Sub Total
Excluding delivery and voucher code discounts.
Go to basket
Free Delivery on all orders to UK mainland within 3 working days.
HP TECH TAKES /...
Exploring today's technology for tomorrow's possibilities
HPImage
HP Device Not Charging? Complete Troubleshooting Guide
Ant Koksal
This comprehensive guide covers seven proven solutions to fix charging issues with HP laptops and wireless accessories. Most problems can be resolved in under 15 minutes using these DIY methods.
HP portable devices make our lives easier, but for that to happen, their batteries need to be fully charged and working smoothly. Whether you use an HP laptop or any type of HP wireless accessory, charging problems can complicate both your daily and professional life across the UK. What makes this issue particularly frustrating is that there are many possible causes: from a faulty battery to a loose power cable, many things can lead to HP device charging problems.
This HP wireless accessory and laptop charging troubleshooting guide will help you identify the most common causes of HP laptop not charging problems, apply DIY solutions for HP device charging issues, determine when to seek professional help if your HP laptop battery is not charging, and contact HP customer support for charging-related problems.
Quick Diagnosis: Identifying Your Charging Problem
HP laptops usually take between 1.5 and 2.5 hours to reach 100% charge. However, sometimes due to hardware, software, or user error, it may not be possible to charge your battery. To answer the question “Why is my laptop not charging?”, you need to follow certain steps, the first of which is a visual inspection.
Most common causes include faulty power adapter accounting for 40% of cases, damaged charging cable representing 30% of cases, battery degradation causing 20% of cases, and software or driver issues making up 10% of cases.
Safety Considerations Before Troubleshooting
During both the visual inspection and the other steps explained below, make sure your device is unplugged and turned off. This is necessary for your safety and is especially important if you are trying to fix laptop power adapter problems. If you are unsure of what you are doing or are concerned about damaging your device, it is best to seek professional help.
Step 1: Visual Inspection (Takes 2 Minutes)
Visual inspection is the first and most important step in diagnosing charging problems.
Check Power Connections
Check whether the charger is plugged into both the device and the power outlet. Start at the outlet and follow the cable to the device. At the same time, examine the power cable and make sure there are no breaks or unusual bends.
When you reach the device, check that the cable is plugged into the correct port. You may have plugged it into the wrong USB-C port. Some HP laptop models have two USB-C ports, one for data transfer and the other for charging. If the charger cable is plugged into the data transfer port, your device will not charge. Also, it would be a good idea to try plugging the power cord into a different outlet before continuing.
Step 2: Hard Reset (Takes 3 Minutes)
This fixes 60% of HP laptop charging issues and should be your first troubleshooting step after visual inspection.
Complete Hard Reset Procedure
Shut down your HP laptop and unplug it from the power outlet. Disconnect all nonessential devices such as USB flash drives or external hard drives connected to your HP laptop. Remove the AC adapter from your laptop and press and hold the power button on the device for approximately 25 seconds.
Reconnect the AC adapter to your device and turn on the computer. Check to see if the problem has been resolved. If the hard reset hasn’t resolved the issue, it’s time to start performing software and hardware checks.
Step 3: Battery Health Diagnostics (Takes 5-10 Minutes)
You can perform battery health diagnostics in two different ways, both providing valuable insights into your battery’s condition.
Method 1: Windows Built-in Battery Report
Click the Windows Start button, find the Command Prompt option, right-click it, and select Run as Administrator. Type the following in the window that opens and click the Enter button: powercfg /batteryreport. The report prepared about your battery will be saved in the User folder.
By opening the report, you can see the current status of your battery compared to its design capacity. This will give you a good idea of whether it is time to replace the battery. For example, if its capacity has fallen below 50%, you should consider replacing it.
Method 2: HP Battery Health Check Utility
HP provides additional battery diagnostic tools through their support software that can give you more detailed information about your battery’s condition and performance metrics.
Step 4: Port Cleaning & Connection Fixes (Takes 3-5 Minutes)
Connection issues are often overlooked but can be the root cause of charging problems.
Try Alternative Charging Methods
Try charging your HP laptop using a method other than the AC adapter. You can use a power bank, or even a phone charger in some cases. Test with a different charging cable if available to rule out cable-related issues.
Inspect and Clean Charging Port
Examine your device’s charging port and check for any problems. For example, it may be damaged or something may be stuck inside it. Use a soft, dry cloth to clean the charging contacts and make sure the charging points are completely dry before reconnecting the cable.
Power Adapter Verification
Make sure you are using the correct power adapter. If the problem is with the adapter, you can simply order a new one from HP Laptop Accessories. Using an incompatible adapter can prevent proper charging and may damage your device.
Step 5: Software & Driver Updates (Takes 5-10 Minutes)
Before attempting advanced solutions, it is a good idea to check if there is an update for the operating system’s battery drivers and power management.
