HP ZBook Power 15.6 inch G8 Mobile Workstation PC
- 11th Generation Intel® Core™ i7 processor
- Windows 10 Pro 64
- 512 GB PCIe® NVMe™ SSD
- 16 GB
- NVIDIA
Free Adobe Substance 3D Collection Plan A (6months)
HP Prelude Pro 15.6 Top Load (1D4F6AV)
HP Laser 3 Button USB Mouse (Y8L10AV)
Overview
Features
Fingerprint reader
Having a fingerprint reader can help to increase the security of your PC and protects your data.
Backlit keyboard
The keys in backlit keyboard are illuminated for ease of viewing in dim or completely dark conditions.
Bluetooth
Bluetooth connection allows you to connect wirelessly to other devices to share and transfer files.
ENERGY STAR® certified
Products with ENERGY STAR labels are more energy efficient than standard products, saving energy and money by at least 30%.
Full HD
Full High Definition (FHD) is a display resolution of 1920 x 1080 pixels.
Solid State Drive (SSD)
SSDs provide a huge performance advantage — they’re faster to start up, faster to shut down, and faster to transfer data.
TECHNICAL DETAILS
Windows 10 Pro 64
Processor
Intel® Core™ i7-11800H (up to 4.6 GHz with Intel® Turbo Boost Technology, 24 MB L3 cache, 8 cores)
Memory
16 GB DDR4-3200 MHz RAM (1 x 16 GB)
- Operating system
- Windows 10 Pro 64
- Processor
- Intel® Core™ i7-11800H (up to 4.6 GHz with Intel® Turbo Boost Technology, 24 MB L3 cache, 8 cores)
- Processor family
- Chipset
- Intel® WM590
- Memory
- 16 GB DDR4-3200 MHz RAM (1 x 16 GB)
- Memory slots
- 2 SODIMM; supports dual channel
- Internal storage
- Storage type
- SSD
- Display
- 39.6 cm (15.6") diagonal, FHD (1920 x 1080), IPS, anti-glare, 400 nits, 100% sRGB
- Graphics
- NVIDIA RTX™️ A2000 (4 GB GDDR6 dedicated)
- I/O Port location
- Left side
- Ports
- 1 RJ-45; 1 SuperSpeed USB Type-A 5Gbps signaling rate; 1 HDMI 2.0; 1 nano security lock slot
- I/O Port location
- Right side
- Ports
- 1 power connector; 1 headphone/microphone combo; 1 Thunderbolt™ 4 with USB4 Type-C® 40Gbps signaling rate (USB Power Delivery, DisplayPort™ 1.4); 2 Super Speed USB Type-A 5Gbps signaling rate (1 charging)
- Expansion slots
- 1 smart card reader
- Audio features
- HP Audio, dual stereo speakers, dual array digital microphones, functions keys for volume up and down, combo microphone/headphone jack, HD audio
- Fingerprread
- Fingerprint reader
- Pointing device
- ClickPad Mylar with multi-touch gesture support, taps enabled as default; Microsoft Precision Touchpad with gesture support
- Keyboard
- HP Premium Quiet Keyboard, spill-resistant, full-size, backlit, keyboard with a Programmable Key and numeric keypad
- Network interface type
- LAN
- Network interface
- Intel® I219-V GbE, non-vPro®
- Wireless
- Intel® Wi-Fi CERTIFIED 6™ AX201 (2x2) and Bluetooth® 5 combo (Supporting Gigabit data rate)
- Power
- 150 W external AC power adapter
- Energy Efficiency Compliance
- ENERGY STAR® certified
- Environmental
- Low halogen
- Dimensions without stand (W x D x H)
- 35.94 x 23.39 x 2.28 cm
- Weight
- Starting at 1.89 kg
- Security management
- Absolute persistence module; HP Device Access Manager; HP Power On Authentication; HP Security Manager; Integrated smart card reader; Master Boot Record security; Pre-boot authentication; HP Sure Click; Windows Defender; HP Secure Erase; HP Manageability Integration Kit; HP Sure Sense; HP Secure Platform; HP Sure Recover Gen3; HP BIOSphere Gen6; HP Sure Start Gen6; HP Sure Run Gen3; HP Tamper Lock; Nano Security Lock Slot; HP Client Security Suite Gen7; Trusted Platform Module TPM 2.0; Windows Secured Core
- Software included
- Bing search for IE11; Buy Office; HP Hotkey Support; HP Performance Advisor; HP Recovery Manager; HP Remote Graphics Software; HP Support Assistant; HP JumpStart; Native Miracast support; HP Connection Optimizer; HP Cloud Recovery; HP Admin; HP Privacy Settings; HP QuickDrop; HP Easy Clean; HP PC Hardware Diagnostics; HP ZCentral Remote Boost 2020 Software for Z workstation; Tile™ Application
- Warranty
- 3 year (3/3/3) limited warranty includes 3 years of parts, labor and on-site repair. Terms and conditions vary by country. Certain restrictions and exclusions apply.
Special offers
Reviews
Add
Product -
Compare nowClear allNo product added to compare list
