Register Page
HP Series 5 Pro 27 inch QHD USB-C Monitor - 527pu
THB 14,650.00
SAVE THB 1,460
THB 13,190.00
Installment from
THB 1,319.00*
See repayments
10% off Monitors with a PC purchase*
  • CLOUD, getAggregateRating, 424.31ms
In stock
9E0G5AA
Powerfully designed to connect
THB 14,650.00 SAVETHB 1,460 (9%)
THB 13,190.00
You Save: THB 1,460 (9%)
Installment from
THB 1,319.00*
See repayments
Installment
Leasing
content
3mths 4mths 6mths 10mths
- THB 3,297.50 THB 2,198.33 THB 1,319.00
THB 4,396.67 THB 3,297.50 THB 2,198.33 THB 1,319.00
  • Financial Freedom
  • Cutting-Edge Tech Access
  • Tax Savings Potential
  • Quick Implementation
  • Lease-End Flexibility
Call 02 028 1504
Not ready to buy?
Notify me when this product is in stock
Shipping Availability
Configuration
  • 27 inch QHD (2560 x 1440)
  • Curved with Edge-lit backlight
  • 1 HDMI 2.0, DisplayPort™
  • Docking monitor
  • Adjustable stand; VESA mountable; Sustainable; HP Eye Ease; WWCB Certified
  • (See more Specifications)
Overview
Plug into more possibilities with the HP Series 5 Pro 27” QHD USB-C​ Monitor. Its sleek, modern design gives you crisp, stunning visuals and enhanced 100W power delivery with a single cable connection that seamlessly connects to PCs and peripherals at home or in the office.
Your center of productivity
Get more done with your unique hub for unstoppable productivity. Connect any device[3] with a single USB-C® cable for strong 100W power delivery. See your work elevated in smooth, crisp detail with 100 Hz refresh rate[1], while also experiencing vibrant, consistent colors with 100% sRGB[1] and HP Progressive White Balance[2].
Designed to work beautifully together
Transform your space into a seamless workplace. The 3-sided borderless with micro-edge bezel design lets you see more than ever. Daisy-chain[4] another HP Series 5 Pro monitor[5] for a perfect dual display setup with next-level productivity.
Take control of your comfort
Find a way to feel your best all day with 4-way adjustability optimized by the step-by-step Ergonomic Setup Guide[6] in HP Display Center[7]. Keep your eyes comfortable with HP Eye Ease by reducing blue light without impacting color.
Materials that make an impact
This energy-efficient monitor is thoughtfully designed with at least 90% recycled plastic content[8], 20% recycled glass in the monitor panel[10], and 90% recycled aluminum in the stand[9]. Plus, 100% of the paper-based packaging is sustainably sourced[11].
IPS Technology
Experience elevated productivity on any device[3] with 100W power delivery. See more vibrant and consistent colors with 100% sRGB[1] and HP Progressive White Balance[2].
Transform your space with a sleek, 3-sided borderless with micro-edge bezel design. Daisy-chain[4] another monitor[5] for a perfect dual display setup.
Find all-day comfort with 4-way adjustability and the Ergonomic Setup Guide[6] for the optimal monitor position. HP Eye Ease reduces blue light without impacting color.
HP is proud to be rated Platinum by EcoVadis
This places HP in the top 1% of organisations assessed globally, recognising our commitment to ethical sourcing, sustainability Innovation, and a respectful working environment.
Environment
Environment:
Focuses on how companies take responsibility for their ecological footprint through the product life cycle and supply chain operations, covering greenhouse gas emissions, energy consumption, water, waste reduction, and air pollution prevention.
Labour & Human Rights
Labour & Human Rights:
Centred on the standards businesses uphold for their workforce and supply chain, including diversity and inclusion, safe working conditions, fair compensation, and employee development.
Ethics
Ethics:
Rooted in responsible business conduct, covering anti‑corruption policies, data privacy and security, and compliance with applicable laws and regulations.
Sustainable Procurement
Sustainable Procurement:
Aimed at ensuring that businesses make sourcing decisions that take into account the broader environmental, social, and economic consequences of their supply chain choices.
Features
QHD Resolution
Dive into the captivating definition and sharp details of 3.7 million pixels. 2560 x 1440 Quad HD resolution transforms all your content for a stunning viewing experience on this 27" monitor.
IPS Technology
No matter where you are or sit, IPS technology ensures image accuracy and consistency across wide 178-degrees horizontal and vertical viewing angles.
100 Hz Refresh Rate
With a 100 Hz refresh rate this monitor is capable of clear details, smoothly moving from frame to frame, allowing for fast split-second reaction time.
More Contrast
See the nuanced differences of color, shadow, and highlights thanks to the enhanced 1500:1 contrast ratio.
High Brightness
350 nits of brightness lets you see clearly. Enhance your visual performance for work or simply enjoying entertainment.
100% sRGB Color Gamut
Enjoy highly accurate colors on screen with 100% sRGB. This HP monitor provides ideal color reproduction with minimal effort.
Work better with content that looks the same on both screens. Progressive White Balance is an HP technology that provides consistent white-point matching from screen-to-screen.
USB-C® Connectivity
Keep your set up simple and seamless with a display that has everything built in. Connect a keyboard and mouse to the ports on the back of this monitor and only one USB-C® cable to your notebook for data, video, and up to 100W of charging.
