Accessories
Items 1-15 of 39
1  of  3
39 Results
 Results
  1. Songkran Savings | Up to THB 7,000 OFF*
    In Stock
    Songkran Festival
    #2 Best Seller
    HP Wireless Mouse 200
    Lose the wire. Love the price.
      X6W31AA
      THB 490.00
      SAVE THB 195 (39%)
      THB 295.00
      THB 29.50/m*
    • Songkran Savings | Up to THB 7,000 OFF*
      In Stock
      Best Seller
      Songkran Festival
      HP 280 Silent Wireless Mouse
      No sound, no wires
      • No sound, no wires
      • Reliable connection with a 2.4GHz wireless dongle
      • Up to 90% noise reduction on the left and right buttons
      • Dimension (cm) : 10.95 x 7.08 x 4.01
      • Weight : 0.21 lb
      19U64AA
      THB 790.00
      SAVE THB 300 (37%)
      THB 490.00
      THB 49.00/m*
      In Stock
      Best Seller
      Songkran Festival
       Poly Blackwire 5220 Stereo USB-A Headset
      • Select the right option for your device: USB-A or USB Type-C® for PC and 3.5 mm for mobile connectivity.
      • Ultra-soft leatherette ear cushion(s) wrapped around pillow-soft memory foam provide long lasting comfort. A lightweight cushioned metal headband offers durability and a comfortable custom fit.
      • Hi-fi stereo wearing style for those who want a richer, more immersive experience.
      • Dynamic EQ optimizes the quality of your voice on calls, and automatically adjusts the EQ settings when you want high-quality sound for listening to music or for multimedia playback.
      • Connection type: Wired USB Type-A; 3.5 mm audio
      • With Poly Standard 2 Year Limited Warranty
      80R97AA
      THB 3,550.00
      SAVE THB 260 (7%)
      THB 3,290.00
      THB 329.00/m*
      In Stock
      Songkran Festival
      HP 240 Empire Red Bluetooth Mouse
      Stay connected in style
      • Stay connected in style
      • With Bluetooth 5.1 wireless connectivity
      • Sleek and ambidextrous design
      • With 1,600 DPI for super accurate tracking
      • Up to 15 months battery life
      • Dimensions (mm) : 107 x 60.5 x 29.31
      • Weight : 0.0542 kg
      43N05AA
      THB 590.00
      SAVE THB 355 (60%)
      THB 235.00
      THB 23.50/m*
    • Use HPTH5 For 5% OFF* Storewide
      In Stock
      #1 Best Seller
      HP Prelude 15.6-inch Backpack
      Travel at the speed of ultralight
      • Travel at the speed of ultralight
      • Slip on the padded straps of this ultralight, ultradurable stylish pack with a zap of color on the zipper
      • Made with water-resistance material to keep it all dry
      • Dimensions (cm) : 31 x 10.5 x 45.5
      • Weight : 0.38 kg
      2Z8P3AA
      THB 490.00
      SAVE THB 40 (8%)
      THB 450.00
      THB 45.00/m*
      In Stock
      Best Seller
      HP 150 Wired Mouse
      Sometimes everything just clicks
      • Works on almost any surface with astounding accuracy
      • Click real quick
      • Elegant ergonomic design
      • Ambidextrous
      240J6AA
      THB 190.00
      THB 19.00/m*
    • Use code HP1500 | Get THB1,500 OFF*
      In Stock
      Best Seller
      HP DesignJet T200/T600 Automatic Sheet Feeder
      Simple A3/A4 compatibility with your LF Plotter.
