April 8, 2025
Multi Frame Generation on RTX 50 Series: Breaking Down the FPS Revolution
With our stunning landscapes and increasing interest in esports, New Zealand gamers deserve top-tier performance from their gaming setups. Gadgets with high frame rates deliver an unforgettable gaming experience, and NVIDIA’s Multi Frame Generation (MFG) technology with AI capabilities represents a significant leap in gaming innovation. AI MFG provides gamers with smooth and responsive gameplay with refresh displays at ultra-high levels.
In this guide, you’ll learn about the evolution of FPS technologies for gaming, the impact of DLSS, the OMEN MAX 16 plug-and-play design, and more MFG insights that can elevate your gaming experience, whether you’re playing competitively or casually from Auckland to Wellington.
The Evolution of Frame Rate Enhancement Technologies
Understanding Multi Frame Generation: How it Works
Frame Generation
  • Uses AI to synthesise frames
  • Enhances smoothness via interpolation and neural networks
  • May result in some latency
  • Enhanced CUDA Cores (Up to 21,760)
DLSS 4 MFG doubles performance with neural shaders in real-time interpolation. It creates three AI frames per rendered frame (compared to one in DLSS 3) and activates transformer models exclusive to RTX 50 GPUs for higher quality and reduced memory usage.
AI Neural Networks
The system employs experience replay and transfer learning techniques for training:
  • Generative Adversarial Networks
  • Long Short-Term Memory
  • Convolutional Neural Network
The NVIDIA RTX 50 Series
The latest RTX 50 Series:
  • Accelerates AI workflows
  • Features Blackwell architecture
  • Offers AI frame generation
  • Enhanced data yield with 5th-gen Tensor Cores
The RTX 50 Series’ Fifth-Generation Tensor Cores
These advanced Tensor Cores are:
  • Capable of 3,352 trillion operations per second
  • Optimised for DLSS 4
  • Provide neural rendering for gaming and allied applications
Multi Frame Generation vs. DLSS: Clarifying the Relationship
DLSS 4.0 Multi Frame Generation
  • Utilises AI transformer models
  • Yields up to three frames per rendered frame
  • Boosts performance through Resolution and Ray Reconstruction
Integration of MFG and DLSS
  • Unifies resolution scaling
  • Improves lighting accuracy
  • Multiplies frames via AI
  • Delivers new levels of smoothness and fidelity (previously impossible in demanding games like Cyberpunk 2077)
Complementary Synergy
  • Creates synergy between Super Resolution and MFG
  • Reduces GPU load for upscaling
  • Provides up to an eightfold performance boost (e.g., in Dune Awakening)
Configuration Flexibility
  • Offers in-game presets
  • Allows NVIDIA App overrides
  • Supports users toggling between AI frame generation modes (3X and 4X)
Real-World Performance Gains: The Numbers
Frame Rate Improvements with DLSS 4 MFG
  • Cyberpunk 2077 using Path Tracing (4K): Fourfold increase from 63 FPS to 200+ FPS
  • Alan Wake 2: 3.35X FPS surge from 32.5 to 109 FPS
DLSS 4.0 demonstrates superior performance over DLSS 3 at 1440p with a mix of texture clarity and edge stability, making gameplay smoother at 144Hz–240Hz.
For optimal utilisation of 144Hz–240Hz monitors, MFG requires a base of 36-48 FPS.
System load reduction is achieved through precise timing, lowering redundant rendering and saving up to 50% in power usage.
Beyond Raw FPS: Other Benefits
  • GPU submission synced with visual refresh cycles enhances frame delivery, reducing input latency and variance
  • Lower FPS with enhanced smoothness is achieved using synchronised adaptive refresh rate
  • Temporal upscaling leads to better display quality aided by presentation timestamps
  • Optimised pacing balances responsiveness, smoothness, and efficiency while mitigating trade-offs in competitive scenarios
The Plug-and-Play Revolution: OMEN Gaming Laptops with RTX Technology
OMEN MAX 16
Shop Omen Max 16 Now
The OMEN MAX 16, OMEN’s most powerful laptop yet, represents the pinnacle of gaming laptop engineering. Equipped with next-generation components and the freedom to overclock beyond normal limits without fear of throttling or long-term damage, it delivers desktop-level power in a portable form factor. While the OMEN MAX 16 isn’t yet available in New Zealand stores, HP offers several powerful OMEN alternatives that New Zealand gamers can purchase today.
