Product page placeholder
Use HPTH5 For 5% OFF* Storewide & &
  • CLOUD, getAggregateRating, 499.81ms
HP P204v 19.5-inch HD+ Monitor
In stock
5RD66AA
Business-class affordability in a mainstream screen size
Configuration
  • 19.5" HD+ (1600 x 900 @ 60 Hz)
  • Flat TN with LED backlights
  • 1 HDMI 1.4 (with HDCP support); 1 VGA
  • Tilt Stand, VESA mountable
  • Anti-glare, LED backlights
  • (See more Specifications)
THB 3,890.00 SAVETHB 100 (2%)
THB 3,790.00
You Save: THB 100 (2%)
THB 379.00/m*
  See repayments
Standard Warranty INCLUDED
3 year parts and labour limited warranty.
    Choose Your Option
    hp care pack(0) learn more
  • 3 year parts and labour limited warranty.
Secure, Flexible Payment Options - Learn More
Free & Fast Delivery -  Learn More
HP Advantage – Best prices & services for businesses - Learn More
Shipping Availability
Recommended
Overview
Features
Specs
Offers
Reviews
Ask a Question
Similar Products
Drivers, Manuals & Support
Overview
Get essential presentation features and device connectivity with the stylishly redesigned and surprisingly cost-conscious HP P204v 19.5-inch Monitor.
Crisp image clarity for all your content
Easily navigate your documents and spreadsheets on this sleek display that complements your modern workspace and has a 19.5-inch diagonal screen with 1600 x 900 resolution.
Display and device connectivity
Quickly connect to your devices and additional displays through the HDMI connector. Get legacy device compatibility from the VGA connector.
Create an efficient workspace
Attach your HP Desktop Mini, HP Chromebox or select HP Thin Client directly behind the display.[1] Keep things tidy with an integrated power supply and cable management features.
Place it where you need it
Quickly connect to your devices and additional displays without dongles or adapters through the HDMI and VGA connectors.
Attach your HP PC or select HP Thin Client directly behind the display.[1]
Features
Find your sweet spot
Filter blue light emission and shift colors to a warmer spectrum for more comfortable viewing with HP Low Blue Light mode. Adjust tilt for your best view.
Free up valuable desk space with mounting options enabled by the 100-mm VESA pattern.
Complete the picture
Customize a total solution with options designed for your display, like the HP S100 Speaker Bar, which attaches easily to the lower bezel to add stereo audio without the desktop clutter.
Responsibly made
Energy efficiency and environmental sustainability are built into every ENERGY STAR® and TCO certified, EPEAT® 2019 registered, and low halogen display.
Divide and conquer
Manage your display and make it work for you. HP Display Assistant allows you to quickly resize screen partitions so you can work in separate regions of the screen and helps deter theft by dimming a display that’s disconnected without approval.
We have your back
We’re just a call or click away. Rest assured that your IT investment is supported with our three-year standard limited warranty. To extend your protection, select an optional HP Care service.
Specs
Screen size
19.5-inch
Resolution (native)
HD+ (1600 x 900)
Display type
Response time
5 ms gray to gray
Display Input Type
Display features
Anti-glare; LED backlights
Offers
Special offers
  • Get 5% off with a maximum discount of THB 3,000
  • Use code at checkout to redeem.
  • Promotion ends on 31 December 2024 or while stock last.
SEE MORE
10% off Monitors with a PC purchase*
  • Valid with every PC Purchase
  • Discount is capped at THB300 and will be automatically deducted at checkout.
  • You may add-on purchase-with-purchase items under ""Recommended"" tab or add item to your cart directly.
  • Other terms apply.
SEE MORE
Reviews
  • CLOUD, getReviews, 494.55ms
Ask a Question
Ask a Question
Click here
FEATURES
  • [1] HP Desktop Mini, HP Chromebox, and HP Thin Client sold separately.
  • EPEAT® registered where applicable. EPEAT registration varies by country. See www.epeat.net for registration status by country. See HP’s 3rd party option store for solar energy accessory at www.hp.com/go/options
TECHNICAL DETAILS
  • [1] All specifications represent the typical specifications provided by HP's component manufacturers, actual performance may vary either higher or lower.
  • [2] External power supplies, power cords, cables and peripherals are not Low Halogen. Service parts obtained after purchase may not be Low Halogen.
  • [3] Lock is sold separately.
6627873344
Mon-Fri 9.00am - 6.00pm
6623284555(WhatsApp)
@hpthailand (Line)
