Sub Total
Excluding delivery and voucher code discounts.
Go to basket
Free Delivery on all orders to UK mainland within 3 working days.
HP TECH TAKES /...
Exploring today's technology for tomorrow's possibilities
HP Printers for Home Use in the UK
The Best Printers for Home Use in the UK
As remote work becomes standard practice across the UK, having a home printer has evolved from luxury to necessity. However, this widespread adoption has made choosing the right printer more challenging. With numerous options flooding the market and factors like budget, printing needs, and evolving technologies to consider, the selection process can feel overwhelming.
HP offers three distinctive printer lines designed to fulfil the needs of every home user: HP DeskJet for budget-conscious buyers, HP ENVY for versatile all-in-one use, and HP Smart Tank for high-volume printing. This comprehensive guide walks you through each line, helping you decide which printer best matches your needs and budget.
What to Consider When Choosing a Home Printer
Before purchasing a printer, evaluate these four key factors that will drive your decision.
Print Volume Needs
Most home printers handle occasional use rather than bulk printing. Consider your typical workload:
Light Usage (school worksheets, occasional documents)
  • Choose a printer optimised for minimal use
  • Requires close to no maintenance
  • Lower upfront cost is practical
Heavy Usage (creative professionals, work-from-home requirements)
  • Need higher capacity systems
  • Require cost-effective consumables
  • Benefit from refillable tank designs
Honestly assess your monthly print volume. This single factor dramatically influences long-term costs and satisfaction.
Document Types
The types of documents you print directly affect which printer class you need:
Black and White Documents
  • Emphasise speed over quality
  • Prioritise cost efficiency
  • Standard inkjet or laser works well
Colour Documents and Photos
  • Require higher resolution and colour fidelity
  • Demand quality output
  • Need better ink systems and colour management
Mixed Use (text and photos)
  • All-in-one or multi-function printers ideal
  • Balanced speed and quality important
Budget Considerations
The budget extends beyond upfront printer cost. The real expense emerges in running costs—ink and toner replacement can quickly exceed your initial investment.
Upfront Cost
  • Budget printers: £50–150
  • Mid-range printers: £150–300
  • Premium printers: £300+
Running Costs
  • Cheap printers with expensive cartridges become costly long-term
  • Refillable tank systems reduce per-page costs dramatically
  • High-yield cartridges offer better value than standard cartridges
Choosing a printer with efficient consumable costs may seem expensive initially but saves significantly over time with frequent use.
Space and Features
Home environments typically feature limited space and connectivity. Consider:
Physical Space
  • Compact printers fit desk corners and shelves
  • Larger models consume significant desk real estate
  • All-in-one multifunction designs maximise efficiency
Connectivity Requirements
  • Wireless printing matches modern workflows
  • Mobile app support enables printing from phones and tablets
  • Network connectivity suits multiple household users
Additional Features
  • Scanning and copying expand functionality
  • Automatic duplex (double-sided) printing saves paper
  • ADF (automatic document feeder) simplifies batch copying
Best Budget Home Printer: HP DeskJet Series
The HP DeskJet series delivers affordable, reliable printing without unnecessary professional features. These compact printers provide print, copy, and scan capabilities with wireless connectivity for easy mobile printing through the HP Smart App.
Who This Series Suits
Ideal for:
  • Families with light printing needs (schoolwork, occasional documents)
  • Home office workers printing a few pages daily
  • Budget-conscious buyers prioritising low cost
  • Users with minimal feature requirements
Strengths
  • All-in-one capability: Print, copy, and scan from one device
  • Low upfront cost: Entry-level pricing under £100 for many models
  • Wireless setup: HP Smart App integration for easy mobile printing
  • Compact design: Minimal desk space requirements
  • Easy maintenance: Simple setup and operation
Considerations
  • Cartridge costs add up: High-volume printing becomes expensive
  • Limited graphic support: Not ideal for frequent photo printing
  • Modest speeds: May feel slow for larger jobs
  • Basic feature set: No advanced connectivity or speciality functions
Who Shouldn’t Choose DeskJet
Users planning frequent colour photo printing or high monthly page volumes (200+ pages) should upgrade to ENVY or Smart Tank series. If printing habits exceed expectations, you’ll outgrow DeskJet quickly.
Verdict: Solid everyday performance at minimal cost. Perfect for occasional printing; upgrade if needs increase.