Update Battery Drivers
Right-click on the Windows Start button and select Device Manager. Find the Batteries option on the screen that opens and right-click on the hardware listed as Microsoft ACPI Compliant Control Method Battery. Click on Update Driver.
If a new driver is available, Microsoft Windows will automatically download and install it. Restart your computer and see if the problem persists. Additional driver updates to consider include power management drivers, chipset drivers, and BIOS updates for advanced users only.
HP Wireless Accessories Charging Issues
If you are experiencing charging issues with an HP wireless accessory, the solutions you should try will vary depending on the type of accessory.
HP Wireless Headphones Charging Solutions
A wired headphone does not need to be charged. If you are using a wireless headphone, first check the charging cable and make sure that there is no problem with the cable and that it is plugged into the correct port.
Try plugging the wireless headphone’s charging cable into a different port on your device. For example, if you have two USB-C ports, you can try the cable in both of them. Clean the charging points on your headphones using a soft, dry cloth and before reconnecting the charging cable, make sure these points are dry.
Check for firmware updates for your specific headphone model and test with a different charging cable if available. Verify the headphones are properly seated in their charging case if applicable.
HP Mouse and Keyboard Charging Troubleshooting
Most HP wireless keyboards and mice use external batteries and do not need to be charged. For example, some HP wireless keyboards run on AAA batteries, and if it is not working, it may simply be because the batteries are dead: installing new AAA batteries will quickly resolve the issue.
For rechargeable HP peripherals, try plugging the charging cable into a different port on your device. Clean the charging points as explained above and check the charging indicator lights to verify charging status. Test with a different USB cable if your device supports it and verify power management settings aren’t interfering with charging.
USB Receiver and Connectivity Issues
Sometimes, the problem is not related to charging: your HP accessory may appear to be malfunctioning due to connection issues, even though it is charging. Be sure to check the USB or Bluetooth dongle that enables the accessory to communicate wirelessly with your computer, and try plugging it into different ports. Also, check for driver updates for your accessory through the official HP Software and Drivers website.
Additional connectivity troubleshooting includes trying to pair the device again if using Bluetooth, checking for interference from other wireless devices, verifying the accessory is within proper range of the receiver, and resetting the accessory according to manufacturer instructions.
Advanced Troubleshooting: Battery Replacement
If your HP laptop not charging problem is caused by your battery rather than the power cable, replacing it may solve the problem.
User-Replaceable Battery (External Battery Models)
To replace a user-accessible battery, you should purchase an HP replacement battery and make sure it is compatible with your device. Turn off your HP laptop and unplug it from the power outlet, then turn your HP laptop upside down and remove the back panel.
Remove your current battery and carefully disconnect it from the motherboard. Insert the new battery in place of the old one and connect it to the motherboard. Reattach the back panel and turn on your laptop. Keep in mind that laptop battery replacement by user is only available for HP laptops that do not have an internal battery.
Internal Battery Replacement
If your battery is internal, you cannot replace it yourself: this must be done by a professional HP technician. Attempting to replace an internal battery can void your warranty and potentially damage your device.
Signs you need professional battery replacement include battery capacity below 50% of original, rapid battery drain, battery not holding charge, physical swelling or damage to battery, and overheating during charging.
When to Contact HP Customer Support & Warranty Coverage
If none of the suggestions we have shared here have worked and you have an internal battery that needs to be replaced, it is time to seek professional help.
HP Warranty Coverage Details
The HP standard warranty is valid for one to three years unless you have purchased a care pack or extended warranty, and covers all parts of your computer and accessories, including your battery. However, please note that accidental damage, user error, hardware wear and tear, unauthorised repairs and replacements are not covered by the warranty.
You can use the HP Warranty Check Tool to check the current status of your warranty.
When Professional Help is Needed
Professional help is needed when all DIY solutions have failed, internal battery replacement is required, hardware damage is suspected, device is still under warranty, you’re uncomfortable performing troubleshooting steps, or the problem involves multiple components.
Getting Warranty Service
If your warranty is still valid and your battery is covered, it may be possible to have it repaired or replaced free of charge at your nearest HP Authorised Service Centre.
What to bring to service includes proof of purchase, device serial number, detailed description of the problem, and list of troubleshooting steps already attempted.
Preventive Maintenance Tips: Extend Battery Life
Remember that you can extend the life of your battery and make it work more efficiently with a few simple precautions and settings.
Power Management Settings
Set the Power Option to Power Saver or HP Recommended and reduce screen brightness whilst minimising the number of open applications. Disable unnecessary startup programmes and turn off Wi-Fi and Bluetooth when not in use. Use sleep mode instead of leaving laptop on to conserve battery power.
Physical Care and Environment
Consider using a cooling pad to prevent overheating and keep your laptop in a cool, dry environment. Avoid extreme temperatures both hot and cold and don’t leave your laptop in direct sunlight. Store in a well-ventilated area to maintain optimal performance.
