
This powerhouse desktop excels at handling complex video editing projects, real-time colour grading, and simultaneous rendering tasks that Australian creative professionals demand.
3D Rendering Capabilities
Benefits:
  • Faster render times with high bandwidth support
  • Real-time modelling with reduced lag
  • Improved viewport performance with complex scenes
  • Better handling of high-resolution textures and complex geometry
  • Entry-level: 16GB DDR4 3200MHz
  • Professional: 32GB DDR5 4800MHz
  • Production-grade: 64GB+ DDR5 5600MHz
Best HP OMEN Laptop for Mobile 3D Work
For Australian 3D artists who need desktop-class performance on the go, the HP OMEN 17.3 inch laptop delivers exceptional rendering capabilities. Perfect for architects, game developers, and visual effects artists working across multiple locations.
  • Intel® Core™ i9-13900HX (up to 5.4 GHz with Intel® Turbo Boost Technology)
  • 32 GB memory for complex 3D scene handling
  • NVIDIA® GeForce RTX™ 4090 Laptop GPU (16 GB GDDR6 dedicated)
  • 17.3" diagonal QHD display for detailed work
This laptop provides the power needed for real-time 3D modelling, animation previews, and mobile rendering workflows essential for Australian creative professionals.
Graphic Design Enhancement
Benefits:
  • Quick loading of large Illustrator, CAD, Blender, and Photoshop files
  • Lag-free processing of complex designs with multiple layers
  • Smooth handling of high-resolution assets
  • Responsive brush and tool performance
The versatility of desktop PCs makes them ideal for graphic designers who need multiple large displays and extensive storage options.
Disclosure:
