Register Page
HP Series 7 Pro 24 inch WUXGA USB-C Monitor - 724pu
THB 11,870.00
SAVE THB 1,180
THB 10,690.00
Installment from
THB 1,069.00*
See repayments
10% off Monitors with a PC purchase*
  • CLOUD, getAggregateRating, 254.87ms
In stock
8Y2F7AA
Designed for big things. Powered to do them.
THB 11,870.00 SAVETHB 1,180 (9%)
THB 10,690.00
You Save: THB 1,180 (9%)
Installment from
THB 1,069.00*
See repayments
Installment
Leasing
content
3mths 4mths 6mths 10mths
- THB 2,672.50 THB 1,781.67 THB 1,069.00
THB 3,563.33 THB 2,672.50 THB 1,781.67 THB 1,069.00
  • Financial Freedom
  • Cutting-Edge Tech Access
  • Tax Savings Potential
  • Quick Implementation
  • Lease-End Flexibility
Call 02 028 1504
Not ready to buy?
Notify me when this product is in stock
Shipping Availability
Configuration
  • 24-inch WUXGA (1920 x 1200 @ 60 Hz)
  • Flat with edge-lit backlight
  • 1 HDMI 2.0
  • Adjustable stand; VESA mountable; Sustainable; HP Eye Ease
  • (See more Specifications)
Overview
Capture your vision better than you ever imagined with the HP Series 7 Pro 24" WUXGA USB-C Monitor. Do more with the 16:10 aspect ratio and WUXGA resolution that displays more of your work at once.[2] And, trust what you see on screen with superb color accuracy right out of the box, a smooth refresh rate, and enhanced color contrast.[1] Do it all with seamless USB-C® connectivity that turns your monitor into a powerful productivity hub.
Discover what you can do with more.
See your work take on a whole new dimension on a large, smooth screen with vibrant, accurate colors right out of the box. See every detail pop thanks to the deeper shadows and brighter highlights of 1500:1 contrast ratio.[1] enjoy 99% sRBG and 85% Display P3 color gamuts with factory color calibration for remarkable, real-life color accuracy that stays consistent from screen to screen. This 16:10 screen with WUXGA resolution gives you 11% more display space[2] so you can see—and do—more.
Ditch the clutter. Enjoy the power.
This beautifully crafted, premium design heightens your work-life and highlights your desk space thanks to its razor-thin profile and streamlined connectivity. One USB-C® cable delivers video, data, and up to 100 W power, so you can connect your accessories and charge your laptop—all through this monitor hub. The sleek, four-sided micro-edge frame and seamless daisy-chaining creates the perfect multi-monitor hub for more space to work.
Comfort at every turn. Swivel. And tilt.
Stay fresh and comfortable with the monitor that helps you get more done throughout your day. Make screentime comfortable with 100 Hz refresh rates[1] for responsive, seamless scrolling and smooth video playback, while you enhance your focus with built-in HP Eye Ease that reduces blue light output while keeping color accuracy true-to-life. Customize your comfort with four-way ergonomic adjustability—complete with a 150 mm height-adjust stand with tilt, swivel and pivot.
Built for a better tomorrow.
A better choice in an innovative solution, this HP Series 7 Pro monitor is designed using 85% post-consumer recycled materials and 5% ocean-bound plastics[3] with 90% recycled aluminum in the stand. With 100% sustainably sourced packaging[4] and a TCO certified, EPEAT® Registered and ENERGY STAR® Certified design[5], you can be confident knowing you have a monitor that does good things for the planet while doing amazing things for you.
100 Hz Refresh Rate
See and do more with WUXGA resolution from a 16:10 screen that gives you 11% more display space[2], factory color calibration for real-life color accuracy, and 1500:1 contrast ratio[1] for deeper, brighter imagery.
Enhance your work space and work life with USB-C® connectivity that delivers video, data, and up to 100 W charging power, while daisy chaining a second monitor and connecting all your accessories—all through this monitor hub.
Make screentime comfortable with 100 Hz refresh rates[1] for smooth, seamless video. Enhance your focus with built-in HP Eye Ease that reduces blue light to keep eyes fresh, and four-way ergonomic adjustability to customize your comfort.
Features
16:10 WUXGA Resolution
Get 11% more screen with WUXGA (1920x1200) resolution and 16:10 aspect ratio.
100 Hz Refresh Rate
Experience smooth, life-like videos and clear details.
More Contrast
See more detail in color, shadow, and highlights thanks to the enhanced 1500:1 contrast ratio.
99% sRGB & 85% Display P3 Color Gamuts
Trust the colors you see on screen with all the shades and hues of 99% sRGB and 85% Display P3 color gamuts.
Accurate color out of the box
Every HP Series 7 Pro Monitor undergoes strict factory color calibration to ensure that over 400 colors achieve a Delta E of less than 2, making any color difference virtually indistinguishable to the human eye for superb color accuracy.