The OMEN MAX 16 showcases what’s possible with AI-powered frame generation. Its advanced cooling system and “Unleashed Mode” allow it to push components to their limits, delivering chart-topping frame rates with NVIDIA’s latest RTX GPUs. This level of innovation sets the standard for what gaming laptops can achieve with proper thermal management and power delivery.
For New Zealand gamers looking for a similarly premium experience, the OMEN 16 inch gaming laptop 16-u1002TX offers outstanding performance with its Intel® Core™ i9-14900HX processor and NVIDIA® GeForce RTX™ 4070 Laptop GPU. While not quite at the level of the unreleased MAX 16, it still provides exceptional gaming experiences with many of the same plug-and-play advantages.
Unlike desktop setups that often demand technical expertise for optimal performance, OMEN laptops provide an accessible solution for non-technical gamers. The AI-powered optimisation through the OMEN Gaming Hub eliminates trial-and-error troubleshooting, making high-performance gaming more accessible and user-friendly compared to custom desktop configurations.
The ease of use is a significant advantage for new gamers. Notably, OMEN laptops have democratised high-end gaming with powerful NVIDIA RTX GPUs, facilitating elite performance with AI-driven optimisation. The entire gaming community now has access to experience high FPS gaming with this easy setup, requiring no technical knowledge.
While waiting for the OMEN MAX 16 to reach New Zealand shores, consider the powerful OMEN 16 inch gaming laptop 16-u1003TX with its Intel® Core™ i7-14700HX processor and NVIDIA® GeForce RTX™ 4060 Laptop GPU, which delivers exceptional frame generation capabilities in a readily available package.
Mobile Gaming Performance: OMEN Laptop Benchmarks
Additionally, the OMEN 16.1 inch gaming laptop 16-xf0068AX offers superior frame rates, easy setup, and effective cooling, making it the portable choice for elite gamers seeking high performance. Its high refresh rate display is a huge plus for gaming smoothness.
For those who prefer a newer model, the OMEN 16 inch gaming laptop 16-u1003TX represents the latest in gaming technology with its Intel® Core™ i7-14700HX processor and NVIDIA® GeForce RTX™ 4060 Laptop GPU, delivering exceptional performance for modern gaming titles.
These laptops are particularly beneficial for New Zealand gamers who may need to take their gaming setups to local tournaments or LAN events around the country, where portability without compromising on performance becomes crucial.
Desktop Implementation: OMEN Desktops with RTX Series Options
OMEN Desktop
Shop HP OMEN 45L Gaming Desktop Now
The OMEN by HP 45L gaming desktop GT22-2007a PC is optimised with NVIDIA GeForce RTX™ 4080 GPU, an advanced cooling system, and its native Cryo Chamber configured for optimal thermal performance. It’s designed with room for RAM upgrades, making it highly customisable.
As described on the product page: “Enables the liquid cooler radiator to pull-in cold air from the surrounding environment to cool down the CPU.” This innovative cooling solution is particularly valuable in warmer New Zealand summer months when maintaining optimal system temperatures can be challenging.
For those seeking alternatives, the OMEN 40L desktop GT21-2008a PC also offers impressive specifications with an Intel® Core™ i7-14700F processor and NVIDIA® GeForce RTX™ 4080 GPU.
If you’re looking for a more budget-friendly option without compromising too much on performance, the Victus by HP 15L gaming desktop TG02-0016a PC provides a solid gaming experience with its Intel® Core™ i5-12400F processor and NVIDIA® GeForce RTX™ 3050 graphics.
Compared to laptops, these OMEN desktops provide high-performing power delivery and thermal optimisation, leading to performance stability and longevity. For future upgrades, the modular design supports GPU swaps, refits, and larger storage expansions.
The OMEN gaming performance edge makes the RTX Series FPS boost an attractive choice for gamers looking for a durable device with high-end gaming capabilities. This is particularly relevant for New Zealand gamers who value long-term investment in their gaming hardware, given the premium costs often associated with importing technology.
