HP TECH TAKES /...
Best OMEN Settings for VALORANT: Maximum FPS, Low Latency and Pro Precision
Why VALORANT Settings Matter for Competitive Play
FPS Directly Impacts Aim and Reaction Time
Lower Input Lag Means Faster Responses
Visual Clarity Versus Raw Performance
OMEN Hardware Requirements and Performance Expectations
| Hardware Tier | GPU Example | Expected FPS |
Entry Level
GTX 1660 / RTX 3050
144–180 FPS
Mid Range
RTX 4060 / RTX 4060 Ti
200–300+ FPS
High-End
RTX 4080 / 4090 / 50 series
300+ FPS consistent
Complete VALORANT Settings Configuration
| Category | Settings | Reasons |
Display Mode
Fullscreen
Lesser input lag
Resolution
1920×1080 or 2560×1440
Ensured clarity
Limit FPS
Off / Uncapped
Artificial capping can cause a delay
NVIDIA Reflex
On + Boost (if GPU supports it)
Reduces system latency by coordinating CPU and GPU
Multithreaded Rendering
On
Makes use of your entire processor
Material Quality
Medium / Low
Unnecessary details don't impact gameplay
Texture Quality
Medium / Low
Helps with both clarity and performance
Detail Quality
Low
Reduces foliage and unnecessary visual elements
UI Quality
Low
Lower performance cost and a cleaner HUD
Vignette
Off
Reduces peripheral visibility
V-Sync
Off
Prevents input lag
Anti-Aliasing
MSAA 2x
Slight smoothing without performance costs
Anisotropic Filtering
4x
Helps textures
Improve Clarity
Off
Causes FPS spikes
Bloom
Off
Bloom adds glow effects that can mask contrast
Distortion
Off
Avoid warping or visual distortion
Cast Shadows
Off
Merely cosmetics that can affect performance
Audio Settings for Competitive Advantage
- Enable HRTF: This feature enables more precise spatial audio, allowing you to detect footsteps accurately and maintain exceptional directional awareness throughout matches.
- Disable Music and Voicelines: Turn off voiceline and music volumes to eliminate unnecessary distractions during crucial moments.
- Sound Effects: Maximise this setting to catch important in-game audio cues and improve your spatial awareness for tactical advantages.
Graphics and Driver Optimisation
- Power Management: Configure this to maximum performance mode to ensure your GPU never throttles during gameplay.
- Low Latency Mode: Works in conjunction with NVIDIA Reflex, which can be enabled within VALORANT’s settings for reduced system latency.
- Vertical Sync: Keep this disabled to avoid screen tearing and prevent FPS drops that could cost you crucial duels.
- Texture Filtering: Set to high performance to prioritise frame rate over texture quality.
- Radeon Anti-Lag: Enables significantly quicker input responses, crucial for competitive play.
- Radeon Boost: This setting enables dynamic resolution scaling during fast motion, maintaining frame rates during intense firefights.
- Texture Filtering: Configure texture filtering to performance mode for optimal frame rates.
- AMD FreeSync: If your gaming monitor supports it, enable FreeSync for smoother gameplay without V-Sync latency.
System and Performance Optimisation
- Windows Game Mode: Enabling this feature allows Windows to optimise resource management for gaming, reducing background interference.
- Power Plans: Configure Windows power plans to “High Performance” or the equivalent performance-focused plan available on OMEN PCs.
- Monitoring: Utilise OMEN Gaming Hub to track latency and FPS in real-time, allowing you to identify performance issues immediately.
- Background Processes: Close unnecessary background applications such as web browsers, update services, or other programmes that may have launched automatically.
- Windows Updates: Schedule Windows updates during off-peak gaming hours to prevent interruptions during competitive matches.
Network Optimisation
- Wired Connection: Always prefer a wired Ethernet connection over Wi-Fi for consistent low ping and reduced packet loss. This is especially important for UK players connecting to European servers.
- OMEN Network Booster: Use the OMEN Network Booster feature to prioritise VALORANT traffic over other applications and significantly reduce packet loss during matches.
- Router Tweaks: Ensure Quality of Service (QoS) is enabled on your router to prioritise gaming traffic over other household internet usage.
- Server Selection: Connect to the appropriate European servers (typically London or Paris for UK players) for the lowest possible latency.
Audio and Peripheral Settings
- Audio Awareness: A quality headset with surround sound or HRTF support ensures you can pinpoint every footstep and maintain the directional awareness necessary for competitive success. Consider investing in quality audio accessories for optimal performance.
- Mouse DPI: Professional players typically use a DPI range of 800-1600 for optimal aiming precision. The HP 710 Rechargeable Silent Mouse offers programmable buttons and up to 90-day battery life, making it excellent for extended gaming sessions without interruption.
- Mouse Acceleration: Disable mouse acceleration in Windows mouse settings for consistent, predictable tracking across all movements.
- Keybinds: Review and customise your keyboard bindings for maximum comfort and accessibility during intense matches. The HP 350 Compact Multi-Device Bluetooth Keyboard provides excellent tactile feedback whilst maintaining a compact design that doesn’t crowd your gaming space.
- RGB Profiles: Utilise RGB lighting profiles to highlight critical keybinds, making them more visible and easier to locate during clutch situations.
- Gaming Monitor: Invest in a quality gaming monitor with high refresh rates and accurate colour reproduction. The OMEN 27k 4K UHD IPS Gaming Monitor offers 144Hz refresh rates and 1ms response time, perfect for competitive VALORANT play. For those seeking an even more immersive experience, the OMEN 34c WQHD Curved Gaming Monitor provides an ultrawide 1500R curved screen with 165Hz refresh rates.
