Sub Total
Excluding delivery and voucher code discounts.
Go to basket
Free Delivery on all orders to UK mainland within 3 working days.
HP TECH TAKES /...
Exploring today's technology for tomorrow's possibilities
omen hub
Welcome file Welcome file HyperX NGenuity vs OMEN Hub: Complete Guide to Accessory and System Syncing
With countless apps, drivers, and tools available today, choosing the right gaming software can feel overwhelming. As a gamer in the UK, it’s not always clear which platform manages your HyperX accessories and which one takes care of OMEN system syncing.
That’s where HyperX NGenuity and the OMEN Hub come in. HyperX NGenuity gives you full control over your gear, allowing you to customise RGB lighting, adjust performance settings, and create profiles that suit your playstyle. On the other hand, OMEN Hub focuses on the bigger picture: system syncing, performance monitoring, and overall PC optimisation.
In this comprehensive guide, we’ll break down HyperX NGenuity vs OMEN Gaming Hub in detail. You’ll discover how each platform works, where their strengths lie, and how they can complement each other to give you an incredible gaming experience.
What is HyperX NGenuity?
HyperX NGenuity is software designed to give you full control over your HyperX accessories. It allows you to adjust performance, customise RGB lighting, and create personalised profiles that fit your style.
Although we’ve built it for gamers, NGenuity is flexible enough for creators and everyday PC users. Whether you’re competing in esports or simply enjoying your favourite titles, this software adapts to your needs.
Compatible HyperX devices
It works smoothly with most of our HyperX products such as HyperX headsets, keyboards, mice, and microphones.
It also works with select HP and OMEN devices with RGB lighting support, creating a unified ecosystem across your entire setup.
It supports RGB lighting synchronisation across multiple devices, enabling you to create a consistent look and feel for your gaming station.
We are continuously expanding compatibility to help you manage more HyperX products in one place, ensuring your investment remains future-proof.
Key features and capabilities
  • Create and apply custom RGB lighting effects that match your gaming aesthetic
  • Adjust DPI levels and fine-tune audio profiles for competitive advantage
  • Save multiple profiles for different games or workflows
  • Integrates smoothly with HP OMEN Gaming Hub for full-system control
  • Cloud sync capability to access your profiles from anywhere
System requirements
To use NGenuity, you will need a PC running Windows 10 or Windows 11.
A stable internet connection for downloading the latest updates and for enabling cloud profile syncing.
The software is lightweight, meaning that it installs quickly and runs without slowing down your system, even during intense gaming sessions.
What is OMEN Gaming Hub?
OMEN Gaming Hub is an all-in-one dashboard for gamers. It brings your HP devices and accessories together in one place, making it easier to manage how everything looks and performs.
Whether you’re adjusting system performance, customising lighting, or syncing devices, OMEN Hub will adapt to your needs. This makes it perfect for casual gaming as well as competitive play. The intuitive interface ensures that even newcomers to PC gaming can navigate the features with ease.
Compatible OMEN devices and systems
It works smoothly with OMEN laptops, desktops, and gaming monitors.
It is also compatible with select HyperX peripherals, making your setup feel more connected across brands.
Additionally, most HP Victus laptops and devices support the Hub, meaning you can still enjoy the features even if you are not using OMEN hardware exclusively.
Core features and tools
With the OMEN Gaming Hub settings, you can:
  • Monitor system vitals in real time for optimal performance
  • Use Network Booster to reduce lag during online matches
  • Overclock supported devices for extra power when you need it most
  • Sync RGB lighting across OMEN and HyperX gear
  • Launch and manage your games from one centralised location
  • Adjust fan speeds, macros, and system settings to prevent thermal throttling
  • Track gaming statistics and session history
System requirements for OMEN Gaming Hub
The OMEN Gaming Hub works if you have:
  • Windows 10 or Windows 11
  • The latest version of the app (free on Microsoft Store)
  • An OMEN or Victus device for full access to advanced features like overclocking and lighting control
Feature Comparison: HyperX NGenuity vs OMEN Hub
Understanding the specific capabilities of each platform helps you make informed decisions about your gaming setup. Let’s examine the key differences in detail.