      • Automatic sheet feeder tray for up to 13-inch by 19-inch sheets (works with A3 and A4 sheets)
      • Easily switch from roll to single sheets automatically
      • Holds up to 50 A3 sheets at a time, feeds up to 6 A3 pages per minute
      • Margins on all sides are 5 mm x 5mm x5 mm
      • Works with HP DesignJet T210, T230, T250, T630 & T650 Large Format Plotter Printers
      8AJ60A
      THB 4,500.00
      SAVE THB 2,000 (44%)
      THB 2,500.00
      THB 250.00/m*
      In Stock
      HP Travel 18 Liter 15.6-inch Laptop Backpack
      That One Bag Life
      • Dimensions: 290 x 240 x 420 mm (expanded); 290 x 160 x 420 mm (non-expanded)
      • Weight: 0.51 kg
      6B8U6AA
      THB 1,299.00
      SAVE THB 109 (8%)
      THB 1,190.00
      THB 119.00/m*
      In Stock
      HP Wired Desktop 320K Keyboard (US Layouts)
      Pro-class productivity for your workspace
      • Pro-class productivity for your workspace
      • Easy to connect and use
      • Designed with the environment in mind
      • Designed for your comfort
      • Dimensions (cm) : 42.62 x 11.09 x 1.67
      9SR37AA
      THB 1,190.00
      THB 119.00/m*
      In Stock
      HyperX Cloud Core Gaming Headset (Black)
      Amazing sound meets signature comfort and durability
      • Amazing sound meets signature comfort and durability
      • DTS® Headphone:X®[1] Spatial Audio
      • Durable aluminum frame
      • Signature HyperX comfort
      • Detachable noise-cancelling microphone
      • Cable length : 1m
      • With 2 Year Manufacturer Warranty
      4P4F2AA
      THB 2,690.00
      THB 269.00/m*
      In Stock
      HyperX Alloy Origins - Mechanical Gaming Keyboard - HX Red (TH Layout)
      Compact keyboard featuring custom HyperX mechanical switches.
      • The HyperX Alloy Origins is a mechanical gaming keyboard with a compact design and customizable RGB key lighting.
      • Rated for 80 million keypresses with no loss of quality
      • Full aircraft-grade aluminum body
      • Comes with detachable USB-C cable
      • Cable length : 5.9 ft
      • Dimensions (W x D x H) : 442.5 x 132.5 x 36.4 mm
      • Keyboard layout : Thai
      4P4F6AH
      THB 3,290.00
      THB 329.00/m*
      In Stock
      HyperX Alloy Elite 2 - Mechanical Gaming Keyboard - HX Red (US Layout)
      For play. For work. For everything.
      • The HyperX Alloy Elite 2 is the keyboard for gamers, streamers, and multi-taskers who require controls at their fingertips.
      • HyperX Mechanical Switches[1] & Pudding Keycaps
      • Signature light bar & dynamic RGTB lighting effects
      • Dedicated media keys and large volume wheel
      4P5N3AA
      THB 4,690.00
      SAVE THB 100 (2%)
      THB 4,590.00
      THB 459.00/m*
      In Stock
      HP LaserJet 100 Sheet Reverse ADF Accy
      • Ensure optimum print quality
      • Maximise your business efficiency
      • Reliable and built to last
      X0R65A
      THB 7,470.00
      THB 747.00/m*
      In Stock
      Poly Voyager Surround 85 UC Microsoft Teams Certified USB-C Headset +USB-C/A Adapter +Charging Stand
      Crafted for your work life
      • Microsoft Teams Certified
      • Adjustable Active Noise Cancellation (ANC)
      • 6 built-in boomless microphones for clear audio
      • Up to 21 hours talk time
      8G7T8AA
      THB 19,990.00
      THB 1,999.00/m*
      Pre-Order : Call 1800-012-214
      Songkran Festival
      #3 Best Seller
      HP 240 Pike Silver Bluetooth Mouse
      • Lock On with Bluetooth 5.1
      • Smooth, Speedy, Sensitive
      • Thoughtfully designed
      43N04AA
      THB 590.00
      SAVE THB 355 (60%)
      THB 235.00
      THB 23.50/m*
    Items 1-15 of 39
    1  of  3
    39 Results
     Results
    6627873344
    Mon-Fri 9.00am - 6.00pm
    6623284555(WhatsApp)
    @hpthailand (Line)
