As the creative industry continues to flourish across the UK, content creators constantly push their machines to the absolute limit. Whether you’re rendering high-resolution videos in Manchester’s bustling media quarter or designing complex 3D models for London’s gaming studios, having robust memory architecture to support your creativity is essential. But what exactly is memory architecture?
Though it sounds technical, think of memory architecture as your workspace. If your workspace is too small, it quickly becomes cluttered, and finding what you need requires constant reorganisation. The same applies to your computer’s memory—well-designed memory architecture allows your PC to access, process, and store data quickly without lag or bottlenecks.
Why OMEN PC Memory Architecture Stands Out
OMEN PCs are built with efficiency and utility in mind, equipped with low-latency, high-speed RAM configurations that can handle virtually any creative challenge. By designing memory architecture that prioritises efficiency and stable functionality, OMEN machines have become some of the best PCs for video editing and graphic design.
This focus on creative work efficiency means OMEN’s memory architecture can handle large datasets, multitasking, and running multiple virtual machines simultaneously. Your OMEN system can switch between intensive applications flawlessly, allowing your creative process to flow smoothly without performance compromises.
Why Memory Matters
Your computer’s memory performs various critical operations during creative workflows:
Smooth Performance: Enables heavy tasks like 4K video editing and multitasking without stutters or lags
Stability: Ensures your machine doesn’t crash, lag, or slow down during demanding workflows
Responsiveness: Enables quick loading of applications and faster data processing
Future-proofing: Adequate memory ensures your system remains capable as software demands increase
Understanding OMEN’s Memory Architecture
Many people believe more memory automatically means better performance. Whilst partially true, optimal performance requires more sophisticated architecture. Understanding how OMEN’s memory is designed helps explain why these systems deliver exceptional performance without necessarily requiring hundreds of gigabytes of RAM.
Different Models, Different Setups
OMEN offers tailored configurations designed for specific user needs:
High-end Models: Feature faster RAM, larger capacity, and greater upgradability
Entry-level Systems: Prioritise efficiency and utility whilst remaining budget-friendly, making OMEN gaming and content creation accessible without breaking the bank
Types of RAMs in HP OMEN Gaming PCs
OMEN PCs are built with specialised components to ensure maximum performance:
DDR5 & DDR4 RAM: Most OMEN gaming PCs use DDR4 or DDR5 RAM, with newer models featuring DDR5 for higher bandwidth, lower power consumption, and faster speeds
SO-DIMM (Laptops): Smaller memory modules used in laptops, often equipped with dual-channel configurations for better performance
DIMM (Desktops): Standard memory modules used in desktop computers, with OMEN selecting top-tier components for faster speeds, better cooling, and upgradability
ECC vs. Non-ECC: Whilst most OMEN gaming PCs use non-ECC RAM for faster speeds, some workstation builds feature ECC RAM modules for better data accuracy and processing
Memory Terminology Explained
DDR5/DDR4: Double Data Rate memory generations, with DDR5 being newer and faster
Dual/Quad Channel: Multiple memory channels that increase bandwidth and performance
MHz: Megahertz, the measurement of memory speed (higher is better)
CAS Latency: The delay time between the memory controller requesting data and its availability
XMP: Extreme Memory Profile, allowing for simplified memory overclocking
RAM Configurations and Speeds
OMEN PCs offer a range of memory configurations to meet diverse user needs:
Speed Range: From 2666MHz up to 5600MHz, allowing for faster processing and quicker application load times
Capacity Options: Available in 8GB, 16GB, 32GB, and 64GB configurations to suit various needs
Multi-Channel Architecture:
Dual-Channel: Standard in most OMEN models, improving system responsiveness and bandwidth utilisation
Quad-Channel: Available in higher-end models, perfect for intensive creative workloads like 3D modelling or large-scale rendering
Expandable Memory: Upgradeable memory slots for easy capacity and speed increases
Low-Latency Design: Engineered to reduce lag by enhancing response times
XMP Support: Enables easy overclocking and enhanced performance for compatible memory modules
OMEN Gaming Hub Booster Technology
OMEN’s Gaming Hub Booster Technology ties everything together, providing tools for managing memory, lighting, and cooling. The Hub’s performance booster fine-tunes CPU and memory resources, enhancing overall productivity and creative workflow efficiency.
How OMEN’s Memory Architecture Streamlines Creative Processes
Professional creators need systems that can keep pace with demanding workflows without lags or bottlenecks. OMEN’s memory architecture optimises RAM usage to provide seamless creative experiences across various disciplines:
Video Editing Performance
Benefits:
Reduced buffering times with increased memory speeds
Seamless 4K and 8K editing regardless of layer count or effects complexity
Smoother timeline scrubbing and real-time effect previews
Faster export and rendering times
Recommended Configuration:
Entry-level (1080p editing): 16GB DDR4 3200MHz
Professional (4K editing): 32GB DDR5 4800MHz
High-end (8K editing): 64GB DDR5 5600MHz
Best OMEN Desktop for Video Editing
The OMEN 25L GT15-2009na gaming desktop delivers exceptional performance for creative professionals with its NVIDIA GeForce RTX 4070 SUPER graphics card and powerful Intel processor. Experience incredible performance with dazzling graphics that make video editing, rendering, and creative work seamless.