RGB lighting customisation
HyperX NGenuity gives you detailed lighting control for each device. You can create effects, sync patterns, and fine-tune colours for HyperX keyboards, mice, and headsets. The granular control extends to individual LED zones, allowing for complex lighting designs.
OMEN Hub includes basic lighting options for supported devices. If you want more advanced effects, you can add OMEN Light Studio.
Through this tool, you can layer effects, create complex animations, and sync lighting across multiple devices. The visual editor makes it simple to preview changes before applying them.
Macro programming capabilities
HyperX NGenuity supports advanced macro programming. You can remap keys, set up custom shortcuts, adjust DPI, and save multiple profiles for different games. The macro recorder captures your input sequences with millisecond precision.
OMEN Hub does not focus on macros. Instead, it offers lighting and system performance features, meaning customisation for key inputs is limited. However, basic key remapping is available for OMEN keyboards.
Performance monitoring tools
The OMEN Hub features built-in tools that allow you to monitor your CPU, GPU, and memory usage in real time. This is especially helpful if you would like to track the performance of your system during intense gameplay. Temperature monitoring helps prevent overheating and thermal throttling.
We’ve designed NGenuity for peripherals, meaning it focuses purely on customising your HyperX gear. It doesn’t include system-level monitoring, keeping the software lightweight and efficient.
Game library integration
NGenuity does not include a game library since it focuses purely on device customisation and not game management.
OMEN Hub features a game library that organises all your installed titles in one place, allowing you to launch them easily. The library automatically detects games from multiple platforms, including Steam, Epic Games Store, and EA.
Price and value proposition
Both NGenuity and OMEN Hub are free to use, meaning your choice shouldn’t be based on cost but value. If you only use HyperX gear, NGenuity alone gives you everything you need.
However, if you have invested in the full OMEN ecosystem, OMEN Hub provides a more comprehensive experience. The integrated approach saves time and simplifies your workflow.
User interface comparison
HyperX NGenuity has a clean and easy-to-navigate interface. The minimalist design prioritises essential functions without overwhelming users. This interface can feel a bit limited, especially if you want more advanced features.
On the other hand, the OMEN Hub uses a more feature-rich dashboard, giving you a wider range of options. You can switch between system monitoring, lighting, and optimisation tools. Although it is powerful, it can be a bit complex for new users.
Device Compatibility and Ecosystem Lock-in
When building a gaming setup, most people only focus on choosing the most powerful gear. However, that’s not enough, because you will also need to consider how well all these pieces work together. This is what is referred to as a gaming ecosystem.
With OMEN Gaming Hub and HyperX NGenuity, we have designed a unified system to help you sync up your hardware and software perfectly as follows.
HyperX device compatibility
HyperX NGenuity works best with HyperX accessories such as keyboards, mice, headsets, and memory modules. With this software, you can customise RGB lighting, create macros, and adjust performance settings.
However, it will only work if you have HyperX products. If you try to connect devices from other brands, features such as lighting sync or macro controls may not work. The software identifies devices through specific hardware IDs unique to HyperX products.
OMEN device compatibility
OMEN Hub is designed to work smoothly with OMEN laptops, desktops, and select peripherals. It offers customisable RGB lighting, system syncing, performance monitoring, and quick access to system settings.
Just like NGenuity, OMEN Hub works best when you stay within HP’s OMEN ecosystem. Using non-OMEN devices may work for basic functions, but advanced features won’t work. The deep integration with OMEN hardware enables unique capabilities like hardware-level overclocking.
Cross-brand functionality limitations
Before you buy new gear, it is important to note that neither NGenuity nor OMEN Hub fully supports devices from other brands. You might be able to connect a third-party device, but advanced customisation, synchronised lighting, or macro programming won’t work.
Some gamers use both HyperX gear and an OMEN system. In this case, you might end up using both tools together: NGenuity for fine-tuning peripherals and OMEN Hub for managing the performance of your PC. Running both applications simultaneously requires minimal system resources.
Performance Optimisation Features
OMEN Hub performance control
Allows you to adjust CPU, GPU, and fan speeds instantly through intuitive sliders.
Use it for monitoring system performance through its clear graphs and real-time statistics.
Prevents overheating whilst keeping your PC running smoothly during marathon gaming sessions.
The performance profiles automatically adjust based on the application you’re running, ensuring optimal balance between power and efficiency.
NGenuity game-specific profiles
Allows you to create custom profiles for each game or app with unique settings.
Automatically adjusts lighting, macros, and key functions when you launch specific games.
Helps optimise HyperX accessories for smooth gameplay without extra effort.
Profile switching happens instantly, with no perceptible lag or delay.
System resource usage
OMEN Hub is a comprehensive tool that monitors your CPU, GPU, and RAM. As a result, it uses more system resources compared to NGenuity.
HyperX NGenuity is lightweight and focuses on managing peripheral or accessory settings, typically using less than 100 MB of RAM.
Choose OMEN for full PC customisation and NGenuity for efficient accessory management. The difference in resource usage becomes more noticeable on systems with limited RAM.
Background process management
The OMEN Gaming Hub has a core background service that runs continuously to enable its features. However, this can sometimes affect the performance of other apps, particularly on systems with limited resources.
NGenuity runs quietly in the background to keep devices synced efficiently, with minimal impact on gaming performance.
Both help your system stay smooth, but OMEN offers more granular controls for advanced users who want complete oversight of their system.
Tips on How to Get the Best From Your Choice
Best practices for optimisation
Firmware updates – Always keep your device firmware and the software itself updated. These updates typically include performance improvements, bug fixes, and new features. Enable automatic updates to ensure you never miss critical improvements.
Limit background applications – Closing programmes you’re not using helps free up system resources. It also makes syncing smoother. Use Task Manager to identify resource-heavy applications that may interfere with gaming performance.
Create profiles – Create different profiles for your favourite games. This will ensure that lighting, macros, and performance settings load automatically when you launch them. Consider creating separate profiles for work, streaming, and competitive gaming.
Lighting control – Whilst RGB lighting looks brilliant, it can use system resources. If you are a competitive gamer who prioritises performance, consider less intensive lighting effects or even turning them off. Alternatively, if you want to create the perfect mood for your gaming session, sync your lights across all your devices to achieve a consistent look.
Macro and key binding – Use macros to automate repetitive actions. A macro is a sequence of commands or keystrokes that can be executed with a single button press. This is a huge time-saver in games and can also be useful for daily tasks. Test your macros in practice mode before using them in competitive matches.
Common troubleshooting tips
If a device isn’t detected, unplug it and reconnect. If that doesn’t work, try a different USB port. USB 3.0 ports typically provide better power delivery for gaming peripherals.
Restart the software if it feels slow or unresponsive. This refreshes the connection with your devices. Also, overly complex lighting effects or too many active profiles can cause the system to be slow. Simplifying your setup can resolve performance issues.
Double-check compatibility – Some devices work best with NGenuity, whilst others integrate better with OMEN Hub. Consult the product specifications before purchasing new peripherals.
If issues persist, you may need to reinstall the software. This helps clear up syncing or setup errors. Before reinstalling, back up your profiles to avoid losing custom configurations.
Check for Windows updates – Sometimes compatibility issues arise from outdated Windows versions. Ensure your operating system is current to avoid conflicts with gaming software.
