HP EliteDisplay E201 20-inch LED Backlit Monitor
- 20"
- 1600 x 900
- 5 ms (on/off)
- Widescreen (16:9)
THIS PRODUCT IS DISCONTINUED
Ringkasan
fitur
Height/Swivel adjustability
Monitor with height/swivel adjustability allows for comfort on your neck and eyes.
LED backlighting
Reduced energy consumption, offer better contrast and brightness, and greater color range instead of cold cathode fluorescent (CCFL) backlighting.
Pivot rotation
Monitor pivot refers to the ability to rotate the display, changing the aspect ratio from a widescreen format to a vertically inclined long format.
Spesifikasi
- Nomor produk
- C9V73AA
- Product color
- Black
- Display size (diagonal)
- 20"
- Aspect ratio
- Widescreen (16:9)
- Resolution (native)
- 1600 x 900
- Pixel pitch
- 0.276 mm
- Brightness
- 250 cd/m²
- Contrast ratio
- 1000:1 static; 5000000:1 dynamic
- Response time
- 5 ms (on/off)
- Display features
- Plug and Play; Anti-glare; User programmable; Language selection; On-screen controls
- Display Input Type
- 1 DisplayPort (with HDCP support); 1 DVI-D (with HDCP support); VGA
- Ports
- 3 USB 2.0 (one upstream, two downstream)
- Dimensions without stand (W x D x H)
- 47.28 x 5.1 x 28.9 cm
- Dimensions with stand (W x D x H)
- 47.28 x 22.89 x 43.48 cm
- Berat
- 5.2 kg
- Catu daya
- Input voltage: 90 to 265 VAC
- Power Consumption Description
- 30 W (maximum), 22 W (typical), 0.5 W (standby)
- Operating temperature range
- 5 to 35°C
- Energy Efficiency Compliance
- ENERGY STAR® qualified; EPEAT® Gold
- Lingkungan
- Arsenic-free display glass; Mercury-free display backlighting; Low halogen
- Apa yang ada di dalam kotak
- HP EliteDisplay E201 20-inch LED Backlit Monitor; VGA cable; DVI-D cable (for APJ region only); DisplayPort cable (not included in APJ region except for Australia and New Zealand); USB cable; AC power cable; Printed documentation and CD; HP DisplayAssistant software
- Jaminan
- Three years parts, labour and on-site limited warranty
- Physical security
- Security lock ready
Special offers
Ulasan
Tambahkan
Produk -
Bandingkan sekarangKosongkan SemuaTidak ada produk yang ditambahkan ke daftar perbandingan
