Sub Total
Excluding delivery and voucher code discounts.
Go to basket
Free Delivery on all orders to UK mainland within 3 working days.
HP TECH TAKES /...
Exploring today's technology for tomorrow's possibilities
Thermal Architecture in OMEN Systems: Design Principles and Performance Impact
HP OMEN gaming systems are renowned throughout the UK for their advanced thermal architecture, which drives peak performance during extended gaming sessions. For British gamers who demand the very best, the OMEN 45L leads the field with its distinctive and innovative patented cooling technology designed to handle even the most demanding titles.
Gaming is high-performance driven, leading to rapid temperature spikes in systems and devices. Temperature management in gaming prevents overheating, avoids thermal throttling, and maintains high frame rates. There are design safeguards that enable overclocking and ensure smooth, consistent gaming performance. The OMEN 45L CRYO CHAMBER represents the pinnacle of gaming thermal engineering.
In this guide, we take you through the latest innovations in cooling technologies, the excellence of OMEN CRYO CHAMBER, performance optimisation, and cutting-edge insights on the impact of thermal performance on gaming.
Cooling Technologies in OMEN: Air vs Liquid and CRYO CHAMBER Innovations
Several desktops and laptops run on traditional air cooling, which serves to prevent the damaging effects of excessive heating. However, some OEMs prioritise liquid cooling to match the demands of high-performance systems in high-intensity scenarios. Understanding how both cooling systems work will lay a good foundation for understanding our innovative CRYO CHAMBER technology.
Traditional air vs liquid cooling comparison
Air cooling uses conduction and convection to dissipate heat effectively, whilst liquid cooling enhances heat transfer via fluid circulation and phase change.
Presented below are more distinctions:
Talking Points Traditional Air Liquid Cooling
Performance Gains
Cost-effective, reliable, easy to install, sufficient for moderate gaming, low maintenance
Higher efficiency, stable FPS, better overclocking, quieter operation, longer component lifespans
Limitations
Less efficient cooling, louder fans, bulky design, limited overclocking potential
Higher cost, complex installation
When you’re investing in a gaming desktop, understanding these cooling fundamentals helps you make an informed decision about the performance you need.
OMEN’s patented CRYO CHAMBER technology
Revolutionary design principles and engineering innovation
The design features of OMEN CRYO CHAMBER focus on thermal insulation, minimising heat transfer, and selecting low thermal conductivity materials. It is built for structural integrity under cryogenic conditions.
How CRYO CHAMBER surpasses traditional liquid cooling
Advanced vacuum and sealing techniques are used to sustain ultra-low temperatures efficiently. Temperature control is precise and stable, with safety features to handle extreme cold environments.
Performance benefits: temperature reduction and sustained performance
The OMEN 45L CRYO CHAMBER delivers exceptional cooling performance:
  • Reduces CPU temperature by up to 7.5°C
  • Improves sustained gaming performance by preventing thermal throttling
  • This patented system pulls cold ambient air to isolate and cool the CPU cooler
  • Enables stable, long-lasting high performance during intense gaming sessions and heavy workloads
  • Enhances GPU cooling efficiency for overall system thermal management
OMEN Thermal Architecture Comparison
The OMEN thermal architecture across its models offers some unique features that are worth highlighting to suit specific use cases for UK gamers.
Comparative table: OMEN 16L vs 35L vs 45L cooling systems
Model Cooling Type Key Features Thermal Capacity
OMEN 16L
Air Cooling
Optimised airflow, compact design
Mid-range gaming
OMEN 35L
Liquid Cooling
AIO integration, balanced performance
High-performance gaming
OMEN 45L
CRYO CHAMBER
Patented liquid cooling, LCD integration
Extreme gaming performance
Airflow engineering across models
Strategic component placement in CRYO CHAMBERS divides thermal zones to isolate heat-sensitive parts, maintaining optimal temperatures through insulation and staged cooling.
Intake and exhaust placements maximise cooling efficiency and minimise heat buildup, optimising thermal management within the chamber. This engineering approach ensures that whether you’re exploring OMEN gaming laptops or desktop systems, you benefit from HP’s thermal expertise.
OMEN 45L CRYO CHAMBER: Deep Technical Analysis
The patented design of OMEN 45L CRYO CHAMBER improves overclocking, separates heat from other components, and offers easy upgrades, enhancing overall system performance and cooling efficiency.
CRYO CHAMBER has a carrying handle, making it easy to move, hold, adjust, or upgrade as needed. The system supports high-end CPUs and GPUs with solid airflow through RGB fans. It balances powerful cooling with sleek design and user convenience.
Engineering design philosophy
Heat transfer efficiency in CRYO CHAMBERS is enhanced by optimising fin geometry and coating layers, reducing thermal resistance and cryogen consumption. Thermal density management balances heat load, temperature uniformity, and material properties for compact, effective cooling with minimal energy loss.
Component isolation and temperature zone control
Temperature zone control employs independent thermal stages and shielding to maintain precise, stable low temperatures for different chamber parts, effectively enhancing system efficiency and reducing cooldown times.