Daisy-Chain a Second HP Series 5 Pro Monitor
Display even more with DisplayPort™ by daisy- chaining a second HP Series 5 Pro monitor for the perfect dual-display setup.
More Ports. More Power. Easily Accessible.
Packed with ports including full-function USB-C®, HDMI 2.0, DisplayPort™ 1.4, USB-C® downstream, plus 3 USB-A 3.2 ports.
Sleek Design, Clean Space
See and do more on your screen with a 3-sided borderless with micro-edge bezel design that maximizes your viewing area for a sleek design and virtually seamless dual-monitor setups.
Endless Adjustability
With 4-way adjustability you can customize pivot, tilt, height adjust, and swivel settings to fit you, your desk, and your needs.
Specs
Screen size
27-inch
Resolution (native)
QHD (2560 x 1440)
Display type
IPS; LCD
Offers
Special offers
Purchase-With-Purchase Item
Get 50% off Accessories with PC purchase (Max Discount 3,000baht)  here
Get 10% off Monitor with PC Purchase (Max Discount 300 baht) here
Get 10% off Printer with PC Purchase (Max Discount 300 baht) here
  • This promo is valid with any LAPTOPS or DESKTOPS purchase only.
  • Discount will be automatically applied at checkout.
  • Applies to all Accessories, Printers or Monitors from under "Recommended" tab or add item to your cart directly.
SEE MORE
Reviews
  • CLOUD, getReviews, 7.78ms
Questions and Answers
  • CLOUD, getReviews, 7.95ms
Drivers, Manuals & Support
Click here
FEATURES
  • [1] All performance specifications represent the typical specifications provided by HP's component manufacturers; actual performance may vary, either higher or lower.
  • [2] HP's Progressive White Balance feature is designed to calibrate 100% full white on HP Series 5 Pro monitors. This adjustment is intended to align the white point more closely among various HP Series 5 Pro monitors. However, due to the nature of monitors, perceptible differences in the white color may still occur when the monitors are viewed from varying angles.
  • [3] Works across any OS. Keeps the same power delivery when connecting multiple devices.
  • [4] 100 Hz refresh rate supported on host PCs with DisplayPort™ 1.2 or higher. Host PC may affect the refresh rate combinations of monitors 1 and 2. Refresh rates can be user enabled in PC settings.
  • [5] HP Series 5 Pro monitor or additional monitor sold separately.
  • [6] Ergonomic Setup Guide is available through HP Display Center. Host PC requires Windows 10 or higher. HP Display Center is available on the Microsoft store.
  • [7] Host PC requires Windows 10 or higher. HP Display Center is available for download on the Microsoft store for Windows or support.hp.com for Windows and MacOS.
  • [8] Recycled plastic is expressed as a percentage of the total weight plastic. Post-consumer recycled is based on the definition set in the EPEAT® standard for computers, IEEE 1680.1-2018 standard.
  • [9] Recycled metal is expressed as a percentage of the total weight of the metal according to ISO 14021 definitions for metal parts over 25 grams.
  • [10] Percentage of recycled glass in the monitor panel varies by product. Recycled glass is expressed as a percentage of the total weight of the glass.
  • [11] 100% of paper-based packaging made from sustainably sourced, certified, and recycled fibers.
TECHNICAL DETAILS
  • [1] All specifications represent the typical specifications provided by HP's component manufacturers, actual performance may vary either higher or lower.
  • [2] DisplayPort™ 1.4 or HDMI 2.0 required to drive panel at its native resolution. The video card of the connected PC must be capable of supporting 2560 x 1440 at 60 Hz with 8-bit color using one DisplayPort™, HDMI. The video card of the connected PC must be capable of supporting 2560 x 1440 and include one DisplayPort™ or one HDMI outputs to drive the monitor at the Preferred Mode.
  • [3] Included cables may vary by country.
  • [4] Lock sold separately.
  • [5] Host PC requires Windows 10 and above. HP Display Center is available on the Microsoft store.
  • [6] EPEAT® registered where applicable. EPEAT® registration varies by country. See www.epeat.net for registration status by country. Based on US EPEAT® registration according to IEEE 1680.1-2018 EPEAT®. Status varies by country. Visit www.epeat.net for more information.
  • [7] Percentage of recycled glass in the monitor panel varies by product. Recycled glass is expressed as a percentage of the total weight of the glass.
  • [8] Ocean Bound plastic is expressed as a percentage of the total weight plastic. Ocean Bound plastic is based on the definition set by the UL2809 standard.
  • [9] External power supplies, WWAN modules, power cords, cables and peripherals excluded. Service parts obtained after purchase may not be Low Halogen.
  • [10] 100% outer box packaging and corrugated cushions made from sustainably sourced certified and recycled fibers.
  • [11] Recycled metal is expressed as a percentage of the total weight of the metal according to ISO 14021 definitions for metal parts over 25 grams.
  • [12] The Client Management Script Library must be downloaded to the connected PC to run CMSL commands. Some limitations may apply to legacy displays. Visit support.hp.com to download HP CMSL.
024450601
Mon-Fri 9.00am - 6.00pm
6623284555(WhatsApp)
@hpthailand (Line)
