  • CLOUD, getAggregateRating, 466.14ms
HP ZBook Power 15.6 inch G9 Mobile Workstation PC + P M22f 21.5 FHD IPS Monitor
In stock
732B4PA-BN
screen size 15.6"
Color Turbo Silver
Included:
  • เม้าส์ USB and กระเป๋าโน๊ตบุ๊ค
OPTIONS
(1 MORE OPTIONS AVAILABLE)
Learn More
Includes 3 Years On-site Warranty
    Choose Your Option
    hp care pack(1) learn more
  • 3 Years On-site Warranty
  • HP 3 year Next Business Day Response Onsite w/Accidental Damage Protection NB HW Supp
    THB 2,970.00
Contains
HP M22f FHD Monitor
THB 61,990.00 SAVE฿2,500 (4%)
As low as THB 59,490.00
You Save: ฿2,500 (4%)
THB 5,949.00/m*
  See repayments
Free & fast delivery - Learn More
0% Interest Free - Learn More
Delivery
Shipping Availability
Delivery estimate to is:
In stock
Pro-certified power within reach​
Overview
Recommended
Features
Specs
Offers
Reviews
Ask a Question
Similar Products
HP ZBook Power G9 Mobile Workstation PC
Upgrade to professional ZBook performance and security at an unbelievably affordable price. Power up your productivity on this durable yet premium device—delivering enhanced collaboration features and pro-grade components to seamlessly run leading professional software applications.
  • Intel Core Processors
  • HD camera
  • HP Collaboration Keyboard
1 2 3
  • 1. 15.6" diagonal FHD display
  • 2. HP Audio, dual stereo speakers
  • 3. Fingerprint Sensor
*For selected products only
Power through professional workflow
Blaze through 3D modeling workloads with NVIDIA® graphics, and seamlessly multitask with Intel® processors, fast storage and large memory configurations.
Intel® Core™ Processors
Run several CPU–heavy programs simultaneously without sacrificing performance with the latest Intel® Core™ Processors.
Certified, secured and supported.
Get peace of mind with a high-performance PC that's certified to work with professional apps and comes with HP Wolf Security for Business—protecting below, in and above the OS.3
Connect. Communicate. Collaborate
Collaborate effectively with ZBook Power. The 720p HD camera offers improved image quality and AI enhanced audio software4 blocks background noises so you can connect from anywhere.
Launch and manage calls from anywhere using Skype® with HP Noise Cancellation and the world-facing third microphone. Shortcut keys, including start/stop call, calendar and screen share, enable efficient and effective collaboration.
HP Z Turbo Drive High-speed Storage
Work without limits in any location with local PCIe storage that’s up to 6x faster than SATA SSD, and up to 21x faster than traditional HDD storage.2
Take The Next Step
1. Multicore is designed to improve performance of certain software products. Not all customers or software applications will necessarily benefit from use of this technology. Performance and clock frequency will vary depending on application workload and your hardware and software configurations. Intel’s numbering, branding and/or naming is not a measurement of higher performance.
2. For hard drives, GB = 1 billion bytes. TB = 1 trillion bytes. Actual formatted capacity is less. Up to 30GB (for Windows 10) of system disk is reserved for system recovery software.
3. HP Wolf Security for Business requires Windows 10 or higher, includes various HP security features and is available on HP Pro, Elite and Workstation products. See product details for included security features and OS requirement.
4. DNN Noise Reduction is delivered automatically through Windows update or can be downloaded from https://support.hp.com/us-en/drivers. Requires Windows 10 or higher, compatible with internal PC speakers, microphone and analog headsets. The DNN Noise Reduction setting can be configured through the Application HP Audio Control.
Features
Intel® Core™ i7 processor
Run several CPU–heavy programs simultaneously without sacrificing performance with an Intel® Core™ i7 processor.
15.6" (39.6 cm) Diagonal FHD Display
Get clear and sharp visuals in full high definition. Comfortably work without reflections on an anti-glare screen.
Industry-leading security features
Advanced security features come standard. System safeguards like HP Sure Start – the industry's first self-healing BIOS – mean your device is locked down tight, so your data and identity are too.