Performance Impact on Gaming
Performance efficiency is crucial for gaming as it ensures smooth gameplay, reduces heat and power consumption, improves system responsiveness, extends hardware lifespan, enhances competitive advantage, and improves overall user experience.
Preventing thermal throttling during games
There is continuous delivery of cryogenic coolant through throttling devices, ensuring rapid, consistent cooling response. This is particularly important for UK gamers who participate in extended tournaments or streaming sessions.
Maintaining boost clock speeds under maximum load
This happens with cryogenic cooling for thermal stability, reducing heat-induced frequency drops and enabling sustained high-performance processing speeds. When paired with the right gaming monitor, these systems deliver uncompromising performance.
System stability and component longevity benefits
Cryogenic cooling enhances system stability by reducing thermal stress and wear, significantly extending component lifespan. Cryogenic cooling also reduces maintenance frequency, ensuring reliable long-term operation.
Aesthetic and Functional Integration
LCD display integration for real-time monitoring
LCD display integration in CRYO CHAMBERS enables real-time monitoring by showing precise temperature, pressure, and system status. This gives gamers immediate feedback on their system’s thermal performance.
RGB lighting without compromising thermal performance
RGB lighting integration uses low-heat LED technology and careful placement to avoid disrupting thermal pathways, preserving optimal cooling efficiency and performance. The aesthetic appeal doesn’t come at the expense of function.
Advanced Cooling Features and Monitoring in OMEN Systems
Advanced cooling features in OMEN systems include patented CRYO CHAMBER technology that pulls in fresh air to reduce CPU temperatures. They also include Addressable RGB (ARGB) liquid cooling, silent fans, and real-time monitoring for optimal performance and stability.
The CRYO CHAMBER can be upgraded, allowing easy installation of various liquid cooling radiators, future-proofing the system for high-end gaming demands and optimal thermal management. These advanced features ensure stable, efficient performance during intense gaming sessions.
Real-time temperature monitoring and system vitals integration
Systems are optimised for automated alerts, cloud data storage, and analytics for immediate issue detection. They ensure optimal performance, regulatory compliance, and asset protection.
Custom cooling profiles and fan curve optimisation
Cooling intensity is based on thermal load variations, which adaptively maximise efficiency and prolong system life by dynamically balancing cooling capacity with real-time demands.
Performance vs noise balance controls
These are designed to optimise fan speeds and cooling power, reducing noise whilst maintaining efficient thermal management. They ensure quiet operation without sacrificing system performance.
Premium Cooling Features (45L Focus)
LCD liquid cooling system with customisable displays
These systems optimise cooling performance whilst enhancing aesthetic appeal through vibrant, programmable LCD screens integrated with RGB lighting.
Temperature-based RGB colour coding and alerts
This means the RGB LED changes colour based on sensed temperature values, helping to visually indicate temperature levels that trigger alerts.
Proactive thermal management and user notifications
The system uses predictive models and dynamic adjustments, minimising temperature spikes and performance loss whilst enabling timely user alerts to avoid overheating damage.
Thermal Performance Impact on Gaming Excellence
Thermal performance directly impacts gaming excellence by preventing throttling, ensuring stable frame rates, enhancing responsiveness, and enabling sustained high performance.
Sustained performance benefits
Consistent frame rates during extended gaming sessions
Consistent frame rates during extended gaming ensure smooth visuals, reduce lag, and prevent performance drops from overheating. For competitive UK gamers, this consistency can mean the difference between victory and defeat.
CPU and GPU thermal headroom for overclocking
CPU and GPU thermal headroom allows safe overclocking by providing extra cooling capacity to manage increased heat. This is where the CRYO CHAMBER technology truly shines.
Component lifespan extension through optimal temperatures
Lifespan is extended through optimal temperatures by reducing heat stress, slowing degradation, and preventing thermal damage. This represents better value for your investment in gaming accessories and peripherals as well.
Competitive gaming advantages
Elimination of thermal-based performance drops
Elimination of thermal-based performance drops involves advanced cooling techniques, thermal management, and preventing overheating to maintain optimal device performance. This stops thermal throttling that reduces CPU/GPU speed due to heat.
Reliable performance during tournaments and streaming
Demanding scenarios require stable hardware, low latency, efficient cooling, and consistent internet connectivity. The OMEN cooling architecture ensures your system performs reliably when it matters most.
Common Questions About OMEN Cooling Systems
How effective is the CRYO CHAMBER compared to traditional liquid cooling?
The CRYO CHAMBER cools components at lower temperatures more effectively than traditional liquid cooling, offering more efficient and stable thermal management. It can reduce CPU temperatures by up to 7.5°C compared to conventional cooling solutions.
What maintenance is required for the OMEN 45L cooling system?
For OMEN 45L cooling maintenance, regularly clean dust filters and fans. It’s important to replace thermal paste during liquid cooler servicing and ensure proper cable management. The system is designed for easy access and minimal maintenance requirements.
Can the cooling system handle overclocked components?
