Sub Total
Excluding delivery and voucher code discounts.
Go to basket
Free Delivery on all orders to UK mainland within 3 working days.
HP TECH TAKES /...
Exploring today's technology for tomorrow's possibilities
HPImage
HP Smart Tank 5101 All-in-One Printer: A Complete Review
Cameron Cashman
Consumer printers have gotten cheaper and more common over the years, and these days there are two reliable options when it comes to home printers: laser and inkjet. Laser printers utilize a material called toner, which is good for high-volume, black-and-white print jobs.
As the name implies, inkjet printers utilize ink, which is better at printing high-quality, colour material. Consumer Inkjet printers are typically fed ink through cartridges, which can be expensive and will run out quickly when used for high-volume print jobs.
Luckily, there’s a new type of printer that addresses this problem: the ink tank printer.
What are ink tank printers?
HPImage
Ink tank printers use the same inkjet technology found in most traditional consumer ink printers. Ink is heated and liquefied, then transferred to a nozzle, or print head. The print head sprays the ink onto the paper below, recreating the desired text or image. Traditionally, inkjet printers have utilized disposable cartridges, making them perfect for low-to-mid-volume print jobs.
But for frequent printers or high-volume jobs, replacing ink cartridges can quickly become expensive.
That’s why many people are turning to newer ink tank printers to tackle higher volume jobs. Ink tank printers have built-in ink reservoirs that can print hundreds of pages before having to be refilled. Plus, a single refill bottle contains enough ink to last for up to two years, so you’ll be buying them much less frequently than replacement cartridges.
When you do need to purchase refills, you’ll only have to purchase the ink you need: black, cyan, magenta, or yellow.
What’s more, ink tank printers are better for the environment, since ink utilizes small recyclable bottles instead of cartridges.
Aside from this key difference, ink tank printers are comparable to cartridge printers. They offer the same high-quality black and white and colour prints, and all-in-one models can copy and scan documents, as well. Plus, they’re just as fast - if not faster - than cartridge-based inkjet printers.
Who benefits from ink tank printers?
HPImage
With more people working and learning from home than ever before, a reliable home printer has become an essential tool for a wide variety of users: professionals, students, parents, instructors, and everyone in between. And since ink tank printers are just as versatile as their older, tried-and-true cartridge counterparts, you might be wondering if there’s anyone who wouldn’t benefit from an ink tank printer!
The short answer is no - but there are some important things to keep in mind about ink tank printers. They do require a little bit more manual maintenance than cartridge printers: for example, refilling the tanks is a little more involved than simply slotting in a new ink cartridge.
Plus, ink tank printers have to be used frequently or maintained appropriately to prevent the ink from coagulating or the reservoirs from drying out. So, if you’re not printing off hundreds of pages every month, you may be better off with a cartridge printer.
That’s why ink tank printers are better for mid-to-large businesses, libraries, schools, and families who print a lot.
If you’re thinking about picking up a new ink tank printer, you should consider a Smart Tank printer from HP. Our printers are well-known for being versatile and reliable - and the Smart Tank line continues that tradition.
Introducing the HP Smart Tank 5101 All-in-One Printer
With that in mind, the HP Smart Tank 5101 All-in-One printer is a great, affordable option for a wide variety of users and print jobs – thanks in large part to its guided setup and accessibility features.
Get printing fast
HPImage
First thing’s first: system requirements. Nothing too intense here - just an internet connection, a web browser, and 2GB of storage space. The printer is compatible with Windows 7 through 11, macOS 10-12, Android, and iOS.
If you want to get the printer up and running right out of the box, you should consider downloading the HP app and using the guided setup feature. This presents step-by-step animation instructions so you can quickly and easily get started with your printer. Here, you’ll also be able to connect your printer to your various devices via WiFi.
Once it’s set up, the printer’s smart buttons will illuminate to guide you through the printing process every time, making print jobs easy and painless.
Flexible and feature-packed
A lot has already been said about the quality of prints that inkjet-based printers can produce. To help quantify that, let’s look at the resolutions that the HP Smart Tank 5101 is capable of.
A printer’s resolution is measured in dots per inch or DPI. DPI measures the level of detail in printed, scanned, or copied images. When printing, DPI refers to the number of dots of ink that the printer can put onto each square inch of paper. When scanning or copying, DPI refers to the number of dots that the scanner or copier can capture per inch.
In all three cases, a higher DPI means more dots of ink, which translates to a higher-quality image. So, if you want a high-quality print, scan, or copy, you'll want to choose a printer with a high DPI.
Luckily, that’s not a problem with the Smart Tank 5101. It can print black and white pages with a DPI of up to 1200 x 1200, and color pages up to 4800 x 1200 optimized DPI.
Printing on this machine is fast, too: with a black-and-white print speed of 12 pages per minute (ppm) and a speed of 5 ppm for colour prints, you’ll be cranking out high-quality materials in no time at all.
HPImage
Other useful features of the 5101 include enhanced ID copy for accurately scanning and reproducing identification cards, as well as borderless (up to 8.5 x 11 in, 210 x 297 mm) and manual duplex printing.