Specs
Windows 11 Pro
Processor
Intel® Core™ i7-12700H (up to 4.7 GHz with Intel® Turbo Boost Technology, 24 MB L3 cache, 14 cores, 20 threads)
Memory
16 GB DDR5-4800 MHz RAM (1 x 16 GB)
Graphics
NVIDIA® Quadro® T600 (4 GB GDDR6 dedicated)
Memory and storage
16 GB memory; 1 TB SSD storage
Offers
Special offers
Free Monitor
  • Promo ends by 31st March 2023 or While stock last
  • Other terms apply
SEE MORE
Call us at 1800-012-214 to customize your order
SEE MORE
3% off with HPTH23
  • Promotion ends on 31 December 2023 or while stock last.
SEE MORE
Up to 50% off PWP on accessories and more!
Purchase-With-Purchase Item Promo Details
50% off Accessories Max 500 baht discount
10% off Printers Max 300 baht discount
10% off Monitors Max 300 baht discount
  • Discount will be automatically applied at checkout.
  • This promo is valid with any LAPTOPS or DESKTOPS only.
  • You may add PWP items under "Recommended" tab or add item to your cart directly.
  • Other terms apply*.
SEE MORE
HP M22f FHD Monitor
Reviews
  • CLOUD, getReviews, 5.57ms
Ask a Question
Ask a Question
FEATURES
  • [1] Multicore is designed to improve performance of certain software products. Not all customers or software applications will necessarily benefit from use of this technology. Performance and clock frequency will vary depending on application workload and your hardware and software configurations. Intel’s numbering, branding and/or naming is not a measurement of higher performance.
  • [3] Optional, configurable feature that must be configured at purchase.
  • [6] Testing is not intended to demonstrate fitness of U.S. Department of Defense (DoD) contract requirements or for military use. Test results are not a guarantee of future performance under these test conditions. Accidental damage requires an optional HP Accidental Damage Protection Care Pack.
  • [7] Select household wipes can be safely used to clean HP Elite and Workstation PCs up to 1,000 wipes: See wipe manufacturer’s instructions for disinfecting and the HP cleaning guide for HP tested wipe solutions at How to Sanitize Your HP Device Whitepaper (http://h20195.www2.hp.com/v2/GetDocument.aspx?docname=4AA7-7610ENW). Not applicable to HP Elite c1030 Chromebook.
  • [11] DNN Noise Reduction is delivered automatically through Windows update or can be downloaded from https://support.hp.com/us-en/drivers. Requires Windows 10 or higher, compatible with internal PC speakers, microphone and analog headsets. The DNN Noise Reduction setting can be configured through the Application HP Audio Control.
  • [12] HP Wolf Security for Business requires Windows 10 or 11 Pro or higher, includes various HP security features and is available on HP Pro, Elite and Workstation products. See product details for included security features and OS requirement.
TECHNICAL DETAILS
  • [1] Not all features are available in all editions or versions of Windows. Systems may require upgraded and/or separately purchased hardware, drivers, software or BIOS update to take full advantage of Windows functionality. Windows is automatically updated and enabled. High speed internet and Microsoft account required. ISP fees may apply and additional requirements may apply over time for updates. See http://www.windows.com .
  • [2] Multicore is designed to improve performance of certain software products. Not all customers or software applications will necessarily benefit from use of this technology. Performance and clock frequency will vary depending on application workload and your hardware and software configurations. Intel’s numbering, branding and/or naming is not a measurement of higher performance.
  • [3] Processor speed denotes maximum performance mode; processors will run at lower speeds in battery optimization mode.
  • [4] Intel® Turbo Boost performance varies depending on hardware, software and overall system configuration. See www.intel.com/technology/turboboost for more information.
  • [5] In accordance with Microsoft’s support policy, HP does not support the Windows 8 or Windows 7 operating system on products configured with Intel and AMD 7th generation and forward processors or provide any Windows 8 or Windows 7 drivers on http://www.support.hp.com
  • [8] Maximized dual-channel performance requires SODIMMs of the same size and speed in both memory channels.
  • [9] Intel® allows architectures designed with four DIMM slots to run at 3200 MT/s.