Yes. It effectively cools overclocked components within safe margins, but pushing significantly beyond stock speeds may cause stability issues. Overall, cooling performance is excellent for typical overclocking needs, providing the thermal headroom enthusiasts require.
Is the CRYO CHAMBER technology available in other OMEN models?
The patented CRYO CHAMBER technology is exclusive to the OMEN 45L, representing the pinnacle of HP’s gaming thermal engineering. Other OMEN models feature advanced liquid and air cooling solutions optimised for their respective performance tiers.
How does ambient temperature affect OMEN cooling performance?
OMEN systems are designed to perform optimally in typical UK room temperatures. The CRYO CHAMBER pulls in ambient air, so cooler room temperatures will enhance overall cooling efficiency, whilst warmer environments may see slightly elevated system temperatures whilst still maintaining excellent performance.
Conclusion and CRYO CHAMBER Innovation Impact
The HP OMEN 45L is built with a patented CRYO CHAMBER for extreme cooling, separating CPU liquid cooling for fresh air intake and lowering temperatures significantly. Its cooling system features a 360mm liquid radiator, excellent airflow with multiple intake and exhaust points, and a modular power supply for reduced heat generation.
The OMEN 45L has efficient fan noise control, extends component lifespan, and supports high performance and overclocking. This design ensures consistent, quiet cooling under sustained loads. Its advanced cooling improves gaming performance by preventing thermal throttling, maintaining high frame rates, and enhancing system reliability through precise temperature control.
For UK gamers seeking the ultimate in thermal performance and gaming excellence, the OMEN range delivers cutting-edge cooling technology that keeps you competitive. Whether you’re a casual gamer or a professional esports athlete, proper thermal management ensures your system performs at its peak when it matters most.
The innovation behind CRYO CHAMBER technology represents HP’s commitment to pushing the boundaries of gaming performance. By addressing the thermal challenges that have traditionally limited gaming systems, OMEN delivers sustained excellence that lets you focus on what matters—winning.
Visit the HP online store to experience the OMEN gaming desktop range today and discover how advanced thermal architecture can transform your gaming experience.
Disclosure: Our site may get a share of revenue from the sale of the products featured on this page.
Disclaimer
HP’s MSRP is subject to discount. HP’s MSRP price is shown as either a stand-alone price or as a strike-through price with a discounted or promotional price also listed. Discounted or promotional pricing is indicated by the presence of an additional higher MSRP strike-through price
The following applies to HP systems with Intel 6th Gen and other future-generation processors on systems shipping with Windows 7, Windows 8, Windows 8.1 or Windows 10 Pro systems downgraded to Windows 7 Professional, Windows 8 Pro, or Windows 8.1: This version of Windows running with the processor or chipsets used in this system has limited support from Microsoft. For more information about Microsoft’s support, please see Microsoft’s Support Lifecycle FAQ at https://support.microsoft.com/lifecycle
Ultrabook, Celeron, Celeron Inside, Core Inside, Intel, Intel Logo, Intel Atom, Intel Atom Inside, Intel Core, Intel Inside, Intel Inside Logo, Intel vPro, Itanium, Itanium Inside, Pentium, Pentium Inside, vPro Inside, Xeon, Xeon Phi, Xeon Inside, and Intel Optane are trademarks of Intel Corporation or its subsidiaries in the U.S. and/or other countries.
Microsoft Windows 10: Not all features are available in all editions or versions of Windows 10. Systems may require upgraded and/or separately purchased hardware, drivers, software or BIOS update to take full advantage of Windows 10 functionality. Windows 10 is automatically updated, which is always enabled. ISP fees may apply and additional requirements may apply over time for updates. See http://www.microsoft.com.
Get Marvel’s Avengers when you purchase HP gaming PCs with qualifying 9th gen or 10th gen Intel® Core™ i5, i7 and i9 processors. Redemption code will be sent out by email within 60 days of purchase. Limited quantities and while supply lasts. Offer valid thru 12/31/2020 only while supplies last. We reserve the right to replace titles in the offer for ones of equal or greater value. Certain titles may not be available to all consumers because of age restrictions. The Offer may be changed, cancelled, or suspended at any time, for any reason, without notice, at Intel’s reasonable discretion if its fairness or integrity affected whether due to human or technical error. The Offer sponsor is Intel Corporation, 2200 Mission College Blvd., Santa Clara, CA 95054, USA. To participate you must create an Intel Digital Hub Account, purchase a qualifying product during the redemption period, enter a valid Master Key, and respond to a brief survey. Information you submit is collected, stored, processed, and used on servers in the USA. For more information on offer details, eligibility, restrictions, and our privacy policy, visit https://softwareoffer.intel.com/offer/20Q3-19/terms.
© 2020 MARVEL. © Intel Corporation. Intel, the Intel logo, and other Intel marks are trademarks of Intel Corporation or its subsidiaries in the U.S. and/or other countries. Other names and brands may be claimed as the property of others.
The personal information you provide will be used according to the HP Privacy Statement (https://www8.hp.com/us/en/privacy/ww-privacy.html)
