Sub Total
Excluding delivery and voucher code discounts.
Go to basket
Free Delivery on all orders to UK mainland within 3 working days.
HP Tech@Work
Today's trends for tomorrow's business
HPImage
What To Do When You’ve Lost Your HyperX Wireless Dongle
Victoria Okonkwo
Losing the wireless dongle for your HyperX headset, mouse, or keyboard can be incredibly frustrating, especially when you depend on these devices for gaming, work, or content creation. This small but essential component enables the wireless functionality that makes HyperX peripherals so convenient. For UK-based users, misplacing this tiny device between sofa cushions or during your commute can disrupt your entire setup. Don’t worry – this guide will walk you through finding it, exploring temporary alternatives, and securing a replacement.
Why Dongles Go Missing: Common Loss Scenarios
The compact size of HyperX wireless dongles makes them particularly prone to being misplaced. Understanding where they commonly disappear can help in both locating a missing dongle and preventing future losses:
  • Cluttered workspaces: Small dongles easily vanish under papers, cables, or other desk accessories
  • Household interference: Pets or children might pick up and relocate the dongle
  • Accidental disposal: The tiny size makes dongles vulnerable to being mistakenly thrown away
  • Unnoticed drops: The dongle might slip out while handling multiple devices
  • Travel incidents: Commuters and frequent travellers risk dongles falling out of bags on trains, buses or being left behind in hotel rooms
  • Moving between work and home setups: Many UK professionals now split their time between multiple locations, increasing the risk of misplacing small accessories
First Steps: Finding Your Missing Dongle
If you realise your HyperX wireless dongle is nowhere to be found, follow these systematic steps before seeking a replacement:
  1. Search your immediate surroundings: Check your desk, under furniture, and between cushions
  2. Retrace your recent activities: Think about when you last used the device and search those locations
  3. Ask household members: Someone else might have moved the dongle or noticed where it is
  4. Check all USB ports: Confirm the dongle isn’t still plugged into your computer or other devices
  5. Search travel bags thoroughly: If you recently travelled, check all compartments of your luggage
  6. Look in coat pockets and drawers: These are common places where small items end up forgotten
Temporary Connection Solutions
While searching for your dongle or waiting for a replacement, you can keep your device functional with these alternative connection methods:
Wired Connection Options
Many HyperX wireless devices can function in wired mode:
  • Most HyperX wireless peripherals include compatible USB-C or micro-USB cables
  • Simply connecting this cable typically restores full functionality
  • No additional setup is usually required
Advantages of wired connections:
  • Complete stability without wireless interference
  • Zero latency – crucial for competitive gaming
  • No battery drain as power comes directly from your computer
Limitations to consider:
  • Restricted movement and flexibility
  • Cable management challenges
  • Not supported by all wireless models
Bluetooth Connectivity
Bluetooth connections are an effective alternative for wireless devices, but it depends on whether your device supports it.
Split image showing a white HyperX wireless mouse next to a laptop keyboard on the left, and a hand holding a USB dongle next to black HyperX wireless headphones with purple lighting on the right
Several HyperX devices offer Bluetooth as a secondary connection option:
  • Check your specific model’s documentation to confirm Bluetooth compatibility
  • Pair through your computer or console’s standard Bluetooth menu
  • No specialised hardware required
Advantages of Bluetooth:
  • Maintains wireless functionality without a dongle
  • Compatible with multiple platforms (PC, console, mobile)
  • Simple setup process
Limitations to be aware of:
  • Higher latency compared to the dedicated 2.4GHz dongle connection
  • Increased battery consumption
  • Potential audio quality reduction for headsets
  • Limited support for advanced features
Other Temporary Alternatives
If neither wired nor Bluetooth options work for your device:
  • Universal USB Bluetooth adapters can provide basic wireless connectivity
  • USB receivers from similar models might offer limited compatibility in some cases
  • Third-party software solutions may enable functionality for certain devices
For temporary connectivity solutions, you might consider using the HP USB-C Travel Hub G2 to organize your connections and ensure stable wired connectivity for your devices.
Performance Considerations with Alternative Connections
While temporary solutions can keep you connected, they typically involve performance trade-offs:
  • Increased input lag affecting gaming responsiveness
  • Lower polling rates for mice and keyboards
  • Potential audio compression in headsets
  • Reduced microphone quality
  • Faster battery drain
  • Limited wireless range
  • Restricted access to advanced features
Dongles are specifically designed to provide low-latency, high-quality connections – alternatives rarely match this optimised performance.
Securing a Replacement Dongle
The most reliable long-term solution is obtaining an official replacement from HyperX:
Contacting HyperX Support
  • Visit the official HyperX website
  • Click “Contact Support” in the top navigation
  • Choose between phone support or live chat
UK customers can also explore HyperX accessories available through the HP Store for compatible gaming peripherals.
What You’ll Need
  • Proof of purchase: Have your receipt or invoice ready for verification
  • Device information: Know your specific HyperX model number
  • Warranty status: Check if your device is still under warranty coverage
Important Considerations
  • HyperX typically does not sell dongles as standalone purchases
  • Warranty terms vary by region, so check policies applicable to the UK
  • You may qualify for a free replacement if your device is still under warranty
  • Support representatives can suggest alternatives if replacements aren’t available
If you’re looking for a new wireless mouse while waiting for your replacement dongle, consider the HP 430 Multi-Device Wireless Mouse, which features connectivity with up to two devices and exceptional battery life.