Battery Charging Best Practices
Try to keep the battery level between 20% and 80% and avoid letting the battery completely drain regularly. Don’t keep the laptop plugged in 24 hours a day and perform a full discharge and charge cycle monthly. Unplug the charger when battery reaches 100% to prevent overcharging.
Regular Maintenance
Clean vents and fans regularly to prevent overheating and update drivers and BIOS regularly for optimal performance. Run battery health checks monthly and keep your operating system updated. Use genuine HP accessories and chargers to ensure compatibility and safety.
Quick Reference: Complete Troubleshooting Checklist
Follow this checklist in order for best results. Safety first: unplug and turn off device. Visual inspection: check cables, ports, and connections taking two minutes. Hard reset: power button hold for 25 seconds taking three minutes.
Port cleaning: clean charging contacts taking three to five minutes. Driver updates: update battery and power drivers taking five to 10 minutes. Alternative charging: try different cables and adapters. Professional help: contact HP support if issues persist.
Most HP laptop charging issues resolve within 15 minutes using these methods. Complex hardware problems may require professional diagnosis and repair.
HP Customer Support Is Ready to Help You
If you are experiencing a charging problem with your HP laptop or accessory, start with a visual inspection of the power cable, continue with a hard reset, and use tools that diagnose battery health. Check for software and driver updates, clean the charging points, and make sure the problem is not caused by the connection.
If the problem persists despite all these steps, contact official HP Customer Support: you can count on them to help you. To benefit from HP warranty for a longer period of time, consider purchasing a care pack or extended warranty.
Contact options include HP Online Support for chat and email assistance, HP Phone Support for direct technical help, HP Authorised Service Centres for in-person repairs, and HP Community Forums for peer support and solutions.
Disclosure: Our site may get a share of revenue from the sale of the products featured on this page.
Disclaimer
HP’s MSRP is subject to discount. HP’s MSRP price is shown as either a stand-alone price or as a strike-through price with a discounted or promotional price also listed. Discounted or promotional pricing is indicated by the presence of an additional higher MSRP strike-through price
The following applies to HP systems with Intel 6th Gen and other future-generation processors on systems shipping with Windows 7, Windows 8, Windows 8.1 or Windows 10 Pro systems downgraded to Windows 7 Professional, Windows 8 Pro, or Windows 8.1: This version of Windows running with the processor or chipsets used in this system has limited support from Microsoft. For more information about Microsoft’s support, please see Microsoft’s Support Lifecycle FAQ at https://support.microsoft.com/lifecycle
Ultrabook, Celeron, Celeron Inside, Core Inside, Intel, Intel Logo, Intel Atom, Intel Atom Inside, Intel Core, Intel Inside, Intel Inside Logo, Intel vPro, Itanium, Itanium Inside, Pentium, Pentium Inside, vPro Inside, Xeon, Xeon Phi, Xeon Inside, and Intel Optane are trademarks of Intel Corporation or its subsidiaries in the U.S. and/or other countries.
Microsoft Windows 10: Not all features are available in all editions or versions of Windows 10. Systems may require upgraded and/or separately purchased hardware, drivers, software or BIOS update to take full advantage of Windows 10 functionality. Windows 10 is automatically updated, which is always enabled. ISP fees may apply and additional requirements may apply over time for updates. See http://www.microsoft.com.
Get Marvel’s Avengers when you purchase HP gaming PCs with qualifying 9th gen or 10th gen Intel® Core™ i5, i7 and i9 processors. Redemption code will be sent out by email within 60 days of purchase. Limited quantities and while supply lasts. Offer valid thru 12/31/2020 only while supplies last. We reserve the right to replace titles in the offer for ones of equal or greater value. Certain titles may not be available to all consumers because of age restrictions. The Offer may be changed, cancelled, or suspended at any time, for any reason, without notice, at Intel’s reasonable discretion if its fairness or integrity affected whether due to human or technical error. The Offer sponsor is Intel Corporation, 2200 Mission College Blvd., Santa Clara, CA 95054, USA. To participate you must create an Intel Digital Hub Account, purchase a qualifying product during the redemption period, enter a valid Master Key, and respond to a brief survey. Information you submit is collected, stored, processed, and used on servers in the USA. For more information on offer details, eligibility, restrictions, and our privacy policy, visit https://softwareoffer.intel.com/offer/20Q3-19/terms.
© 2020 MARVEL. © Intel Corporation. Intel, the Intel logo, and other Intel marks are trademarks of Intel Corporation or its subsidiaries in the U.S. and/or other countries. Other names and brands may be claimed as the property of others.
The personal information you provide will be used according to the HP Privacy Statement (https://www8.hp.com/us/en/privacy/ww-privacy.html)