Like all HP printers, you’ll have full control over a variety of print settings - which can be adjusted via the 1.2-inch LCD display or the HP zpp. The mobile app is highly recommended, because it helps users access advanced smart features that HP has built into the printer.
HP Smart Advance makes it easier to manage print jobs, track ink and paper usage, and scan and share documents. Users can scan and save documents to the cloud or email them directly from the printer, without having to go through a separate scanning process. HP Smart Advance also includes security features like secure boot and firmware integrity checking to protect against attacks and unauthorized access.
An HP printer with HP Smart Advance features offers a range of benefits that can help users be more productive, efficient, and secure in their printing and document management tasks.
Sleek, heavy-duty, and low-maintenance
The HP Smart Tank 5101 comes in a sleek, simple chassis that weighs about 11 lbs with dimensions of about 17 x 14 x 6 inches. It is heavy-duty enough to be sturdy and rugged, but small enough that it should fit on a small-to-medium-sized table in most spaces.
It includes a 100-page input tray, a 30-page output tray, and is compatible with a variety of media types - including plain, matte, and glossy papers, envelopes, and other speciality inkjet papers. The recommended media weight for this printer is 20 lbs, and it supports up to 110-pound cardstock.
When it comes to maintenance, there isn’t a whole lot to worry about thanks to HP ink sensors, self-healing WiFi, and automatic on/off function, which ensures the printer isn’t running when you aren’t using it. When it comes time to refill your ink tanks, you won’t have to worry about spills thanks to HP’s hassle-free bottles and refill system.
Finally, HP includes bottles of ink with the printer that will last up to two years, so you won’t have to worry about getting ink refills for a while!
Summary
Overall, the HP Smart Tank 5101 All-in-One printer continues HP’s long-standing reputation for high-quality, reliable home printers. If you’re ready to upgrade from a traditional cartridge printer to an ink tank printer, you won’t go wrong with the HP Smart Tank 5101.
About the Author
Cameron Cashman is a contributing writer for HP Tech Takes. Cameron is based in New England and has experience writing for a variety of industries, including technology, gaming, finance, HR, and recruiting.
Disclosure: Our site may get a share of revenue from the sale of the products featured on this page.
Disclaimer
HP’s MSRP is subject to discount. HP’s MSRP price is shown as either a stand-alone price or as a strike-through price with a discounted or promotional price also listed. Discounted or promotional pricing is indicated by the presence of an additional higher MSRP strike-through price
The following applies to HP systems with Intel 6th Gen and other future-generation processors on systems shipping with Windows 7, Windows 8, Windows 8.1 or Windows 10 Pro systems downgraded to Windows 7 Professional, Windows 8 Pro, or Windows 8.1: This version of Windows running with the processor or chipsets used in this system has limited support from Microsoft. For more information about Microsoft’s support, please see Microsoft’s Support Lifecycle FAQ at https://support.microsoft.com/lifecycle
Ultrabook, Celeron, Celeron Inside, Core Inside, Intel, Intel Logo, Intel Atom, Intel Atom Inside, Intel Core, Intel Inside, Intel Inside Logo, Intel vPro, Itanium, Itanium Inside, Pentium, Pentium Inside, vPro Inside, Xeon, Xeon Phi, Xeon Inside, and Intel Optane are trademarks of Intel Corporation or its subsidiaries in the U.S. and/or other countries.
Microsoft Windows 10: Not all features are available in all editions or versions of Windows 10. Systems may require upgraded and/or separately purchased hardware, drivers, software or BIOS update to take full advantage of Windows 10 functionality. Windows 10 is automatically updated, which is always enabled. ISP fees may apply and additional requirements may apply over time for updates. See http://www.microsoft.com.
Get Marvel’s Avengers when you purchase HP gaming PCs with qualifying 9th gen or 10th gen Intel® Core™ i5, i7 and i9 processors. Redemption code will be sent out by email within 60 days of purchase. Limited quantities and while supply lasts. Offer valid thru 12/31/2020 only while supplies last. We reserve the right to replace titles in the offer for ones of equal or greater value. Certain titles may not be available to all consumers because of age restrictions. The Offer may be changed, cancelled, or suspended at any time, for any reason, without notice, at Intel’s reasonable discretion if its fairness or integrity affected whether due to human or technical error. The Offer sponsor is Intel Corporation, 2200 Mission College Blvd., Santa Clara, CA 95054, USA. To participate you must create an Intel Digital Hub Account, purchase a qualifying product during the redemption period, enter a valid Master Key, and respond to a brief survey. Information you submit is collected, stored, processed, and used on servers in the USA. For more information on offer details, eligibility, restrictions, and our privacy policy, visit https://softwareoffer.intel.com/offer/20Q3-19/terms.
© 2020 MARVEL. © Intel Corporation. Intel, the Intel logo, and other Intel marks are trademarks of Intel Corporation or its subsidiaries in the U.S. and/or other countries. Other names and brands may be claimed as the property of others.
The personal information you provide will be used according to the HP Privacy Statement (https://www8.hp.com/us/en/privacy/ww-privacy.html)
