  • CLOUD, getAggregateRating, 471ms
HP ZBook Firefly 14 inch G9 Mobile Workstation PC Wolf Pro SecurityEdition
In stock
6Q9N1PA
screen size 14"
Color Nouvelle Silver
Protect your device with an hp carepack
OPTIONS
(MORE OPTIONS AVAILABLE)
Learn More
None
    Choose Your Option
    hp care pack(1) learn more
  • None
  • HP 3 year Next Business Day Response Onsite w/Accidental Damage Protection NB HW Supp
    THB 2,970.00
THB 56,604.00 SAVE฿6,814 (12%)
THB 49,790.00
You Save: ฿6,814 (12%)
THB 4,979.00/m*
  See repayments
Free & fast delivery - Learn More
0% Interest Free - Learn More
Delivery
Shipping Availability
Delivery estimate to is:
In stock
Overview
Recommended
Features
Specs
Offers
Reviews
Ask a Question
Similar Products
HP ZBook Firefly 14 G9 Mobile Workstation PC
Step up performance. Not size
Pro-level performance combines with true mobility in this amazingly sleek and powerful laptop. Stay productive wherever you're working with integrated or discrete graphics and processor, AI-enhancing webcam and audio, and a stunning display—everything you need to collaborate and manage projects anywhere.
  • Intel Core Processors
  • HP Fast Charge
  • HP Wolf Security
1 2
  • 1. 5MP HD IR camera
  • 2. Clickpad with multi-touch gesture support
*For selected products only
Upgrade to pro-level performance
Say goodbye to lags and crashes with faster responsiveness on projects. With Intel® processors1 and integrated or discrete graphics you can open large files and run pro apps simultaneously for speedy multitasking and productivity.
Connect. Communicate. Collaborate.
Collaborate effectively with ZBook Firefly. The AI enhanced auto-framing 5MP camera6 offers improved image quality even in low light, and discrete audio amps block background noise so you can connect from any location with a more personal experience.
Industry-leading security features
Advanced security features come standard. System safeguards like HP Sure Start – the industry's first self-healing BIOS – mean your device is locked down tight, so your data and identity are too.
Work all day. Anywhere.
Starting at 1.44 kg,4 our most mobile ZBook is made to move. With up to 13-hours of battery life5, this sleek yet durable device is small enough to fit in your bag so you can stay productive anywhere. This is high performance workstation power on the go.
Immerse in your work
The more you can see, the more you can do. The 16:10 aspect ratio reduces the need to scroll by showing more vertical content than a 16:9 display. Now you can see more of your programs and apps you use every day.
HP Z Turbo Drive High-speed Storage
Work without limits in any location with local PCIe storage that’s up to 6x faster than SATA SSD, and up to 21x faster than traditional HDD storage.7
Take The Next Step
1. Multicore is designed to improve performance of certain software products. Not all customers or software applications will necessarily benefit from use of this technology. Performance and clock frequency will vary depending on application workload and your hardware and software configurations. Intel’s numbering, branding and/or naming is not a measurement of higher performance.
2. Recharges the battery up to 50% within 30 minutes when the system is off or in standby mode. Power adapter with a minimum capacity of 65 watts is required. After charging has reached 50% capacity, charging will return to normal. Charging time may vary +/-10% due to System tolerance.
3. HP Wolf Security for Business requires Windows 10 or higher, includes various HP security features and is available on HP Pro, Elite and Workstation products. See product details for included security features and OS requirement.
4. Lowest weight. Weight will vary by configuration.
5. Battery life will vary depending on the product model, configuration, loaded applications, features, use, wireless functionality and power management settings. The maximum capacity of the battery will naturally decrease with time and usage. See MobileMark18 battery benchmark https://bapco.com/products/mobilemark2018/ for additional details.
6. Optional feature that must be configured at purchase.
7. For hard drives, GB = 1 billion bytes. TB = 1 trillion bytes. Actual formatted capacity is less. Up to 30GB (for Windows 10) of system disk is reserved for system recovery software.
8. Depending on your product configuration, you may be downgraded to the Windows 10 version.
Features
Intel® Core™ i7 processor
Run several CPU–heavy programs simultaneously without sacrificing performance with an Intel® Core™ i7 processor.
HP Fast Charge
Ultra-fast recharge takes you from zero to 50% charge in just 30 minutes.
Spill-resistant Keyboard
Accidents happen - which is why we designed our keyboard with a drain hole, so minor spills flow out the bottom for easy cleanup.
Specs
Windows 10 Pro (available through downgrade rights from Windows 11 Pro)
Processor
Intel® Core™ i7-1260P (up to 4.7 GHz with Intel® Turbo Boost Technology, 18 MB L3 cache, 12 cores, 16 threads)
Memory
16 GB DDR5-4800 MHz RAM (2 x 8 GB)
Graphics
Intel® Iris® Xᵉ Graphics
14" diagonal WUXGA display
Memory and storage
16 GB memory; 512 GB SSD storage
Offers
Special offers
Shop Dee Mee Kuen 2023
  • All purchases from HP are qualified for Shop Dee Mee Kuen 2023's VAT Tax Invoice
  • Validity period: 13.1.2023 - 15 February 2023
SEE MORE
Up to 50% off PWP on accessories and more!
Purchase-With-Purchase Item Promo Details
50% off Accessories Max 500 baht discount
10% off Printers Max 300 baht discount
10% off Monitors Max 300 baht discount
  • Discount will be automatically applied at checkout.
  • This promo is valid with any LAPTOPS or DESKTOPS only.
  • You may add PWP items under "Recommended" tab or add item to your cart directly.
  • Other terms apply*.
SEE MORE
Reviews
  • CLOUD, getReviews, 5.36ms
Ask a Question
Ask a Question