Intel processor for smooth multitasking
NVIDIA GeForce RTX 4070 SUPER for accelerated rendering
Tool-less access to internals for easy upgrades
Full controllable RGB lighting for a professional setup
This desktop’s cutting-edge modern design and upgradeable architecture ensure your creative workstation grows with your needs, whilst the powerful graphics card accelerates video encoding and effects processing.
3D Rendering Capabilities
Benefits:
Faster render times with high bandwidth support
Real-time modelling with reduced lag
Improved viewport performance with complex scenes
Better handling of high-resolution textures and complex geometry
Entry-level: 16GB DDR4 3200MHz
Professional: 32GB DDR5 4800MHz
Production-grade: 64GB+ DDR5 5600MHz
Best OMEN Desktop for 3D Rendering
Built for extreme performance, the OMEN by HP 45L gaming desktop PC is designed for demanding creative workflows from the ground up. Powered by the latest AMD processor, this gaming desktop takes cooling to incredible heights with a unique cooling chamber, perfect for sustained 3D rendering sessions.
Latest AMD processor for multi-threaded rendering performance
Unique cooling chamber design for thermal management
Easy tool-less upgradeability with industry standard components
Designed to meet demanding creative and gaming needs
Created for easy tool-less upgradeability, this desktop ensures you can expand memory and storage as your 3D rendering projects become more complex and demanding.
Graphic Design Enhancement
Benefits:
Quick loading of large Illustrator, CAD, Blender, and Photoshop files
Lag-free processing of complex designs with multiple layers
Smooth handling of high-resolution assets
Responsive brush and tool performance
Pro Tip: Memory Allocation for Creatives
For optimal performance in creative applications, aim to keep your memory usage below 80% of total capacity. When memory usage exceeds this threshold, consider closing unnecessary applications or upgrading your RAM. Monitor memory usage through OMEN Gaming Hub or Windows Task Manager during resource-intensive tasks.
Gaming Performance: The Other Side of OMEN’s Memory Architecture
Whilst creativity is crucial, OMEN systems are also designed for exceptional gaming performance. The same memory architecture that powers creative workflows delivers lag-free, high-frame-rate gaming experiences:
Gaming Benefits
Streaming Optimisation: OMEN systems are designed to handle gaming whilst simultaneously streaming to platforms like Twitch, YouTube, or Facebook Gaming
Triple-A Title Performance: Fast memory allows for quick texture loading, improved open-world performance, and reduced lag
Background Task Management: Run Discord, music players, and other utilities without impacting game performance
Get one machine to do it all with the Victus by HP gaming desktop. This powerful system features an AMD processor and impressive NVIDIA GeForce RTX 4060 Ti graphics, perfect for gaming whilst streaming or creating content. Seamlessly switch between gaming, streaming, and creative work.
Powerful AMD processor for multitasking performance
NVIDIA GeForce RTX 4060 Ti graphics for smooth gaming
Latest Windows 11 OS with Bluetooth connectivity
9 USB ports and plenty of storage for all your needs
Plus, control RGB lighting and other performance features with the OMEN Gaming Hub, making it perfect for content creators who game and gamers who create.
Software-Specific Performance Improvements
OMEN’s memory architecture significantly enhances performance across popular creative applications:
3D Modelling Software
Blender: Enhanced viewport performance and faster simulation calculations
AutoCAD: Smoother navigation of complex drawings and faster regeneration times
Maya: Improved animation preview and scene manipulation
Video Editing Applications
Adobe Premiere Pro: Faster timeline scrubbing and real-time playback
DaVinci Resolve: Improved colour grading performance and render speeds
Final Cut Pro: Enhanced proxy workflows and background rendering
Benchmarks & Performance Metrics
Tests show that upgrading from 16GB DDR4 to 32GB DDR5 memory in OMEN systems yields:
Up to 30% faster render times in Adobe Premiere Pro
Up to 25% improvement in Blender viewport performance
Up to 40% reduction in load times for complex Photoshop projects
Up to 20% improvement in gaming frame rates at 4K resolution
Choosing the Right OMEN PC for your Creative Needs
With several OMEN models available, selecting the right system depends on your specific creative requirements and budget considerations.
High-Performance Creative Workstation
Look good and play even better with the OMEN by HP 25L desktop PC featuring NVIDIA GeForce RTX 4060 Ti graphics. Experience incredible performance with an Intel processor and dazzling graphics perfect for creative work and gaming.
Intel processor for reliable creative performance
NVIDIA GeForce RTX 4060 Ti for accelerated workflows
Cutting-edge modern design with controllable RGB lighting
Tailor this PC to your liking with tool-less access to internals and easy upgradability, ensuring your creative workstation evolves with your growing needs.
Budget-Friendly Creative Option
Get one machine to do it all with the Victus by HP 15L desktop gaming PC. This system offers excellent value with a powerful AMD processor and NVIDIA GeForce GTX 1660 SUPER graphics, making creative work accessible without breaking the bank.
