HP ProDisplay P17A 17-inch 5:4 LED Backlit Monitor
- 43.18 cm (17")
- SXGA (1280 x 1024 @ 60 Hz)
- 5 ms on/off
- 5:4
THIS PRODUCT IS DISCONTINUED
Ringkasan
fitur
LED backlighting
Reduced energy consumption, offer better contrast and brightness, and greater color range instead of cold cathode fluorescent (CCFL) backlighting.
Spesifikasi
- Nomor produk
- F4M97AA
- Product color
- Meteorite bezel, black chassis/stand
- Display size (diagonal)
- 43.18 cm (17")
- Aspect ratio
- 5:4
- Resolution (native)
- Resolutions supported
- 1280 x 1024; 1280 x 800; 1280 x 720; 1024 x 768; 800 x 600; 720 x 400; 640 x 480
- Pixel pitch
- 0.264 mm
- Brightness
- 250 cd/m²
- Contrast ratio
- 1000:1 static
- Response time
- 5 ms on/off
- Onscreen controls
- Menu; Minus ("-"); Plus ("+"); Power
- Display features
- Plug and Play; Anti-glare; User programmable; Language selection; On-screen controls; LED Backlights
- Display Input Type
- 1 VGA
- Dimensions without stand (W x D x H)
- 37.72 x 5.7 x 31.66 cm
- Dimensions with stand (W x D x H)
- 37.72 x 20.63 x 38.72 cm
- Berat
- 3.72 kg
- Catu daya
- Input voltage: 100 to 240 VAC
- Power Consumption Description
- 20 W (maximum), 15.2 W (typical), 0.5 W (standby)
- Operating temperature range
- 5 to 35°C
- Energy Efficiency Compliance
- ENERGY STAR® qualified; EPEAT® Gold
- Lingkungan
- Mercury-free display backlights; Arsenic-free display glass; Low halogen; TCO Certified
- Environmental specification footnote number
- [2] External power supplies, power cords, cables and peripherals are not low halogen. Service parts obtained after purchase may not be low halogen.
- Apa yang ada di dalam kotak
- Monitor; VGA cable; AC power cable; Printed documentation and DVD; HP Display Assistant software
- Jaminan
- 3 years parts, labour and on-site limited warranty
- Physical security
- Security Lock-ready
- Aksesoris
- USB Graphics Adapter – dual output C5U89AA; USB Graphics Adapter – single output NL571AA; Single Monitor Arm BT861AA; Speaker Bar NQ576AA; HP LCD Monitor Quick Release EM870AA; HP Business PC Security Lock Kit PV606AA
Special offers
Ulasan
Tambahkan
Produk -
Bandingkan sekarangKosongkan SemuaTidak ada produk yang ditambahkan ke daftar perbandingan