  • [10] Maximum memory capacities assume Windows 64-bit operating systems. With Windows 32-bit operating systems, memory above 3 GB may not all be available due to system resource requirements.
  • [11] For storage drives, GB = 1 billion bytes. TB = 1 trillion bytes. Actual formatted capacity is less. Up to 35GB (for Windows) is reserved for system recovery software.
  • [12] GbE - The term "10/100/1000" or "Gigabit" Ethernet indicates compatibility with IEEE standard 802.3ab for Gigabit Ethernet, and does not connote actual operating speed of 1 Gb/s. For high-speed transmission, connection to a Gigabit Ethernet server and network infrastructure is required.
  • [13] Wi-Fi 6E requires a Wi-Fi 6E router, sold separately, to function in the 6GHz band. Availability of public wireless access points limited. Wi-Fi 6E is backwards compatible with prior 802.11 specs. And available in countries where Wi-Fi 6E is supported.
  • [14] HD camera feature. InfraRed feature , IPS Anti-reflection Touchscreen feature are based on the selection of display.
  • [15] HP ZCentral Remote Boost Sender does not come preinstalled on Z Workstations but can be downloaded and run on all Z desktop and laptops without license purchase through 2022. With non-Z sender devices, purchase of perpetual individual license or perpetual floating license per simultaneously executing versions and purchase of ZCentral Remote Boost Software Support is required. ZCentral Remote Boost Sender for non-Z Hardware requires a license and Windows 10, RHEL/CentOS (7 or 8), or UBUNTU 18.04 or 20.04 LTS operating systems. macOS (10.14 or newer) operating system and ThinPro 7.2 are only supported on the receiver side. Requires network access. The software is available for download at hp.com/ZCentralRemoteBoost .
  • [16] Intel® Integrated graphics: Intel® Xᵉ Graphics.
  • [17] FHD and HD content required to view HD images respectively.
  • [18] Windows Hello face authentication utilizes a camera specially configured for near infrared (IR) imaging to authenticate and unlock Windows devices as well as unlock your Microsoft Passport.
  • [19] HP Sure Click requires Windows 10 Pro or higher or Enterprise. See https://bit.ly/2PrLT6A_SureClick for complete details.
  • [20] 120 W power adapter is only available with UMA graphics. 150 W power adapter is only available with discrete graphic options.
  • [21] UHD content required to view UHD images.
  • [22] HP BIOSphere Gen6 features may vary depending on the platform and configuration.
  • [23] Resolutions are dependent upon monitor capability, and resolution and color depth settings.
  • [24] Actual brightness will be lower with HP Sure View or touch-screen.
  • [25] For full Intel® vPro™ functionality, Windows 10 Pro 64 bit, a vPro supported processor, vPro enabled chipset, vPro enabled wired LAN and/or WLAN card and TPM 2.0 are required. Some functionality requires additional 3rd party software in order to run. See http://intel.com/vpro
  • [26] HP Quick Drop requires Internet access and Windows 10 PC preinstalled with HP QuickDrop app and either an Android device (phone or tablet) running Android 7 or higher with the Android HP QuickDrop app, and /or an iOS device (phone or tablet) running iOS 12 or higher with the iOS HP QuickDrop app.
  • [27] HP Sure Run Gen3 is available on select HP PCs and requires Windows 10 and higher.
  • [28] SuperSpeed USB 20Gbps is not available with Thunderbolt™ 4.
  • [29] HP Performance Advisor Software - HP Performance Advisor is ready and waiting to help you get the most out of your HP Workstation from day one—and every day after. Learn more or download at: https://www.hp.com/us-en/workstations/performance-advisor.html
  • [30] HP Manageability Integration Kit can be downloaded from http://www8.hp.com/us/en/ads/clientmanagement/overview.html
  • [31] Absolute Persistence Module: Absolute agent is shipped turned off, and will be activated when customers activate a purchased subscription. Subscriptions can be purchased for terms ranging multiple years. Service is limited, check with Absolute for availability outside the U.S. The Absolute Recovery Guarantee is a limited warranty. Certain conditions apply. For full details visit: http://www.absolute.com/company/legal/agreements/computrace-agreement . Data Delete is an optional service provided by Absolute Software. If utilized, the Recovery Guarantee is null and void. In order to use the Data Delete service, customers must first sign a Pre-Authorization Agreement and either obtain a PIN or purchase one or more RSA SecurID tokens from Absolute Software.