Setting Up and Optimising Multi Frame Generation
The OMEN Gaming Hub is recommended to configure and enable MFG:
  • Enable DLSS 4 game support settings for supported titles
  • Adjust resolution and visual texture quality using in-game settings to balance performance and HD display
  • Use monitoring tools to verify performance improvements
  • Check frame rates alongside system temperatures in game mode to enhance optimal performance
  • Adjust monitor settings to optimise refresh rates for gaming smoothness
Key Optimisation Points:
  • OMEN Gaming Hub simplifies gaming setup, delivering the best settings for accessibility and high-end performance
  • OMEN laptops offer multiple performance modes in the OMEN Gaming Hub, delivering optimised cooling and power for best outcomes
Portable Gaming Performance Optimisation
Recommendations:
  • Ensure your GPU supports NVIDIA’s DLSS and activate these features before gameplay to boost frame rates
  • Maintain consistent performance by capping frame rates
  • Monitor cooling and temperature settings during gameplay and adjust accordingly for performance optimisation
  • Achieve gaming smoothness through balanced frame rates and display quality by optimising in-game settings
  • Implement proper thermal management (cooling pads, external fans, thermal paste) to maintain optimal temperatures for consistent performance in gaming laptops
For New Zealand gamers dealing with varying ambient temperatures depending on season and location, proper cooling becomes even more critical. Consider investing in quality HP accessories such as cooling pads or external fans during summer months, especially if you’re in warmer North Island locations.
Limitations and Considerations
Game Compatibility
Some platforms and certain games support frame generation while others don’t. Without integration by developers, optimal gaming results are not possible.
Visual Artifacts
Blurring can occur in high-intensity games as AI predictions can fall short of reality in some cases.
Less Beneficial Scenarios
High resolutions can lead to unexpected results that might make frame generation reduce frame rates and disrupt gaming smoothness.
Hardware Requirements
Even with the best GPUs, optimal CPU power is necessary for elite gaming performance (especially in GPU-bound scenarios).
Future Compatibility
Hardware with greater capacity and robustness could become the benchmark, provided developer support continues.
Internet Considerations
For New Zealand gamers, especially those in rural areas where internet connectivity may be variable, it’s worth noting that while Multi Frame Generation itself doesn’t require an internet connection to function once set up, initial driver downloads and game updates that implement DLSS support will require reliable internet. Plan your updates during times when you have stable connectivity.
The Future of Frame Generation Technologies
Industry Trajectory and Competitive Landscape
NVIDIA’s DLSS 4 and MFG have rapidly disrupted the gaming experience, challenging competitors to keep pace.
Potential Improvements
AI models need continued refinement to attain higher levels of accuracy, potentially integrating cutting-edge AI techniques for frame generation and game prediction.
AI-driven rendering is gaining momentum among developers, with DLSS 4 currently supported by over 75 games—a trend likely to become the norm.
Impact on Game Development Approaches
Immersive experiences driven by AI optimisation, higher frame rates, and efficient rendering represent the new frontier for gaming development.
Beyond Multi Frame Generation
Future advancements could include entire scripts predicted and generated by AI, potentially making it difficult to differentiate rendered content from generated content.
Conclusion: Is Multi Frame Generation Worth it?
OMEN laptops and desktops offer plug-and-play optimisation with OMEN Gaming Hub alongside the DLSS performance boost. They leverage RTX Series GPUs to enhance gaming performance by utilising DLSS and MFG efficiencies.
Optimised AI models are deployed to predict and generate frames, enhancing visual smoothness and profoundly boosting gaming performance. With NVIDIA Reflex 2 updates, a smoother gaming experience results even in high latency scenarios.
For competitive gamers and enthusiasts seeking the highest performance levels, Multi Frame Generation technology represents a significant advancement that delivers tangible benefits in both visual quality and gameplay responsiveness.
For New Zealand gamers looking to experience this technology firsthand, visit HP’s gaming laptops and gaming desktops pages to explore the latest OMEN products equipped with RTX graphics cards.
Disclosure:
