Sub Total
Excluding delivery and voucher code discounts.
Go to basket
Free Delivery on all orders to UK mainland within 3 working days.
HP TECH TAKES /...
Exploring today's technology for tomorrow's possibilities
HP LaserJet multifunction printer placed on a modern white desk with office supplies and paper stack, ideal for small business or home office use.
Troubleshooting Tips: Why Your HP Printer Won't Connect to a New Wi-Fi Network
Emma Williams
Connecting your HP printer to a new Wi-Fi network can sometimes feel like an uphill battle, especially when nothing seems to work as expected. Various factors from incorrect network credentials to outdated firmware or even incompatible security settings can prevent your printer from establishing a stable connection. This comprehensive guide will walk you through systematic troubleshooting steps to help you identify and resolve the issue efficiently. By following these detailed tips, you can restore connectivity and get back to enjoying seamless, wireless printing.
Understanding the Problem
Before diving into the troubleshooting steps, it’s important to understand that your HP printer relies on several layers of communication to connect to a wireless network. These include:
  • Network Credentials: The correct Wi-Fi name (SSID) and password are required for authentication.
  • Internal Settings: Printer network settings and stored configurations can sometimes interfere with new network connections.
  • Firmware and Software: Outdated firmware or printer software can lead to compatibility issues with modern network protocols.
  • Router Settings: Your router’s configuration, such as frequency bands or security protocols, might not be fully compatible with your printer.
With these factors in mind, let’s explore the step-by-step troubleshooting process.
Verify Network Credentials
One of the most common causes of connectivity issues is incorrect network credentials. Even a minor typographical error in the SSID or password can block your printer from joining the network.
Double-Check SSID and Password:
  • Ensure you have entered the exact network name and password. Keep in mind that both are case-sensitive.
Find Network Details:
  • If you’re uncertain about your network credentials, refer to the information provided on your router. This information is often printed on a label on the back or bottom of the router, or you can access it via the router’s admin interface.
Re-enter Information Carefully:
  • When setting up the printer’s connection, retype the credentials rather than relying on auto-fill options, as this minimises the risk of errors.
Taking the time to verify the correct network details is a simple yet essential first step in resolving connection issues.
Restore Network Settings on the Printer
Old network configurations can sometimes persist in your printer’s memory and interfere with connecting to a new network. Resetting the network settings can clear these outdated configurations.
Access the Control Panel:
  • On your printer’s control panel, navigate to the Wireless or Setup menu.
Find Network Setup:
  • Look for options labelled “Network Setup,” “Wireless Setup,” or “Settings.”
Reset or Restore Network Settings:
  • Choose the option to “Restore Network Settings” or “Reset Network Settings.” This action will clear all previously saved network data, allowing you to start fresh.
Consult the Manual:
  • Since the menu options can vary by model, refer to your printer’s user manual for precise instructions on how to perform a network reset.
Restoring your network settings is a straightforward process that often resolves conflicts arising from residual configurations.
Reconnect the Printer to the Wi-Fi Network
After resetting the network settings, it’s time to reconnect your printer to the desired Wi-Fi network.
Initiate the Wireless Setup Wizard:
  • Access the Wireless Setup Wizard from your printer’s control panel. This tool will scan for available networks in your vicinity.
Select Your Network:
  • From the list of detected networks, choose your Wi-Fi network (SSID).
Enter the Correct Password:
  • Carefully enter the network password, ensuring that it matches exactly what you verified earlier.
Complete the Setup:
  • Follow the on-screen prompts to finish the connection process. Once completed, your printer should attempt to join the network.
Re-establishing the connection using the setup wizard often resolves connectivity issues if the problem was simply due to incorrect initial settings.
Check for USB Connections
Sometimes, a direct USB connection between your printer and computer can override or interfere with wireless setup processes.
Disconnect Any USB Cables:
  • If your printer is connected to your computer via USB, disconnect the cable before setting up the wireless connection.
Ensure Wireless Priority:
  • Without a wired connection, the printer will prioritise establishing a connection with your Wi-Fi network.
Removing the USB connection can eliminate conflicts that might prevent the printer from switching to wireless mode.
Restart Your Devices
A simple yet highly effective step in troubleshooting network issues is to restart all involved devices. Power cycling (restarting) can resolve many temporary glitches.
Turn Off Devices:
  • Power down your printer, router, and computer.
Wait Briefly:
  • Allow the devices to remain off for about 60 seconds. This pause helps clear any lingering issues.
Restart the Router First:
  • Turn on your router and wait until it has fully restarted and established a stable connection.
Turn on the Printer and Computer:
  • Finally, power up your printer and computer. This sequence ensures that the router assigns a fresh IP address to the printer, facilitating smoother communication.
Restarting devices is a basic step that can resolve issues caused by temporary glitches or IP address conflicts.
Use the HP Print and Scan Doctor
HP offers a specialised diagnostic tool called the HP Print and Scan Doctor. This free utility is designed to detect and fix many common printer connectivity issues automatically.
Download and Install:
Run the Diagnostic:
  • Open the programme and select your printer from the list of devices. Follow the on-screen instructions to start the diagnostic process.
Follow Recommendations:
  • The tool will identify potential issues and provide step-by-step guidance on how to resolve them.
Using the HP Print and Scan Doctor can simplify the troubleshooting process, especially if the problem is complex or not immediately apparent.
Update Printer Firmware
Outdated firmware can hinder your printer’s ability to connect to modern networks. Updating the firmware can improve compatibility and overall performance.
Visit the HP Support Website:
  • Navigate to the support section and enter your printer model to find available firmware updates.
Download the Latest Firmware:
  • Follow the instructions provided on the site to download the latest firmware version for your printer.
Install the Update:
  • Carefully follow the installation instructions. Make sure your printer remains powered on during the update process.
Updating firmware not only fixes connectivity issues but also enhances printer functionality and security.
Verify Router Settings
Sometimes, the issue lies not with the printer but with your router’s settings. Checking these settings can ensure compatibility.
Check Frequency Bands:
  • Many HP printers are designed to work on the 2.4 GHz band rather than the 5 GHz band. Ensure your router is broadcasting a 2.4 GHz signal.
Disable MAC Address Filtering:
  • If your router uses MAC address filtering, it might block your printer. Temporarily disable this feature to see if it resolves the connectivity issue.
Update Router Firmware:
  • Outdated router firmware can lead to compatibility problems. Visit your router manufacturer’s website to check for and install any available updates.
Verifying and adjusting router settings can often resolve connectivity issues that prevent your printer from joining the network.
Reinstall Printer Software
Corrupted or outdated printer software on your computer can also prevent successful network connections.
Uninstall Existing Software:
  • Remove the current printer software from your computer.
Download the Latest Version:
  • Visit the HP Support website to download the most recent version of the software for your printer model.
Reinstall and Set Up:
  • Follow the installation prompts, ensuring you select the wireless connection option during setup.
Reinstalling printer software ensures that your computer and printer communicate effectively, eliminating issues caused by outdated or corrupted files.
Ensure Compatibility with Network Security Settings
Modern routers use advanced security protocols like WPA3, which some older printers may not support.
Verify Security Protocols:
  • Check the security settings on your router. If your printer does not support the latest protocols, adjust the settings to a compatible mode, such as WPA2.
Caution with Security Changes:
  • Modifying router security settings can affect overall network safety. Always balance compatibility needs with maintaining robust security measures.
Ensuring that your printer’s capabilities match your router’s security settings is vital for establishing a reliable connection.
Seek Professional Assistance
If you have tried all the above steps and your HP printer still won’t connect to the new Wi-Fi network, it may be time to seek professional help.
Contact HP Support:
  • Reach out to HP’s customer support for personalised guidance tailored to your printer model and network configuration.
Consult Your Internet Service Provider (ISP):
  • Sometimes, router-specific issues might require the attention of your ISP, especially if firmware updates or configuration changes are needed.
Local Technician:
  • In persistent cases, a local technician can provide on-site troubleshooting to diagnose and resolve the problem.
Professional assistance can help identify issues that may be beyond standard troubleshooting steps.
Conclusion
Troubleshooting Wi-Fi connectivity issues with your HP printer may seem daunting, but a systematic, step-by-step approach can help you resolve most problems effectively. By verifying network credentials, restoring network settings on your printer, and reconnecting to your Wi-Fi network, you can eliminate many common causes of connection failures. Additionally, steps like disconnecting USB cables, restarting devices, and using tools like the HP Print and Scan Doctor are simple yet powerful methods to restore connectivity.
Updating your printer firmware, verifying router settings, and reinstalling printer software further ensure that your device is operating with the latest technology and is fully compatible with your network. Finally, ensuring that your printer’s security protocols match your router’s settings and, if necessary, seeking professional assistance can help resolve stubborn issues.
By following these troubleshooting tips, you’ll be well-equipped to diagnose and fix why your HP printer won’t connect to a new Wi-Fi network.
Explore more resources from HP Support and take advantage of the tools and expertise available to you. With the right approach, you’ll soon be back to enjoying seamless printing and the benefits of a well-connected device.
About the Author
Emma Williams is a creative writer with a strong passion for digital marketing and content creation. With a background in AI technology, she writes informative and engaging blog posts for HP Tech Takes.
Disclosure: Our site may get a share of revenue from the sale of the products featured on this page.
Disclaimer
HP’s MSRP is subject to discount. HP’s MSRP price is shown as either a stand-alone price or as a strike-through price with a discounted or promotional price also listed. Discounted or promotional pricing is indicated by the presence of an additional higher MSRP strike-through price
The following applies to HP systems with Intel 6th Gen and other future-generation processors on systems shipping with Windows 7, Windows 8, Windows 8.1 or Windows 10 Pro systems downgraded to Windows 7 Professional, Windows 8 Pro, or Windows 8.1: This version of Windows running with the processor or chipsets used in this system has limited support from Microsoft. For more information about Microsoft’s support, please see Microsoft’s Support Lifecycle FAQ at https://support.microsoft.com/lifecycle
Ultrabook, Celeron, Celeron Inside, Core Inside, Intel, Intel Logo, Intel Atom, Intel Atom Inside, Intel Core, Intel Inside, Intel Inside Logo, Intel vPro, Itanium, Itanium Inside, Pentium, Pentium Inside, vPro Inside, Xeon, Xeon Phi, Xeon Inside, and Intel Optane are trademarks of Intel Corporation or its subsidiaries in the U.S. and/or other countries.
Microsoft Windows 10: Not all features are available in all editions or versions of Windows 10. Systems may require upgraded and/or separately purchased hardware, drivers, software or BIOS update to take full advantage of Windows 10 functionality. Windows 10 is automatically updated, which is always enabled. ISP fees may apply and additional requirements may apply over time for updates. See http://www.microsoft.com.
Get Marvel’s Avengers when you purchase HP gaming PCs with qualifying 9th gen or 10th gen Intel® Core™ i5, i7 and i9 processors. Redemption code will be sent out by email within 60 days of purchase. Limited quantities and while supply lasts. Offer valid thru 12/31/2020 only while supplies last. We reserve the right to replace titles in the offer for ones of equal or greater value. Certain titles may not be available to all consumers because of age restrictions. The Offer may be changed, cancelled, or suspended at any time, for any reason, without notice, at Intel’s reasonable discretion if its fairness or integrity affected whether due to human or technical error. The Offer sponsor is Intel Corporation, 2200 Mission College Blvd., Santa Clara, CA 95054, USA. To participate you must create an Intel Digital Hub Account, purchase a qualifying product during the redemption period, enter a valid Master Key, and respond to a brief survey. Information you submit is collected, stored, processed, and used on servers in the USA. For more information on offer details, eligibility, restrictions, and our privacy policy, visit https://softwareoffer.intel.com/offer/20Q3-19/terms.
© 2020 MARVEL. © Intel Corporation. Intel, the Intel logo, and other Intel marks are trademarks of Intel Corporation or its subsidiaries in the U.S. and/or other countries. Other names and brands may be claimed as the property of others.
The personal information you provide will be used according to the HP Privacy Statement (https://www8.hp.com/us/en/privacy/ww-privacy.html)