  • [32] The system must be populated with dual channel memory for Intel Iris XE. Otherwise, system uses the Intel® UHD Graphics.
  • [33] Manage and monitor your battery’s performance and condition and customize charging options with the easy-to-use HP Power Manager dashboard.
  • [34] Security lock for security slot is sold separately.
  • [35] Miracast is a wireless technology your PC can use to project your screen to TVs, projectors, and streaming media players that also support Miracast. You can use Miracast to share what you’re doing on your PC and present a slide show. For more information: http://windows.microsoft.com/en-us/windows-8/project-wireless-screen-miracast .
  • [37] Battery is internal and not replaceable by customer. Serviceable by warranty. Batteries have a default one year limited warranty except for Long Life batteries which will have same 1-year or 3-year warranty as the platform.
  • [38] HP Sure Start Gen6 is available on select HP PCs and requires Windows 10 and higher.
  • [39] HP Support Assistant: Requires Windows and Internet access.
  • [40] Actual battery Watt-hours (Wh) will vary from design capacity. Battery capacity will naturally decrease with shelf life, time, usage, environment, temperature, system configuration, loaded apps, features, power management settings and other factors.
  • [41] Based on US EPEAT® registration according to IEEE 1680.1-2018 EPEAT®. EPEAT® status varies by country. Visit http://www.epeat.net for more information
  • [42] External power supplies, power cords, cables and peripherals are not low halogen. Service parts obtained after purchase may not be low halogen.
  • [43] HP Smart Support automatically collects the telemetry necessary upon initial boot of the product to deliver device-level configuration data and health insights and is available preinstalled on select products, thru HP Factory Configuration Services; or it can be downloaded. For more information about how to enable HP Smart Support or for download, please visit http://www.hp.com/smart-support .
  • [45] Dual-microphone array when equipped with optional webcam and optional world facing microphone.
  • [47] Secure Erase - For the methods outlined in the National Institute of Standards and Technology Special Publication 800-88 "Clear" sanitation method. HP Secure Erase does not support platforms with Intel® Optane™.
  • [49] HP Sure Recover Gen3 is available on select HP PCs and requires an open network connection. You must back up important files, data, photos, videos, etc. before using HP Sure Recover to avoid loss of data. Network based recovery using Wi-Fi is only available on PC’s with Intel Wi-Fi Module.
  • [52] Storage Slot 1 can support both PCIe Gen3 and Gen4 drives.
  • [53] Requires an Intel® vPro® , AMD Ryzen™ Pro processor or Qualcomm® processor with SD850 or higher and requires 8 GB or more system memory. Secured Core PC functionality can be enabled from the factory.
  • [55] Thunderbolt™ 4 and USB4™ maximum speed of 40Gbps will be divided between the different data workstreams.
  • [56] This product includes a three (3) year license of HP Wolf Pro Security Edition which includes HP Sure Click Pro and HP Sure Sense Pro. The HP Wolf Pro Security Edition software is licensed under the license terms of the HP End User License Agreement (EULA) that can be found at: https://support.hp.com/us-en/document/ish_3875769-3873014-16 as modified by the following: “7. Term. Unless otherwise terminated earlier pursuant to the terms contained in this EULA, the license for the HP Wolf Pro Security Edition (HP Sure Sense Pro and HP Sure Click Pro) is effective upon activation and will continue for thirty six (36) months thereafter (“Initial Term”). At the end of the Initial Term you may either (a) purchase a renewal license for the HP Wolf Pro Security Edition from HP.com, HP Sales or an HP Channel Partner, or (b) continue using the standard versions of HP Sure Click and HP Sure Sense at no additional cost with no future software updates or HP Support.”
Mon-Fri 9.00am - 6.00pm
6623284555(WhatsApp)
@hpthailand (Line)