IPS Panel Technology
No matter where you stand, IPS technology ensures image accuracy and consistency across wide 178-degrees horizontal and vertical viewing angles.
USB-C® with 100 W Power Delivery
Keep your setup simple and seamless with a built-in hub. With just one USB-C® cable, connect your PC or Mac, all your accessories via the monitor's USB-A ports, and even Ethernet via RJ-45, for data, video, and up to 100 W of charging.
More Ports. More Flexibility.
More ports means more capabilities. With an HDMI 2.0, 2 DisplayPort™ 1.4 in/out, USB-C® ports, plus 4 additional USB-A 3.2 ports, you can connect or charge multiple devices like a headset and webcam.
Endless Adjustability
Work effortlessly and comfortably with 4-way adjustability.
Ergonomic Setup Guide
With world-class ergonomic practices at your fingertips, you have the knowledge to fine-tune your display's 4-way adjustability to achieve optimal, all-day comfort thanks to the step-by-step Ergonomic Setup Guide in HP Display Center.
Always-on, True Color, Low-Blue Light Filter
HP Eye Ease keeps you comfortable by reducing blue light without impacting color accuracy.
Remote Management Reimagined
HP Client Management Script Library (CMSL) makes remote manageability easy to use. This powerful solution works seamlessly with Intune/SCCM to manage your display fleet using PowerShell.
Specs
Screen size
24-inch
Resolution (native)
WUXGA (1920 x 1200)
Display type
IPS; LCD
Offers
Special offers
Purchase-With-Purchase Item
Get 50% off Accessories with PC purchase (Max Discount 3,000baht)  here
Get 10% off Monitor with PC Purchase (Max Discount 300 baht) here
Get 10% off Printer with PC Purchase (Max Discount 300 baht) here
  • This promo is valid with any LAPTOPS or DESKTOPS purchase only.
  • Discount will be automatically applied at checkout.
  • Applies to all Accessories, Printers or Monitors from under "Recommended" tab or add item to your cart directly.
SEE MORE
Reviews
  • CLOUD, getReviews, 8.09ms
Questions and Answers
  • CLOUD, getReviews, 8.89ms
Drivers, Manuals & Support
Click here
FEATURES
  • [1] All performance specifications represent the typical specifications provided by HP's component manufacturers; actual performance may vary either higher or lower.
  • [2] Based on comparison against a 23.8-inch FHD (1920 x 1080) resolution monitor.
  • [3] Recycled plastic content percentage is based on the definition set in the IEEE 1680.1-2018 EPEAT® standard. Plastics consist of 90% Post-Consumer Recycled, with 85% post-consumer recycled plastics + 5% Ocean-Bound Plastics (PET).
  • [4] 100% outer box/corrugate cushion packaging made from sustainably sourced certified and recycled fibers. Fiber cushions made from 100% recycled wood fiber and organic material. Any plastic cushions are made from >90% recycled plastic. Excludes plastic bags and plastic foam sheeting.
  • [5] Based on US EPEAT® registration according to IEEE 1680.1-2020 EPEAT®. Status varies by country. Visit www.epeat.net for more information.
TECHNICAL DETAILS
  • [1] All specifications represent the typical specifications provided by HP's component manufacturers, actual performance may vary either higher or lower.
  • [2] DisplayPort™ 1.4 or HDMI 2.0 required to drive panel at its native resolution. The video card of the connected PC must be capable of supporting 1920 x 1200 at 60 Hz and include 1 HDMI or 1 DisplayPort™ outputs to drive the monitor at the Preferred Mode.
  • [3] Number of colors through A-FRC technology.
  • [4] EPEAT® registered where applicable. EPEAT® registration varies by country. See www.epeat.net for registration status by country. Based on US EPEAT® registration according to IEEE 1680.1-2018 EPEAT®. Status varies by country. Visit www.epeat.net for more information.
  • [5] External power supplies, WWAN modules, power cords, cables and peripherals excluded. Service parts obtained after purchase may not be Low Halogen.
  • [6] ITE Derived Closed Loop Plastic percentage is based on the definition set in the IEEE 1680.1-2018 standard.
  • [7] 100% outer box packaging and corrugated cushions made from sustainably sourced certified and recycled fibers.
  • [8] All plastic parts contain ocean-bound plastic. Percentage of ocean-bound plastic contained in each component varies by product.
  • [9] Percent of recycled metal varies by product.
  • [10] Included cables may vary by country.
  • [11] Lock sold separately.
  • [12] Host PC requires Windows 10 and above. HP Display Center is available on the Microsoft store.
  • [13] HP CMSL is estimated to be available between November 2024 to April 2025. HP CMSL is only supported on 64-bit PowerShell 5.1 and higher. CMSL Support Windows 10 version 1809 and higher, and Windows 11. Some limitations may apply to legacy displays. Visit support.hp.com to download HP CMSL.
024450601
Mon-Fri 9.00am - 6.00pm
6623284555(WhatsApp)
@hpthailand (Line)