Advanced customisation options
Dynamic lighting effects - Both platforms allow you to create dynamic lighting effects that react to your game, audio or even system temperatures. For example, your keyboard could flash red when your PC’s CPU gets too hot, providing a visual warning before thermal throttling occurs.
Integration with other apps - OMEN Gaming Hub in particular integrates with services like Twitch and Spotify. This allows you to control these apps from your hardware. You could set up a key to mute your mic on a stream or skip a song without leaving your game. This seamless integration improves workflow efficiency during streaming sessions.
System and performance monitoring - OMEN Gaming Hub has a feature called System Vitals. This feature allows you to monitor your CPU, GPU and RAM usage instantly. You can even set up notifications to alert you if a component gets too hot. Historical data tracking lets you identify performance trends over time.
Profile automation - Both platforms support automatic profile switching based on the active application. Create a silent profile for video calls, a high-performance profile for gaming, and a work profile for productivity tasks. The software detects application launches and switches profiles accordingly.
Cloud synchronisation - Save your profiles to the cloud and access them from any compatible device. This feature is particularly useful for gamers who use multiple PCs or frequently reinstall Windows. Your custom configurations remain accessible regardless of hardware changes.
Advanced Tips for Power Users
Optimising network performance with OMEN Hub
The Network Booster feature in OMEN Hub prioritises gaming traffic over other network activities. This reduces latency and improves responsiveness during online matches. Configure the priority list to ensure your favourite games receive maximum bandwidth.
For competitive gamers, even small reductions in ping can provide a significant advantage. Monitor your network performance through OMEN Hub’s diagnostic tools to identify bottlenecks or connectivity issues.
Creating complex lighting sequences in NGenuity
Advanced users can create intricate lighting patterns that respond to in-game events. Use the effect layering system to combine multiple animations for unique visual displays. The timeline editor provides frame-by-frame control over lighting transitions.
Experiment with colour theory to create aesthetically pleasing combinations that enhance your gaming environment without causing distraction during gameplay.
System overclocking with OMEN Hub
For users with compatible hardware, OMEN Hub enables safe overclocking of CPU and GPU components. The guided overclocking wizard prevents excessive settings that could damage hardware. Monitor temperatures closely and stress-test your system after applying overclock profiles.
Remember that overclocking increases power consumption and heat generation. Ensure your cooling solution can handle the additional thermal load before pushing components beyond stock settings.
Frequently Asked Questions
Can I use both NGenuity and OMEN Hub simultaneously?
Yes, both applications can run together without conflicts. NGenuity manages your HyperX peripherals whilst OMEN Hub controls system-level features and OMEN hardware. The combined approach provides comprehensive control over your entire gaming setup.
Do I need an OMEN PC to use OMEN Hub?
Whilst OMEN Hub offers full functionality on OMEN and Victus systems, some features work with other HP desktops and laptops. However, advanced capabilities like overclocking and hardware monitoring require compatible OMEN components.
How much storage space do these applications require?
HyperX NGenuity requires approximately 200-300 MB of storage space, whilst OMEN Hub needs around 500-800 MB. Both applications install quickly on modern SSDs and have minimal impact on overall system performance.
Can I transfer my profiles to a new PC?
Yes, both applications support profile export and import functions. Additionally, cloud synchronisation in NGenuity automatically backs up your settings. Simply log in with your account on the new system to access your profiles.
Choosing the Right Software for Your Needs
The decision between HyperX NGenuity and OMEN Hub ultimately depends on your specific hardware and priorities. If you’ve invested primarily in HyperX accessories, NGenuity provides everything needed for peripheral customisation.
For users with OMEN desktops or laptops, OMEN Hub delivers comprehensive system management alongside peripheral control. The integrated approach simplifies your gaming experience by consolidating features in one place.
Many UK gamers find that using both applications together creates the ultimate gaming environment. NGenuity handles detailed peripheral customisation whilst OMEN Hub manages system performance and monitoring.