Powerful AMD processor for creative applications
NVIDIA GeForce GTX 1660 SUPER graphics for solid performance
Latest Windows 11 OS with extensive connectivity
OMEN Gaming Hub for performance optimisation
Seamlessly switch between creative work, gaming, and streaming with this versatile desktop that provides professional capabilities at an accessible price point.
Future-Proofing your Creative Workstation
Upgrade Paths
All OMEN systems are designed with future upgradability in mind:
Accessible memory slots for easy RAM upgrades
Support for the latest memory standards
BIOS updates to enable compatibility with new memory modules
Tool-less access for simplified component upgrades
Memory Trends for Creatives
As creative applications grow more demanding, memory requirements continue to evolve:
DDR5 speeds are expected to reach 7200MHz+ in coming generations
Increased adoption of content requiring 8K resolution and beyond
AI-assisted creative tools demanding more system memory
Real-time ray tracing requiring additional VRAM and system RAM
Complementary Hardware Considerations
Beyond memory, consider these components for a complete creative workstation:
Storage: Fast NVMe SSDs for project files and scratch disks
Graphics: Dedicated GPUs with ample VRAM for rendering and effects
Monitors: Colour-accurate displays for precise creative work
Accessories: Professional keyboards, mice, and drawing tablets
Maintaining Peak Performance
Memory Optimisation Tips
Close unnecessary background applications during intensive creative work
Use OMEN Gaming Hub to monitor and optimise memory usage
Regularly update drivers and software for optimal compatibility
Consider memory overclocking for additional performance gains
System Maintenance
Keep your OMEN system updated with the latest BIOS versions
Monitor temperatures during extended creative sessions
Clean dust from cooling systems to maintain performance
Use quality power supplies to ensure system stability
Conclusion
As digitalisation transforms the creative landscape throughout the UK, OMEN systems provide the perfect balance of work efficiency and entertainment capabilities. Equipped with exceptional memory architecture, OMEN PCs deliver smooth and seamless performance across different creative applications whilst offering clear upgrade paths as technology advances.
OMEN’s commitment to incorporating cutting-edge memory technology ensures these systems will remain the right choice for creative professionals for years to come. Whether you’re editing high-resolution video, rendering complex 3D models, or designing intricate graphics, OMEN’s memory architecture provides the foundation for your creative success.
The combination of powerful processors, advanced graphics cards, and optimised memory configurations makes OMEN desktops ideal for the demanding workflows of today’s creative professionals. With tool-less upgradability and comprehensive software support, these systems grow with your creative ambitions.
To explore the complete range of OMEN and gaming desktop systems optimised for creative work, browse our selection of high-performance desktops designed to power your creative vision.
HP’s MSRP is subject to discount. HP’s MSRP price is shown as either a stand-alone price or as a strike-through price with a discounted or promotional price also listed. Discounted or promotional pricing is indicated by the presence of an additional higher MSRP strike-through price
The following applies to HP systems with Intel 6th Gen and other future-generation processors on systems shipping with Windows 7, Windows 8, Windows 8.1 or Windows 10 Pro systems downgraded to Windows 7 Professional, Windows 8 Pro, or Windows 8.1: This version of Windows running with the processor or chipsets used in this system has limited support from Microsoft. For more information about Microsoft’s support, please see Microsoft’s Support Lifecycle FAQ at https://support.microsoft.com/lifecycle
Ultrabook, Celeron, Celeron Inside, Core Inside, Intel, Intel Logo, Intel Atom, Intel Atom Inside, Intel Core, Intel Inside, Intel Inside Logo, Intel vPro, Itanium, Itanium Inside, Pentium, Pentium Inside, vPro Inside, Xeon, Xeon Phi, Xeon Inside, and Intel Optane are trademarks of Intel Corporation or its subsidiaries in the U.S. and/or other countries.
Microsoft Windows 10: Not all features are available in all editions or versions of Windows 10. Systems may require upgraded and/or separately purchased hardware, drivers, software or BIOS update to take full advantage of Windows 10 functionality. Windows 10 is automatically updated, which is always enabled. ISP fees may apply and additional requirements may apply over time for updates. See http://www.microsoft.com.
Get Marvel’s Avengers when you purchase HP gaming PCs with qualifying 9th gen or 10th gen Intel® Core™ i5, i7 and i9 processors. Redemption code will be sent out by email within 60 days of purchase. Limited quantities and while supply lasts. Offer valid thru 12/31/2020 only while supplies last. We reserve the right to replace titles in the offer for ones of equal or greater value. Certain titles may not be available to all consumers because of age restrictions. The Offer may be changed, cancelled, or suspended at any time, for any reason, without notice, at Intel’s reasonable discretion if its fairness or integrity affected whether due to human or technical error. The Offer sponsor is Intel Corporation, 2200 Mission College Blvd., Santa Clara, CA 95054, USA. To participate you must create an Intel Digital Hub Account, purchase a qualifying product during the redemption period, enter a valid Master Key, and respond to a brief survey. Information you submit is collected, stored, processed, and used on servers in the USA. For more information on offer details, eligibility, restrictions, and our privacy policy, visit https://softwareoffer.intel.com/offer/20Q3-19/terms.