Best All-in-One Home Printer: HP ENVY Series
The HP ENVY series addresses users wanting versatility, including high-quality photo printing. These printers deliver print, copy, and scan functionality with touchscreen navigation and full wireless support, making them ideal for households with diverse printing needs.
Ideal for:
  • Creative households with mixed document types
  • Home offices printing text and occasional photos
  • Users wanting one machine handling multiple tasks
  • Those desiring higher photo quality without premium pricing
  • Small businesses operating from home
Strengths
  • Versatile functionality: Print, copy, scan, and photo support
  • Strong colour output: Quality suitable for casual photo printing
  • Multiple photo sizes: Supports diverse creative projects
  • Wireless connectivity: Seamless mobile printing and app integration
  • Touchscreen interface: Intuitive navigation and settings
  • Balanced speed: Handles most workloads efficiently
  • Reasonable pricing: Mid-range cost for all-in-one capability
Considerations
  • Higher than budget models: £200–350 range typical
  • Photo quality not professional-grade: Adequate for home use, not exhibition-quality
  • Moderate monthly duty cycle: Designed for regular rather than heavy use
  • Cartridge costs: Traditional cartridges vs. refillable tanks
Real-World Performance
Customers describe the ENVY series as a strong home office performer with photo quality good enough for casual photo-printing. All-in-one capabilities and robust wireless and app support make it a practical workhorse for diverse household printing needs.
Verdict: Excellent balance of features, quality, and cost. Best for households mixing document and photo printing.
Best High-Volume Home Printer: HP Smart Tank Series
The HP Smart Tank series handles heavy-duty printing needs from document quantity to complete photo books. The HP Smart Tank 7005 Wireless All-in-One Colour Printer delivers printing seamlessly from start to finish with a cartridge-free design for the whole family, creating a variety of outstanding-quality colour documents at a low cost with up to three years of Original HP ink included in the box.
Ideal for:
  • Home office users printing 500+ pages monthly
  • Students printing large assignments regularly
  • Photo enthusiasts printing batches of images
  • Cost-conscious users with high print volumes
  • Anyone prioritising cost-per-page above all else
Strengths
  • Ultra-low cost per page: Refillable tanks reduce consumable costs 70–90%
  • Refillable ink tanks: Large capacity reduces frequent refilling
  • Network and wireless connectivity: Full mobile printing support
  • Larger input capacity: Accommodates more paper
  • Exceptional value long-term: Monthly printing costs drop significantly
  • Multi-function capability: Print, copy, and scan from one device
Considerations
  • Higher upfront cost: £300–500 range typical (compared to DeskJet £100–150)
  • Larger footprint: Takes more desk space than compact models
  • Learning curve: Refill system requires initial understanding
  • Better for committed users: Long-term value requires sustained use
Another excellent option in the Smart Tank range is the HP Smart Tank 5107 Wireless All-in-One Colour Printer, which delivers the HP quality you expect with savings that are anything but expected.
Quick Comparison: Which HP Home Printer Is Right for You?
Usage Pattern Recommended Series Best For
Budget priority + light volume
HP DeskJet Series
Lowest upfront cost; sufficient for occasional printing; occasional documents and school projects
Balanced features + occasional photos
HP ENVY Series
All-in-one functionality; print, scan, copy, and casual photo support; home office versatility
High volume + cost efficiency
Refillable tanks; ultra-low cost per page; built for heavy use and cost-conscious frequent printing
Common Questions About Home Printers
What is the most cost-effective printer for home use?
For light printing, a DeskJet series printer offers the lowest upfront cost and easiest setup. However, if you plan printing 200+ pages monthly, a Smart Tank refillable system offers better long-term savings despite higher initial investment.
Are ink tank printers worth it for home users?
Yes, especially with high print volumes or frequent colour and photo printing. Higher upfront cost is offset by substantially lower per-page costs and simplified supply management. Tank refills cost significantly less than cartridge replacements.
What features should I prioritise in a home printer?
Essential features depend on your use case:
  • Wireless connectivity and mobile printing for modern workflows
  • Print quality and resolution especially for photo printing
  • Speed (ppm rating) for your typical job size
  • Multi-function capability (scan/copy) for versatility
  • Refillable tank system if printing frequently
  • Automatic duplex printing to save paper and costs
  • Adequate tray capacity for your paper needs
What’s the difference between inkjet and laser printers for home use?