Conclusion
Both HyperX NGenuity and OMEN Hub do a brilliant job, though they work in different ways. NGenuity is all about customising your gaming accessories, from RGB lighting to game profiles. OMEN Hub, on the other hand, gives you broader system control, like performance tuning and syncing across HP devices.
The choice between these platforms isn’t about which is better, but rather which suits your hardware and priorities. NGenuity excels at peripheral customisation with its intuitive interface and powerful macro programming. OMEN Hub provides comprehensive system management with real-time monitoring and performance optimisation.
For the best experience, consider your entire gaming ecosystem. If you’re building a new setup, explore our range of gaming desktops, gaming laptops, and HyperX accessories designed to work seamlessly together.
Would you like to test them out? Download HyperX NGenuity or HP OMEN Gaming Hub and see which one transforms your gaming experience. Both applications are free, allowing you to explore their features without financial commitment. Your perfect gaming setup awaits.
Disclosure: Our site may get a share of revenue from the sale of the products featured on this page.
Disclaimer
HP’s MSRP is subject to discount. HP’s MSRP price is shown as either a stand-alone price or as a strike-through price with a discounted or promotional price also listed. Discounted or promotional pricing is indicated by the presence of an additional higher MSRP strike-through price
The following applies to HP systems with Intel 6th Gen and other future-generation processors on systems shipping with Windows 7, Windows 8, Windows 8.1 or Windows 10 Pro systems downgraded to Windows 7 Professional, Windows 8 Pro, or Windows 8.1: This version of Windows running with the processor or chipsets used in this system has limited support from Microsoft. For more information about Microsoft’s support, please see Microsoft’s Support Lifecycle FAQ at https://support.microsoft.com/lifecycle
Ultrabook, Celeron, Celeron Inside, Core Inside, Intel, Intel Logo, Intel Atom, Intel Atom Inside, Intel Core, Intel Inside, Intel Inside Logo, Intel vPro, Itanium, Itanium Inside, Pentium, Pentium Inside, vPro Inside, Xeon, Xeon Phi, Xeon Inside, and Intel Optane are trademarks of Intel Corporation or its subsidiaries in the U.S. and/or other countries.
Microsoft Windows 10: Not all features are available in all editions or versions of Windows 10. Systems may require upgraded and/or separately purchased hardware, drivers, software or BIOS update to take full advantage of Windows 10 functionality. Windows 10 is automatically updated, which is always enabled. ISP fees may apply and additional requirements may apply over time for updates. See http://www.microsoft.com.
Get Marvel’s Avengers when you purchase HP gaming PCs with qualifying 9th gen or 10th gen Intel® Core™ i5, i7 and i9 processors. Redemption code will be sent out by email within 60 days of purchase. Limited quantities and while supply lasts. Offer valid thru 12/31/2020 only while supplies last. We reserve the right to replace titles in the offer for ones of equal or greater value. Certain titles may not be available to all consumers because of age restrictions. The Offer may be changed, cancelled, or suspended at any time, for any reason, without notice, at Intel’s reasonable discretion if its fairness or integrity affected whether due to human or technical error. The Offer sponsor is Intel Corporation, 2200 Mission College Blvd., Santa Clara, CA 95054, USA. To participate you must create an Intel Digital Hub Account, purchase a qualifying product during the redemption period, enter a valid Master Key, and respond to a brief survey. Information you submit is collected, stored, processed, and used on servers in the USA. For more information on offer details, eligibility, restrictions, and our privacy policy, visit https://softwareoffer.intel.com/offer/20Q3-19/terms.
© 2020 MARVEL. © Intel Corporation. Intel, the Intel logo, and other Intel marks are trademarks of Intel Corporation or its subsidiaries in the U.S. and/or other countries. Other names and brands may be claimed as the property of others.
The personal information you provide will be used according to the HP Privacy Statement (https://www8.hp.com/us/en/privacy/ww-privacy.html)