Pairing a New Dongle with Your Device
Once you receive a replacement dongle, follow these steps to pair it with your HyperX device:
  1. Connect the USB adapter to your system (PC or console)
  2. Activate pairing mode by inserting a small pin into the reset hole on the adapter and holding for 5 seconds until the LED flashes rapidly
  3. With your device powered off, press and hold the power button for 6-7 seconds (continue holding after it powers on)
  4. Wait for automatic connection – the USB adapter LED will change from flashing to solid when successfully paired
Preventing Future Dongle Loss
Implement these practical strategies to avoid losing your dongle again:
  • Keep it plugged in whenever possible rather than removing after each use
  • Double-check before leaving public spaces like cafés or co-working areas
  • Develop a checklist habit for essential items including your dongle
  • Apply visual indicators such as bright-coloured tape to make the dongle more noticeable
  • Use built-in storage slots that come with many HyperX wireless devices
  • Store with similar items in a dedicated tech pouch alongside other small accessories
For secure storage and organization of your gaming accessories, the HP Renew Recycled Travel Bag offers a sustainable option with multiple compartments that can help keep your small peripherals organized and secure.
Frequently Asked Questions
How do I pair a new USB adapter with my headset?
Follow the three-step process:
  1. Plug the USB adapter into your system
  2. Reset the adapter by pushing a pin into the reset hole for 5 seconds until the LED flashes rapidly
  3. With the headset powered off, hold the power button for 6-7 seconds until it enters pairing mode and connects automatically
Are there any gaming mice that don’t require dongles?
Yes! For those tired of dongles altogether, consider the HP 410 Slim Silver Bluetooth Mouse with strong Bluetooth® 5 connectivity that eliminates the need for a dongle.
What should I do if my HyperX dongle is lost during travel in the UK?
If you’ve lost your dongle while travelling around the UK, check with lost property services at train stations, airports, or hotels. In the meantime, consider using a compact travel accessory like the HP Travel USB-C Multi Port Hub for wired connections when away from home.
By understanding the common causes of dongle loss, exploring temporary connectivity options, and knowing how to secure a replacement, you can quickly recover from this common frustration and get back to enjoying your HyperX wireless device at its full potential.
About the Author
Victoria Okonkwo is a seasoned writer with experience in writing on diverse industries including e-commerce, finance, and technology.
Disclosure: Our site may get a share of revenue from the sale of the products featured on this page.
Disclaimer
HP’s MSRP is subject to discount. HP’s MSRP price is shown as either a stand-alone price or as a strike-through price with a discounted or promotional price also listed. Discounted or promotional pricing is indicated by the presence of an additional higher MSRP strike-through price
The following applies to HP systems with Intel 6th Gen and other future-generation processors on systems shipping with Windows 7, Windows 8, Windows 8.1 or Windows 10 Pro systems downgraded to Windows 7 Professional, Windows 8 Pro, or Windows 8.1: This version of Windows running with the processor or chipsets used in this system has limited support from Microsoft. For more information about Microsoft’s support, please see Microsoft’s Support Lifecycle FAQ at https://support.microsoft.com/lifecycle
Ultrabook, Celeron, Celeron Inside, Core Inside, Intel, Intel Logo, Intel Atom, Intel Atom Inside, Intel Core, Intel Inside, Intel Inside Logo, Intel vPro, Itanium, Itanium Inside, Pentium, Pentium Inside, vPro Inside, Xeon, Xeon Phi, Xeon Inside, and Intel Optane are trademarks of Intel Corporation or its subsidiaries in the U.S. and/or other countries.
Microsoft Windows 10: Not all features are available in all editions or versions of Windows 10. Systems may require upgraded and/or separately purchased hardware, drivers, software or BIOS update to take full advantage of Windows 10 functionality. Windows 10 is automatically updated, which is always enabled. ISP fees may apply and additional requirements may apply over time for updates. See http://www.microsoft.com.
Get Marvel’s Avengers when you purchase HP gaming PCs with qualifying 9th gen or 10th gen Intel® Core™ i5, i7 and i9 processors. Redemption code will be sent out by email within 60 days of purchase. Limited quantities and while supply lasts. Offer valid thru 12/31/2020 only while supplies last. We reserve the right to replace titles in the offer for ones of equal or greater value. Certain titles may not be available to all consumers because of age restrictions. The Offer may be changed, cancelled, or suspended at any time, for any reason, without notice, at Intel’s reasonable discretion if its fairness or integrity affected whether due to human or technical error. The Offer sponsor is Intel Corporation, 2200 Mission College Blvd., Santa Clara, CA 95054, USA. To participate you must create an Intel Digital Hub Account, purchase a qualifying product during the redemption period, enter a valid Master Key, and respond to a brief survey. Information you submit is collected, stored, processed, and used on servers in the USA. For more information on offer details, eligibility, restrictions, and our privacy policy, visit https://softwareoffer.intel.com/offer/20Q3-19/terms.
© 2020 MARVEL. © Intel Corporation. Intel, the Intel logo, and other Intel marks are trademarks of Intel Corporation or its subsidiaries in the U.S. and/or other countries. Other names and brands may be claimed as the property of others.
The personal information you provide will be used according to the HP Privacy Statement (https://www8.hp.com/us/en/privacy/ww-privacy.html)