Inkjet Printers
  • Versatile for documents and photos
  • Typically lower upfront cost
  • Excellent colour printing quality
  • Better for occasional use due to ink drying concerns
  • HP DeskJet and ENVY series are inkjets
Laser Printers
  • Faster monochrome printing
  • Lower cost-per-page for black-and-white documents
  • Better for high-volume document printing
  • Less ideal for quality photo printing
  • More expensive upfront
  • Better for business-heavy workflows
For home use combining documents and photos, inkjet (DeskJet or ENVY) is typically better. Browse HP’s range of laser printers if your needs are primarily business-focused.
Key Takeaways: Your Perfect Home Printer
Your search for the best home printer ends here with the right choice for your needs:
Budget-Friendly Choice
  • HP DeskJet Series: Perfect for light home use with minimal upfront cost
  • Best for: Occasional printing, school documents, basic home office needs
Versatile All-in-One
  • HP ENVY Series: Ideal for home offices and mixed document/photo workflows
  • Best for: Creative households, photo enthusiasts, multi-purpose printing
High-Volume Solution
  • HP Smart Tank Series: Cost-efficient for heavy home printing or small business use
  • Best for: Frequent printing, cost-conscious users, creative professionals
Whatever your printing plans, HP has a solution matching your needs specifically so you can maximise value and performance. Explore HP’s complete home printer lineup, compare models within each series, and find your perfect match with confidence.
Ready to upgrade your home printing? Browse the full HP printer collection today and make your choice with certainty. Whether you need a business printer for your home office or a home office printer for everyday use, HP has the perfect solution for you.
Disclosure: Our site may get a share of revenue from the sale of the products featured on this page.
Disclaimer
HP’s MSRP is subject to discount. HP’s MSRP price is shown as either a stand-alone price or as a strike-through price with a discounted or promotional price also listed. Discounted or promotional pricing is indicated by the presence of an additional higher MSRP strike-through price
The following applies to HP systems with Intel 6th Gen and other future-generation processors on systems shipping with Windows 7, Windows 8, Windows 8.1 or Windows 10 Pro systems downgraded to Windows 7 Professional, Windows 8 Pro, or Windows 8.1: This version of Windows running with the processor or chipsets used in this system has limited support from Microsoft. For more information about Microsoft’s support, please see Microsoft’s Support Lifecycle FAQ at https://support.microsoft.com/lifecycle
Ultrabook, Celeron, Celeron Inside, Core Inside, Intel, Intel Logo, Intel Atom, Intel Atom Inside, Intel Core, Intel Inside, Intel Inside Logo, Intel vPro, Itanium, Itanium Inside, Pentium, Pentium Inside, vPro Inside, Xeon, Xeon Phi, Xeon Inside, and Intel Optane are trademarks of Intel Corporation or its subsidiaries in the U.S. and/or other countries.
Microsoft Windows 10: Not all features are available in all editions or versions of Windows 10. Systems may require upgraded and/or separately purchased hardware, drivers, software or BIOS update to take full advantage of Windows 10 functionality. Windows 10 is automatically updated, which is always enabled. ISP fees may apply and additional requirements may apply over time for updates. See http://www.microsoft.com.
Get Marvel’s Avengers when you purchase HP gaming PCs with qualifying 9th gen or 10th gen Intel® Core™ i5, i7 and i9 processors. Redemption code will be sent out by email within 60 days of purchase. Limited quantities and while supply lasts. Offer valid thru 12/31/2020 only while supplies last. We reserve the right to replace titles in the offer for ones of equal or greater value. Certain titles may not be available to all consumers because of age restrictions. The Offer may be changed, cancelled, or suspended at any time, for any reason, without notice, at Intel’s reasonable discretion if its fairness or integrity affected whether due to human or technical error. The Offer sponsor is Intel Corporation, 2200 Mission College Blvd., Santa Clara, CA 95054, USA. To participate you must create an Intel Digital Hub Account, purchase a qualifying product during the redemption period, enter a valid Master Key, and respond to a brief survey. Information you submit is collected, stored, processed, and used on servers in the USA. For more information on offer details, eligibility, restrictions, and our privacy policy, visit https://softwareoffer.intel.com/offer/20Q3-19/terms.
© 2020 MARVEL. © Intel Corporation. Intel, the Intel logo, and other Intel marks are trademarks of Intel Corporation or its subsidiaries in the U.S. and/or other countries. Other names and brands may be claimed as the property of others.
The personal information you provide will be used according to the HP Privacy Statement (https://www8.hp.com/us/en/privacy/ww-privacy.html)
